POV-Ray : Newsgroups : povray.advanced-users : Speeding up media Server Time
2 Jul 2025 17:04:44 EDT (-0400)
  Speeding up media (Message 11 to 20 of 32)
Subject: Re: Speeding up media
Date: 11 Feb 2021 10:45:30
Message: <6025511a$1@news.povray.org>
Le 2021-02-09 à 02:30, Thomas de Groot a écrit :
> Op 08/02/2021 om 16:16 schreef Alain Martel:
>> Le 2021-02-07 à 02:23, Thomas de Groot a écrit :
>>> Op 07/02/2021 om 04:41 schreef Mike Horvath:
>>>> On 2/5/2021 6:56 AM, Bald Eagle wrote:
>>>>> it's likely not your media - but your media settings.
>>>>> try:
http://news.povray.org/povray.newusers/message/%3C59a9ec1c%40news.povray.org%3E/#%3C59a9ec1c%40news.povray.org%3E
>>>> I'm not sure how that applies to my case. I am not using emissive
>>>> media or the "samples" keyword.
>>> There is nothing really wrong with your code as far as I can tell and
>>> from own experience. From the outside (of the media) it is even
>>> rather fast due to the default intervals 1 and samples 1 (Yes! you
>>> /do/ use samples, even if you don't).
>>> However, depending on the location of the camera within or without
>>> the media, render times can be very different; you even may need to
>>> increase the samples value to avoid splotches, and that will decrease
>>> render time even more although not that much.
>>> Using media is time consuming. There is no alternative.
>> The default for samples is 10.
>> samples default to 1 when using sampling method 1 or 2.
>> The default are, as of version 3.6 :
>> sampling_method 3
>> intervals 1 //DO NOT increase !
>> samples 10
>> Increasing intervals dramatically increase the rendering time without
>> giving any appreciable improvement.
>> samples 10 intervals 3 render slower than samples 50 intervals 1.
> I don't know where in the wiki there was a line saying defaults being
> intervals 1 and samples 1,1. Of course, I cannot find that paragraph
> anymore (typical!); but you are right of course: default samples is 10.
You have a mixup between the old version 3.5 and newer version 3.6
documentations.
The format : samples 1,1
is that of method 1 and 2. It's used to set the number of samples for
dark, bright intervals.
It's a leftover from the pre 3.6 version when the default sampling
method was method 1. It demanded an intervals number large enough to
match the number of distinct illuminated areas along a tracing path. If
you had 20 spotlights shining through some media, then, you needed 40,
or more, intervals : One interval for each illuminated part and one
interval for each non-illuminated parts between the illuminated ones.
When using the default method 3, when you have two values for samples,
the second is silently ignored.
Date: 12 Feb 2021 02:33:43
Message: <60262f57@news.povray.org>
Op 11/02/2021 om 16:45 schreef Alain Martel:
> documentations.
The wiki documentation then needs some updating here or a further
elaboration.
Date: 12 Feb 2021 06:03:39
Message: <6026608b$1@news.povray.org>
>> documentations.
>> If you had 20 spotlights shining through some media, then, you needed
>> 40, or more, intervals : One interval for each illuminated part and
>> one interval for each non-illuminated parts between the illuminated ones.
> elaboration.
already there: about 2/3 of the way down...
http://wiki.povray.org/content/Reference:Sampling_Parameters_%26_Methods
Date: 12 Feb 2021 07:45:31
Message: <6026786b$1@news.povray.org>
>>> samples, the second is silently ignored.
>> elaboration.
Maybe my old eyes, but I see on that page more or less a block of text
for method 3; then one for method 1 and last one for method 2.
For samples min, max in the block for method 1 I see:
"The samples Min, Max keyword specifies the minimum and maximum number
of samples taken per interval. The default values are samples 1,1. The
value for Max may be omitted, in which case the range Min = Max will be
used."
Which for method 3 is:
- Wrong in suggesting the min and max are both used. Only min is used.
- Wrong in suggesting the default values for method 3 are 1,1. For
method 3 it is 10. (A little bell that the wrong values are listed
somewhere else too in the docs)
- Wrong in saying samples controls the min and max samples taken per
interval. In method three the number of samples ultimately taken (where
the adaptive method is actually working...) is controlled by
aa_threshold and aa_level. The aa_level really being the limit on the
recursive depth for the algorithm.
I think at a minimum Alain's sentence should be added to the block
related to method 3 at the top. Plus a note about the default samples
with method 3 for the single starting interval being the minimum 10.
Deja vu...
Aside: As people talk about media, it is kicking loose some of the items
on my mental "media isn't quite right" list.
a) In multiple medias which I mentioned earlier I think the problem with
mixing media types had to do with intervals. The first/last setting gets
carried into the rest or similar because it gets set at parse time. It's
always wrong for some of the media - if you mix types.
b) Do NOT use jitter with method 3. Well, unless you just want
additional noise - and often slower media. It never fit the method 3
approach and there are bugs with the actual jitter implementation in
method 3. See, for example, https://github.com/POV-Ray/povray/issues/348.
Quite a bit of this post has been discussed previously elsewhere - a
good chunk of it at least was public (newsgroups / github).
Bill P.
Date: 12 Feb 2021 10:59:11
Message: <6026a5cf$1@news.povray.org>
>>> elaboration.
ok... i'm admitting to playing devils advocate to draw out more comments
> used."
> method 3 it is 10.
i see that mention in the paragraph beginning: Sample method 1 and
before paragraph beginning Sample method 2 ... am i picking nits?
fixed: http://wiki.povray.org/content?title=Special:RecentChanges&hidebots=0
again associated with Sample method 1... if you're buying my previous notion
well i agree on this one ... just wanted discuss other issues before i
addressed
Date: 13 Feb 2021 02:35:12
Message: <60278130@news.povray.org>
Op 12/02/2021 om 12:03 schreef Ash Holsenback:
Aaah! The offending chapter! ;-)
To tell the truth, this whole chapter is one mix of confusion. At no
point it becomes clear if we are reading about method 3, method 1, or
method 2, as the text jumps from one item to another and back (maybe I
am exagerating, but hardly so, and for non-native speakers a total
bewilderment).
I would suggest to subdivide the chapter into clearly defined paragraphs
with the following headers, /after the first 'note'/:
*- Method 3*
[following, a short exposition on how to use method 3 (default); the
(exclusive) use of intervals 1 (default); the use of (single) samples,
(default 10); etc]
*- Method 1*
[following, a short exposition of the legacy use of method 1]
*-Method 2*
[following, a short exposition of the legacy use of method 2]
That way, imho, new users and even experienced ones, will understand
what it is all about. The recent discussion shows how confusing things
sometimes appear to be...
Date: 13 Feb 2021 08:18:34
Message: <6027d1aa$1@news.povray.org>
> bewilderment).
agreed... i'm going to try to clean up grammar tangles etc
> *- Method 3*
> (default 10); etc]
spotted another difference with default for aa_level... 2nd paragraph
after 1st note has it at 4
while: http://wiki.povray.org/content/Reference:Media
has it at 3... inquiring minds wanna know
> *- Method 1*
> *-Method 2*
Date: 13 Feb 2021 19:36:19
Message: <60287083$1@news.povray.org>
It looks like it is 3.
media.cpp has:
Media::Media()
     Type = ISOTROPIC_SCATTERING;
     Intervals      = 10;
     Min_Samples    = 1;
     Max_Samples    = 1;
     Eccentricity   = 0.0;
     Absorption.Clear();
     Emission.Clear();
     Extinction.Clear();
     Scattering.Clear();
     is_constant = false;
     use_absorption = false;
     use_emission   = false;
     use_extinction = false;
     use_scattering = false;
     ignore_photons = false;
     sc_ext     = 1.0;
     Ratio      = 0.9;
     Confidence = 0.9;
     Variance   = 1.0 / 128.0;
     Sample_Threshold = nullptr;
     Sample_Method = 1;
     AA_Threshold = 0.1;
     AA_Level = 3;
     Jitter = 0.0;
Before anyone jumps on the Intervals, Min_Samples, Max_Samples and
Sample_Method defaults above, in parser_materials.cpp we have:
     if (AllowToken(MEDIA_ID_TOKEN))
         IMediaObj = CurrentTokenData<Media>();
     else
         /* as of v3.5, the default media method is now 3 */
         if (sceneData->EffectiveLanguageVersion() >= 350)
             IMedia->Intervals = 1;
             IMedia->Min_Samples = 10;
             IMedia->Max_Samples = 10;
             IMedia->Sample_Method = 3;
Won't that parser override sometimes mess up the defaults for method 1
and 2 you ask. Yes, I think it well might... I'm not going to do the
work to prove it now, but likely media 1 & 2 users will 'always' have to
set the intervals to 10, min and max to 1 if they want documented
defaults for those two methods.
Bill P.
Date: 14 Feb 2021 07:22:17
Message: <602915f9@news.povray.org>
thanks for verification... thats what i found as well. just wanted
someone to concur
> media.cpp has:
> Media::Media()
>      Intervals      = 10;
>      Min_Samples    = 1;
>      Max_Samples    = 1;
>      Eccentricity   = 0.0;
>      Absorption.Clear();
>      Emission.Clear();
>      Extinction.Clear();
>      Scattering.Clear();
>      sc_ext     = 1.0;
>      Ratio      = 0.9;
>      Confidence = 0.9;
>      Sample_Method = 1;
>      AA_Threshold = 0.1;
>      AA_Level = 3;
>      Jitter = 0.0;
>      else
funny you should sat that, as i was looking... several times went hmmmm
what a tangle
Date: 14 Feb 2021 11:02:43
Message: <602949a3$1@news.povray.org>
> media.cpp has:
> Media::Media()
>      Intervals      = 10;
>      Min_Samples    = 1;
>      Max_Samples    = 1;
>      Eccentricity   = 0.0;
>      Absorption.Clear();
>      Emission.Clear();
>      Extinction.Clear();
>      Scattering.Clear();
>      sc_ext     = 1.0;
>      Ratio      = 0.9;
>      Confidence = 0.9;
>      Sample_Method = 1;
>      AA_Threshold = 0.1;
>      AA_Level = 3;
>      Jitter = 0.0;
>      else
> Bill P.
another question: are variance, confidence and ratio valid in method
3... given current narrative i'd say yes to the first two and no on the last
made some progress... here's what i have so far
