POV-Ray : Newsgroups : povray.advanced-users : Override textures/materials? Server Time
14 Mar 2026 23:42:25 EDT (-0400)
  Override textures/materials? (Message 12 to 21 of 31)
Subject: Re: Override textures/materials?
Date: 18 Jun 2021 16:32:48
Message: <60cd02f0$1@news.povray.org>
On 6/18/2021 2:15 PM, Norbert Kern wrote:
> Hi Mike,
> for depth_maps I use a variable to change every finish ( e.g. finish {specular
> dfac*0.3 roughness 0.0003 diffuse dfac*0.6 reflection {dfac*0.03, dfac*0.1}}.
> For the "normal" render dfac is defined as 1 and for depthmaps or other
> effectmaps dfac is 0.
> Together with a white fog you get your depthmap.
> Norbert
Could you post some example images? I don't quite understand what this does.
Mike
Date: 19 Jun 2021 09:40:00
Message: <web.60cdf304eaa34374d81232a3b7ae6630@news.povray.org>
> Mike
If you set every diffuse, specular, phong, ambient, emission and reflection
value as zero, you get a black material.
A white fog turns this to an inverse depthmap. Then you can adapt the color_map
of your blurring file or you can invert it via Photoshop and co to get a
"regular" depthmap.
Here is a depthmap of my last image.
Norbert
Download 'mountain_forest_depth.jpg' (285 KB)
Preview of image 'mountain_forest_depth.jpg'
Date: 19 Jun 2021 10:38:08
Message: <60ce0150$1@news.povray.org>
Am 19.06.2021 um 15:37 schrieb Norbert Kern:
> "regular" depthmap.
Some caveats of this approach:
- The brightness will not depend on the Z coordinate, but on the
distance to the camera; this may or may not be what you want.
- The image value will not represent the distance itself, but rather an
exponential-ish function thereof, something like:
     f(d) = 1 - p^d
where p is a value < 1. Again, this may or may not be what you want.
Also, like with every other thing where you want to get a per-pixel
value out of the render rather than a color, the topic of gamma needs
attention, and also precision, i.e. bit depth.
Date: 19 Jun 2021 12:58:57
Message: <60ce2251$1@news.povray.org>
Le 2021-06-18 à 13:52, Mike Horvath a écrit :
> On 6/18/2021 10:44 AM, Alain Martel wrote:
>> Le 2021-06-18 à 08:41, Mike Horvath a écrit :
>>> Is there a way to override textures or materials that have already
>>> been declared or applied?
>>> I am trying to create a depth map, and need to apply a custom texture
>>> to the entire object.
>>> Thanks.
>>> Mike
>> In the case of a texture or material that have been declared but not
>> used yet, a new #declare will completely replace the original with the
>> new definition.
>> If it have been applied to something, then redefined, then, any object
>> that received it will keep the original definition.
>> In your case, you need to remove, or at least comment out, any texture
>> or material from your object. Then, apply your new texture to that
>> object as a whole.
> Instead of declaring my textures, I may start using macros instead. That
> way, I can just comment out the texture declaration inside the macro.
> But might this not consume more memory?
> Mike
Whenever you use a macro, it get expanded every times it's used, so,
will use more memory while parsing.
When you use a declared texture that is applied in many places, then,
you can change it everywhere at once by changing the declare.
With a macro, you can do the same by changing the definition of the
macro. That won't affect the parameters passed to that macro anywhere in
the scene, but, you can change the macro so that it still accept the
same parameter but ignore them.
Date: 19 Jun 2021 15:36:53
Message: <60ce4755$1@news.povray.org>
On 6/18/2021 2:53 PM, clipka wrote:
> Am 18.06.2021 um 19:33 schrieb Bald Eagle:
>>> Is there a way to override textures or materials that have already been
>> What if you union everything together and do an intersection with a
>> box that is
>> its own
>> object that you can give a fresh texture to.
> That's a smart idea.
> You may need to specify `cutaway_textures` though, and I'm not sure
> whether it does indeed work with objects that are already explicitly
> textured.
What is `cutaway_textures`? I have never head of it.
Mike
Date: 19 Jun 2021 15:38:43
Message: <60ce47c3$1@news.povray.org>
>> reflection
>> color_map
>> "regular" depthmap.
Would it work better if depth maps were an engine feature versus a bunch
of tricks/hacks with pigments or fog?
Mike
Date: 19 Jun 2021 15:40:18
Message: <60ce4822$1@news.povray.org>
>>> reflection
>>> color_map
>>> "regular" depthmap.
>> an exponential-ish function thereof, something like:
> Mike
Not saying you should implement it. 3D photos (see other thread) don't
seem to actually work that well except in a minority of specific cases.
Mike
Date: 19 Jun 2021 15:50:00
Message: <web.60ce4961eaa343741f9dae3025979125@news.povray.org>
It's a keyword
http://www.povray.org/documentation/view/3.6.1/362/
Date: 19 Jun 2021 15:55:00
Message: <web.60ce4b7feaa343741f9dae3025979125@news.povray.org>
Is this the same as:
http://news.povray.org/povray.advanced-users/thread/%3C5e52bde0%241%40news.povray.org%3E/
http://news.povray.org/povray.newusers/thread/%3Cweb.5c90a6ab69c1cfb51d791a250%40news.povray.org%3E/
I have done a similar thing for 3D printing, and simply used a gradient texture,
scaled and translated to contain the entire scene within the 0-1 range.
Date: 19 Jun 2021 20:52:08
Message: <60ce9138$1@news.povray.org>
Am 19.06.2021 um 21:38 schrieb Mike Horvath:
No. It would just be simpler to set up (no tampering with textures,
pigments, fog and/or interiors) while at the same time potentially less
flexible.
(As a matter of fact, if I'm not mistaken older versions of POV-Ray
provided such a feature. At the very least MegaPOV did.)
The caveats I mentioned aren't necessarily problems, just things to be
mindful of, that might require modifications to the process if they
should happen to not exactly be what you need.
