POV-Ray : Newsgroups : povray.advanced-users : Applying noise to geometry Server Time
15 Mar 2026 13:15:39 EDT (-0400)
  Applying noise to geometry (Message 7 to 16 of 17)
<<< Previous 6 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Applying noise to geometry
Date: 27 Feb 2023 18:43:37
Message: <2519ca7c-3804-d941-50de-b664a19ab119@gmail.com>
On 28/02/2023 01:26, Cousin Ricky wrote:
> I haven't tried it out for myself, but there is an Object Collection
> module that might be helpful for this method:
> https://github.com/LeForgeron/PovContributions/tree/master/findsurface/maggot%201.0
Thanks a lot, this is exactly what I was expected !
It works fine, I need only to play with covering object's orientation a
little.
YB
Download 'findsurface.png' (315 KB)
Preview of image 'findsurface.png'
Date: 27 Feb 2023 19:10:00
Message: <web.63fd45ba2d7275891f9dae3025979125@news.povray.org>
> little.
> YB
I haven't looked any of this over, but look over this thread, and see if any of
that helps you:
http://news.povray.org/povray.binaries.images/message/%3Cweb.603d82a3a906d8e31f9dae300%40news.povray.org%3E/#%3Cweb.603
-BW
Date: 27 Feb 2023 19:28:55
Message: <509e7f25-9981-680f-2c96-07e945f03104@gmail.com>
> that helps you:
Thanks, Bald, I will try it...
"Curiouser and curiouser!"
YB
Date: 28 Feb 2023 02:00:00
Message: <web.63fda6072d72758917bac71e8ffb8ce3@news.povray.org>
> thanks for ideas and examples. Although fist method works fine, second
> looks more attractive, as, I suppose, will allow 'decorate' imported
> mesh, which gives me more control on the object's shape.
I.i.r.c. Poseray https://sites.google.com/site/poseray/ can do mesh displacement
based on uv vectors and images. Never tried it myself.
ingo
Date: 28 Feb 2023 02:47:04
Message: <ff679b9e-7a8f-d0e1-8acb-022204f0c765@gmail.com>
Mmm, Poseray ...
I have one, but it's almost the same as importing mesh from ZBrush.
Your first advice about using 'meshmaker' seems more attractive to me...
YB
Date: 28 Feb 2023 03:30:00
Message: <web.63fdbb802d72758917bac71e8ffb8ce3@news.povray.org>
> Mmm, Poseray ...
A long time ago I wrote an unfinished tool to convert mesh2 to obj files.
Something like that could be made to write a bunch of pov-ray arrays to a file.
Then you have full control over the mesh and can transform it by using uv
information and functions.
Or, ask FlyerX to add such an option to Poseray, if they are still working on
it.
https://news.povray.org/povray.binaries.utilities/thread/%3CXns94F5A773245Aseed7%40news.povray.org%3E
ingo
Date: 28 Feb 2023 04:11:45
Message: <187e6d9f-5718-273a-e80e-62604d14708c@gmail.com>
> it.
Thanks for another idea, but I would like to stay 'inside' POV as long
as possible, avoiding external tools. Now, after a few experiments, I
see, that adding some arbitrary 'extensions' to geometry (as in the
attached image, for ex.) is not too complicated.
Maybe I will try to shift the mesh's vertices according to some noise
function too.
YB
Download 'play_spline.png' (151 KB)
Preview of image 'play_spline.png'
Date: 28 Feb 2023 08:14:53
Message: <63fdfe4d@news.povray.org>
Op 28-2-2023 om 07:58 schreef ingo:
> ingo
See attachment.
Download 'displacement mapping - howto.pdf' (527 KB)
Date: 28 Feb 2023 09:20:00
Message: <web.63fe0cd42d7275898ec57efd10800fb2@news.povray.org>
> See attachment.
Date: 28 Feb 2023 13:16:53
Message: <63fe4515@news.povray.org>
On 27/02/2023 21:32, yesbird wrote:
> Hi,
> while working on Yes-project, I am trying to find the way of making
> the objects less 'geometrical', giving them more natural and 'noisy'
> shapes (like in this attachment, for example). The only way I found in
> manual is to play with normals, but I'd like to have an influence on
> geometry, to apply more relief.
Thanks to all your comments, advice and links, a solution was finally
found. Script is working by making a path of spheres along a spline and
applying relief elements to each sphere. It's left only to make some
randomization and push code to the parameterized macro.
Thanks a lot to everyone !
YB
Download 'play_spline_pins.png' (290 KB) Download 'play_spline_spheres.png' (304 KB)
Preview of image 'play_spline_pins.png'
Preview of image 'play_spline_spheres.png'
