POV-Ray : Newsgroups : povray.advanced-users : Displacement Mapping and subdivision surfaces Server Time
28 Jul 2024 12:31:20 EDT (-0400)
  Displacement Mapping and subdivision surfaces (Message 1 to 8 of 8)
Subject: Displacement Mapping and subdivision surfaces
Date: 3 Mar 2006 03:30:01
Message: <web.4407fdd49e2554f58b3e80460@news.povray.org>
Hello everyone,
I would like to know if there is some code to use Displacement mapping,
I love to use Pov-Ray for redering, but I construct models with displacement
mapping and subdivision surfaces so I would need a support for these
to use it for the future,
Thor
Subject: Re: Displacement Mapping and subdivision surfaces
Date: 3 Mar 2006 03:50:02
Message: <du8vmf$j3i$1@chho.imagico.de>
McHannemann wrote:
> Hello everyone,
POV-Ray is mainly a renderer and subdivision surfaces and displacement
mapping are mainly modeling techniques.
There exists a patch for performing parse time subdivision of meshes:
http://www.cise.ufl.edu/~xwu/Pov-Sub/
and the compressed mesh system
http://www.geocities.com/ccolefax/pcm.html
supports deformation of meshes.
Furthermore there is the Surface Subdivision Suite:
http://www.geocities.com/evilsnack/nsss.htm
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 5 Mar 2006 10:20:01
Message: <web.440b007191531e9ea115bbc30@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> McHannemann wrote:
> > Hello everyone,
> Christoph
Hi Christoph, can you add subdivision feature to pov-ray or megapov like
"POV-Ray with Subdivision " This is very usefull thing.  ?
Regards.
Hasan
Date: 10 Mar 2006 04:20:00
Message: <web.441143e291531e9ec91980a50@news.povray.org>
I just tried the POV-Ray Subdivison code and it is working good,
so waht I really would need now would be the displacement mapping,
it is supported in most of the rendering systems I know.
And it is a very usefull modelling tool, but what for are things
like ZBrush if the rendering system does not support it ;-)
REgards,
Thor
Date: 19 Mar 2006 22:41:57
Message: <441e2485@news.povray.org>
  If you want to move the vertices of a mesh around, then move them
around. If you are using the PCM format and the reader macros, it's
rather easy to do that.
Date: 20 Mar 2006 21:25:00
Message: <web.441f633e91531e9e435a24830@news.povray.org>
Based on what I read in Wikipedia on displacement mapping, you could
possibly use a set of height_fields, but it would be a fair amount of
trouble.
Date: 22 Mar 2006 12:00:01
Message: <web.442181c091531e9edb422d6a0@news.povray.org>
> trouble.
I have seen an update for poseray contains subdivison and displacement
mapping onto a mesh, I will try to see if I can get my Character done into
it, the original has 15 mil polys including the displacement... lets see
what poseray then povray can handle
Date: 4 Apr 2006 18:25:01
Message: <web.4432f0c891531e9e127644120@news.povray.org>
> McHannemann wrote:
> > Hello everyone,
In everything I've read on the web about displacement mapping, the term
itself always goes hand-in-hand with using polygonal models (and having to
subdivide the surface to get good results.)  Since POV's isosurfaces are
math constructs instead, and by nature "displaced surfaces"--and since an
image_map can be used as an isosurface function to further perturb such a
surface--it seems to me that this image_map technique could also be
called "displacement mapping."  Or is there a different term for it?
Ken
