Warp wrote:
> Andrey Skvortsov <sti### [at] list ru> wrote:
>>Another point made by Bernd and he is right that Povray SDL indeed needs
>>more features to be implemented
> I don't think anyone has questioned that. His solution to this problem
> was just simply wrong.
Exactly, my solution was wrong. I have once again to apologize for that.
Bernd Fuhrmann
Warp wrote:
> Bernd Fuhrmann <Sil### [at] gmx de> wrote:
>>Yes, it is. There are a lot of features missing that are used in a lot
>>of modern programming languages. Examples:
>>* Structs/Classes
>>* References, esp. to functions
>>* Namespaces
>>* strict type checking
> Then in your opinion for example Lisp and Prolog are not true
> programming languages?
I hate them, yes. I know there are people who really write programs with
them. They are neccessary for certain problems, like artificial
intelligence (where reusability might not be that critical). But there
aren't many programs as it seems. No complex convential software I know
of has been developed with Lisp or Prolog. I will not use them unless I
absolutely need them.
To give you an example for a real bad programming language:
BASIC (not visual). It just totally sucked. Do I need to explain that?
POVRay SDL is just a bit like BASIC. In fact it seems to take the
features of BASIC and mix them with the syntax of the C preprocessor: No
references, no structs, no namespaces, no custom types and so on. Please
note that I don't mean that as an exact description but rather as an
approximation. POVRay SDL is not exactly like BASIC.
Bernd Fuhrmann
ABX wrote:
> On Sun, 02 Jan 2005 17:17:30 +0100, Bernd Fuhrmann <Sil### [at] gmx de>
> wrote:
>>> What is, in your opinion, a "full featured programming language"?
>>> The SDL is turing-complete.
> I have to admit that term "modern" in case of programming makes me think about
> all those annoying features of VisualC which makes programming harder. I like
> plain simple programming when you think about algorithm rather than "cool"
> features of the "language".
>>Examples:
>>* Structs/Classes
> You can mimic structs array of arrays.
Yes, but I wan't real structs or objects. If I'd mimic them I could also
call C an object oriented programming language because I could use
structs and add pointers to functions.
> AFAIK POV-Ray does use references where it benefits in optimizations. Is there
> a place in current SDL when POV-Ray does copying of the object rather than
> referencing it, you can for sure fix it without introducing XML.
No, no, no. I want references to functions. I want references to
abstract data structures. I want references like they exist in Java.
>>Other possibly cool features
>>* Inheritance
>>* Java-like classes inside classes
>>* C++ like multiple inheritance
>>* Lambda expressions (Scheme)
> Obviously POV-Ray SDL is not perfect tool but also obviously it is a lot of
> power already and I very often choose it as simple scripting tool for series
> of simple operations. For example in samples there is a portfolio which easily
> outputs html files with all images rendered. But adding "cool" programming
> features just because they are "cool" is questionable.
Right. Sorry, my mistake. Replace cool with useful. Inheritance is
useful, period. And having useful features is always a good thing.
> In spite of all POV-Ray
> is a renderer so let's concentrate on rendering features: types of objects,
> cameras, lights, build-in patterns, antialiasing, HDRI, splines, visual
> effects, radiosity etc, etc. There is so much to do around such features that
> making programming "cool" if you probably have already your favourite
> programming language which you can easily adopt to preparing SDL file is
> wasting of man power (IMO).
Right. So I'll use for example Java to prepare the SDL. I'll write my
own set of utilities and then modules that are based upon those
utilities. So? What good will this do unless there are more then one
person (me) that will use it? It will lead to one thing: You won't be
able to use objects from my scene and I won't be able to use objects
from yours. So how will we solve this?
Bernd Fuhrmann
Darren New wrote:
> No. You'd just have code that you don't yet have a way to process.
> Parsing the SDL is only the first step. After that, you can do anything
> you want with the parsed code.
Right, but that won't solve my problem.
>> As mentioned earlier: I will have to think about something different
>> to solve my problem.
> So far, I haven't seen what your problem specifically is. So far, you've
> talked about generalized solutions to unspecified problems, but not
> specifically what you've encountered that youhad problems solving.
I want to code certain mesh transformations. This will be too complex in
SDL. Therefore I'd like to use some other programming language but I
couldn't find any solution that will ensure reusability. So XML was my
first idea for that but it is a bit awkward.
> I wrote my own parser to take input that was what I wanted it to be, and
> it outputs SDL (and HTML, and .BAT, and whatever else you want). I ran
> into a bunch of other limitations of POV-Ray that I had to work around
> in my "source code", but the structure of the parser I wrote made that
> not too difficult. Now, I just need to take the time to figure out how
> to put the results up on SourceForge(*) and to solicit opinions from
> others(+). :-)
This is almost what I was about to do. But there are some things that I
might not like: Just imagine the following:
Other people will do the same like you did: They will write their own
programs (each one with their own bugs and limitations and formats).
Some poor guy will use, let's say twenty of these programs for a real
cool scene. So he will be forced to write a build script. This leads to
the first couple of problems:
* Will your program be able to accept special code that is ment for the
next program?
* Will your program be able to run in the build environment (might be a
MAC, a Linux system that cannot execute BAT files or whatever.
I'd be interested in the program you wrote. If you like I can provide
some FTP space on a server that administrate. Just contact me via email.
Bernd Fuhrmann
Darren New wrote:
> Bernd Fuhrmann wrote:
>> No complex convential software I know of has been developed with Lisp
>> or Prolog.
> It amazes me that someone posting on a technical board never even
> *heard* of Emacs.
I heard of Emacs. But I never really used it or had a look at it's
source. I guess I will have to investigate how they did that.
Bernd Fuhrmann
>> So what part of the manual does describe how objects can solve my
>> problems? What part does give the hint?
> What part of your posts has actually described your problem?
I didn't describe my exact problem. But <41d9996f$1@news.povray.org>
gives you the hint what I want to do. I want to fetch some data and
created accordingly geometry. This should be done in a way that reusable
components are used without manual translation into POVRay SDL.
Additionally this should be done in a clean flexible way.
To be exact: I want to assemble ornament modules with different styles.
These are put into modules which are to be assembled in a certain way
(which is described in a tree like structure or a network or sth with
additional meta data). I known it is not yet very specific but I hope
you get the idea. Additionally these structures should be theoretically
transformable to other languages like SVG. So I would like to solve this
problem in a language that is general enough to produce at least POVRay
SDL and XML aswell as possible other languages (who knows what my little
mad mind will think of in the future). I'd like to have the ability to
used existing models in my ornament modules (POVRay specific part of it
of course).
Bernd Fuhrmann
Darren New wrote:
> Warp wrote:
>> However, I have always said that the strongest feature of POV-Ray is
>> also its weakest feature.
> It might be worthwhile to consider the use of an existing scripting
> language that's designed to be embedded in other programs, and use that
> for the scripting language. Something like elisp does for emacs. REXX
> might be a good choice, Tcl would almost certainly be a good choice,
> Python has already been used in some 2D graphics packages as a scripting
> language, etc.
Well, ok. That would certainly be possible. To be exact: Using another
programming language that output some SDL code is most likely the
solution to my problem. But: What good will it do I just I write my
utilities for my favourite programming language. It would be better to
develop some kind of library for that programming language that would be
used by most people who want to develop extensions that cannot be done
properly with POVRay SDL. A standard solution to this should emerge.
Anyone interested in it (while having no idea what it should be like)?
Bernd Fuhrmann
In article <41d86f9a$1@news.povray.org>, dne### [at] san rr com says...
> Patrick Elliott wrote:
> > Ah, but the parser can be used the SDL to generate multiple objects, each
> > needing to be parsed as well.
> Erm, I wouldn't think so. I think when people unfamiliar with POV-Ray
> talk about "parsing", they're talking about basically understanding the
> tokens in the source and the syntactic interrelationships between them.
Well.. Yeah, but I am trying to describe 'why' it takes a lot of time.
Even tokenizing doesn't overcome the processing needs to build something
complex, it just means the parser is now running something closer to JIT
type stuff. Its still executing code that isn't 'part' of the actual
engine in the while loop, until it finally starts making pixels.
void main () {
If Schrödingers_cat is alive
call functional_code()
else
call crash_windows();
> Andrey Skvortsov wrote:
>> I think you are wrong and really underestimate current povray
>> capabilities! What you have written (except discussed namespaces)
>> can be done without a problem right now. Not exactly the way you
>> wrote but similar, there are such things in Povray called objects...
>> RTFM.
> Write the Fine manual!
> POV-Ray help->Index->object:
> Object
> 2.5.11.23 Object Pattern
> adding texture to
> 1.2.1.5 Adding Texture to an Object
> describing
> 1.2.1.4 Describing an Object
> keyword
> modifiers, quickref
> 2.8.9 Object Modifiers
> pattern
>> You can create your arrays of humans and pass the through the mesh()
>> and not too ugly.
> Argh, arrays! I demand structs or real OOP. Sorry but this isn't
> acceptable for me.
> Regards,
> Bernd Fuhrmann
Help is not fantastic, I think so too.
I meant simple CSG
say you can write:
#declare myhuman = union{sphere .... box.. tringle ....etc }
it's not yet going to be shown. And then "instantinate" it like
object{myhuman}
object{myhuman {....some modification, other textures,position etc}}
well it's not like c++
class HumanMaker
HumanMaker(....)
public:
box
protected:
sphere
private:
DoSomething()
TranslateSomeWhere(..)
HumanMaker Human1; //should this make the object appear on the screen?
Should we also implement overloaded functions and operators and all
other advanced C++ stuff? :))
Current SDL mimic this class/object, but you cannot access your boxes
spheres (primitives) in the CSG, of course, that would give us more
power and have eaten more memory!
Although the thing is that OOP code is slower for parsing and this is
very important for 3d modeling, because you want FAST. I even think
there are people who would wish to simplify current SDL to achieve
faster parsing times (or whatever needed). I personaly wanted it,
playing with objects, containing millions of primitivies (strange
attractors)! Parsing is killingly slow and memory consumption is
enormous for such extremes.
But programming convenience and ability to share modules (classes) is
very attractive.
So that is totally a compromise and currently it's not too bad.
Warp has a good point here.
Andrey Skvortsov
Perhaps this will help to understand:
http://en.wikipedia.org/wiki/Compiler#Compiler_front_end
Bernd Fuhrmann
> I hate them, yes.
How does you hating them affect in any way the fact whether they are
true programming languages or not?
That's like saying that you hate toyotas and thus toyotas are not cars.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
That has been considered many times, but doesn't seem to be a good
solution.
POV-Ray needs a language specific for POV-Ray. Using a generic
programming language will make many things too awkward and hard to
use (too many things will have to be kludged).
Besides, optimally the new language will somewhat resemble the
current one so that the learning curve will not be as steep. Most
POV-Ray users have never used any other language and learning a
new language which is similar to the current SDL will be easier
than learning a completely different language.
> be used by most people who want to develop extensions that cannot be
> done properly with POVRay SDL.
Something like:
http://aspn.activestate.com/ASPN/Cookbook/Python/Recipe/205451
Ingo
In article <41d86f9a$1@news.povray.org>, Darren New <dne### [at] san rr com>
wrote:
> Once you get to the point of *interpreting* what "#while" means, you're
> past the parsing stage. POV-Ray may call that "parsing", but it isn't.
> It's executing the specification. In other words, if the OP wants to do
> something like add a namespace to some selected number of variables, you
> don't have to understand a "while" loop to find all the variables you're
> going to change, any more than emacs needs to understand SDL to
> search-and-replace spheres with something else.
When POV says it's parsing, it's really parsing. POV executes the scene
file as it parses it, rather than parsing into an intermediate form to
be executed later. This is one of the reasons it is so slow, and one
thing which badly needs improvement in POV4...it crawls around the input
source files while generating the scene. The body of a loop is actually
parsed once per iteration. Then there's a postprocessing stage where
stuff like photons and radiosity are precalculated, basically "filling
in the blanks" of the generated scene, and then you get to the rendering
stage.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
> Something like:
> Ingo
Yes. I don't know Python good enough, but I think something like that.
Perhaps with slightly more features or better internal structure, but I
really don't know Python good enough to decide that. Just a feeling in
my stomach that this can be done better.
Thanks for the hint. Btw: What is you opinion of a facility like it is
shown in that Python code piece?
Bernd Fuhrmann
> solution.
I don't understand that one. Why should people _need_ to learn new
languages. If there is just a frontend that is able to create SDL code
they'd still have SDL code to work with. They won't be able to
effectively modify it but they aren't now either in many cases (those
that are just to hard to be treated with common SDL).
Bernd Fuhrmann
>>I hate them, yes.
It doesn't. "Being a true programming language" is not defined. If you
mean Turing-complete was a good sign of true programming languages just
have a look at brainfuck (http://www.muppetlabs.com/~breadbox/bf/). No
sane person will use that language to code any serious software. So you
wouldn't consider that a real programming language. On the other hand:
What if you used such a programming language for 40 years and you could
do things faster with that awkward programming language then with any
other? You'd certainly consider it a real programming language. So what?
It's a matter of opinion. So why should we argue about it?
But there are still facts: Some things just save you a lot of time, like
OOP. Modularization is important. So we should have a good look at all
those little nice features of all kinds of programming languages that
allow a better form of modularization. These things should go into
POVRay SDL or any officially recommended frontend for it.
Come on. I did'nt say that. They are considered real programming
languages by many people. I know that. But I still don't like them. It's
just my opinion. Call it a feeling. I once had to do a couple of things
with Scheme and I was really pretty upset because of certain things. So
I will not consider them as a true alternative for C(++) for my
programming work. Other people will think different. I can live with
that (as long as I don't have to mess up with their code).
Bernd Fuhrmann
In general it works fine. In this specific case there's a few things I'd
have done differently, the syntax is 'relative' close to POV-SDL. I'd
probably prefer something like VPython http://vpython.org/ with an
export to POV-Ray, becaus when working in one language I probably don't
want to bothered by another. For generating POV-Ray SDL from another
language I've been looking at templating systems and I think most what
one needs can be done with them, as after all, it's only text.
Here's yet another one:
http://www.4dsolutions.net/ocn/numeracy0.html
and other pages on the site.
Personaly, I think there are three interesting options:
One is a standalone parser that interfaces with, in my case, Python. It
would suit my current needs, but it lacks interaction, so no "trace"
ability.
Two, the possibility to call, in my case python, scripts from POV-Ray as
a kind of include files. I guess the chanches for the latter to happen
are rather small.
A third and maybe most interesting option, is something like Jython
http://www.jython.org/ . POV-Ray SDL implemented in another programming
language in such a way that it completely interacts with that language
and you can use any library available in the two languages. And
regardless what you use, everything looks like POV-Ray-SDL syntax.
All that, from a non-programmers view,
Ingo
In article <41dade0b$1@news.povray.org>, Darren New <dne### [at] san rr com>
> I disagree that this would be the case for several languages designed
> specifically for this purpose, such as FORTH and Tcl. I'd be interested
> in an example of something that current SDL does that would be severely
> awkward in (say) Tcl.
Uh...what? You disagree that Forth would be more awkward? Your brain
must be inside out. ;-)
I actually considered a similar language (more similar to PostScript,
actually) for driving my own raytracer, but I'd never construct a
complex scene in it directly. I've had enough of that stuff with some
hand coded PostScript logos I did. (I finally decided that C++ was good
enough, considering that it was primarily a testbed for raytracing
algorithms.)
I don't know much about Tcl, but I doubt it would be as convenient as a
special purpose language. Simply having a built-in syntax for specifying
vectors is a huge advantage. A quick web search tells me it's designed
to be easily extended though, so maybe you could modify it to support a
fairly POV-like syntax...
In a general purpose language, you're pretty much restricted to
manipulating the raytracing engine through an API, rather than writing a
scene in a scene description language. For just general scene coding,
this is usually more work. For example, something like:
sphere {< 0, 1, 0>, 1
scale < 1, 0.2, 1>
rotate < 45, 0, 0>
typically turns into something like:
Sphere mySphere(Vect3(0, 1, 0), 1);
mySphere.Scale(Vect3(1, 0.2, 1));
mySphere.Rotate(Vect3(45, 0, 0));
scene.AddShape(mySphere);
It gets worse when you throw things like transformations into the mix.
You end up with either a complex, hard to maintain API, or complex, hard
to write and maintain scene code. An "elegant" way to handle
transformations would be to give objects a single method for applying a
transformation:
mySphere.Transform(Transforms::Rotation(Vect3(45, 0, 0)));
The "convenient" way would be to provide a method for each type of
transformation, with different versions for vectors, scalars, and
triples of vectors:
mySphere.Rotate(45, 0, 0);
Much easier to write and read. But the API now has at least 3 rotation
methods in addition to the general Transform() method. If you add an
axial rotation transform, you need to add at least another method to the
shape classes.
Some languages (including Lisp, I think) allow parts of the language
itself to be modified by programs written in the language...this could
be a very useful feature, since you could build the scene description
language with the base programming language. However, I don't know of
any which would be good candidates for a POV-Ray input language.
Another thing to consider is that most scripting languages aren't
designed for efficiently processing floating point math. The current
POV-Ray SDL is one of the worst at this, but the new one should be good
enough to use as a shader language and to specify functions for
isosurfaces without needing an entirely separate VM.
In article <41d98ce0$1@news.povray.org>,
> What should be thought of is this: There are a lot of good programming
> languages out there: C/C++, Java, Pascal/Delphi, JavaScript, XML,
> Scheme, Prolog, PHP, and so on. Why does POVRay need to have it's very
> own programming language that is compatible to none of the existing
> ones? The only thing that POVRay needs to do is this (simplified):
Simplicity. None of those really cut it.
> So one has to ask: How can I get all that date in a clean and easy way
> from all kinds of different sources to the renderer? What sources might
> that be?
Primarily hand-written scene files. XML is basically useless for that,
those other languages are usually just very awkward, and require
knowledge of a complex programming language. The existing SDL is
limited, but it's also simple. People can do substantial things while
knowing very little about programming.
Then there's maintenance issues...keeping up with updates to the
language, changing the language if the developers take it in a direction
that makes it less useful to POV-Ray, etc. Plus debugging someone else's
code base.
For someone with experience in those languages, learning the POV-Ray SDL
shouldn't be a challenge, but the POV language will be better at what it
needs to do.
> Cool. Where do I have to go to join development team? #4 doesn't seem to
> be under development. Or is it? Couldn't find any info, any invitation,
> anything.
That was probably because you weren't invited. POV 4 isn't even
partially released yet, but that you can't see it doesn't mean there
hasn't been any design or code written. You can write and distribute
modifications as allowed by the license, but you'll have to work with
3.6 for now.
If you say so. Are you quite sure of what you're talking? Some of those
languages are very powerful, especially for large projects.
>>that be?
But they can't do advanced things as easy as they could if there existed
some default front-end for one of those programming lanugages mentioned
above. So there should be an alternative for those who want to do the
more advanced stuff.
> code base.
Programming languages don't change that much. Last change of C++ was in
2001, I guess, and that was just a minor issue. Ok, C++ is complex. You
might consider the use of any other programming language. They are well
defined and if there are substantial changes you might stick to the old
version for a while. You might even use external compilers so the POVRay
team can concentrate on the raytracer.
> needs to do.
It's not learning POVRay SDL but getting complex work done with it. I
can tell you that it is not motivating if you are just experienced
enough to know that the code you are writing will not be maintainable.
>>anything.
> 3.6 for now.
So there would be another POVRay modification. I don't have the time for
this. I would have to redesign half of the program. This is useless
since I would have to spend so much time and in the end noone would use
my version (except me). All the advanced features of the next version
and it's bugfixes would not be in my version. Therefore this is pointless.
Bernd Fuhrmann
Typical example of "extrapolation from one or less examples".
I don't understand what you are talking about.
Look at this stuff
http://www.photon.at/~werner/light/
http://www.photon.at/~werner/light/doc/a00451.html
And also you can try to search the web for other projects I didn't do it
thorougly.
What do you think?
Andrey.
If you say so. No, really. I developed (with my partner) about 10
programs that were more or less complex. So I don't think what and how
you say about my Scheme experience is not really fair. I won't answer
that anymore since it's really pointless.
Bernd Fuhrmann
In article <41dbac8c@news.povray.org>,
Yes, I am quite sure. I have done complex simulations in POV-Ray, it's a
pain in the ass. I have also done scenes coded directly in Java and C++,
that's a bigger pain in the ass than writing the raytracers. As I
mentioned before, simply the lack of a built-in vector syntax makes
things much harder to write and read. My C++ tracer can be made to do
Monte-carlo path tracing by simply coding the materials in a certain
way, but building a scene of any complexity is maddening due to all the
C++ syntax I have to work through.
Pascal, Delphi, JavaScript, and PHP would all have similar problems to
C++ and Java related to the requirement of using an API. A Prolog SDL
would be...very interesting, but probably not very good for general use.
Scheme might make a useful, but idiosyncratic SDL. XML is useless for
hand coding, and no easier for automated programs to write than a custom
SDL would be.
> Some of those languages are very powerful, especially for large projects.
And this shows you completely miss the point. It doesn't matter how
powerful the language is if you must be a programmer to use it. Most POV
users aren't programmers, despite hand coding their scenes in a
Turing-complete programming language.
They can't do them *now*. They could with a improved scene description
language, more easily than they could with a general programming
language.
The POV-Team, and all the people developing patches, will concentrate on
what they want. Much of the time, that is extending the language to be
more powerful for describing scenes. It is not just a minor subsystem
for loading scene data.
In addition, an external language will either lose a great deal of
versatility because it can't tie directly into the tracer, or lose
portability due to having to dynamically load the POV-Ray renderer as a
library. Evaluation of pigments, transformations, and ray intersections
during scene construction are extremely important features. You just
can't do this without adding problems with portability, dependency on
other libraries or utilities, etc. And then you have the issues with
ensuring security from malicious scripts, convincing users that they
have to learn a complex programming language and scene API, etc...
You miss the point again...that can be fixed by improving the SDL,
without losing its advantages...which would be lost by moving to a
general programming language. Ease of learning the language and using it
for things which are simple in terms of programming are far more
important than you seem to realize.
I think this should be obvious, but if nobody finds it useful, it
shouldn't be in the official version.
In article <41db3709$1@news.povray.org>, Darren New <dne### [at] san rr com>
> You can write OO-ness in Tcl, entirely in Tcl. Many of Tcl's control
> structures are written in Tcl. Adding a vector type to Tcl is *trivial*.
After looking at some examples online, I begin to see...it's one of
those "mutable" languages I was talking about.
> Yes. That's called an "extensible" language, and includes Tcl, FORTH,
> and Lisp. Lisp still has the ((())) syntax to deal with, FORTH has the
> postscript, and Tcl has very few drawbacks in this regard. Altho, as you
> mention, Tcl expression syntax can be a little bit ugly, just a tad.
Sounds like we're talking about the same thing, just that I don't know
anything about Tcl.
> Tcl, I'd venture. :)
> Mind, Tcl isn't really good at math as such, but on the other hand since
> math isn't technically built into the language, that would probably be
> pretty easy to improve.
Well, I'll have to put Tcl near the top of my list of alternative
existing languages. However, I'd still prefer a custom one, for the
control over architecture and reduction in dependency, and more clear
responsibility for bugfixes and such. Based in spirit on languages like
Tcl, but not in actual code. Writing a language parser isn't all that
difficult, it's mainly tedious after you get basic expression parsing
done...and once it's done, adding or minor modification is pretty easy.
And, if it's not designed for it from the start, making the VM
high-performance for things like shaders would probably be quite
difficult. Going from dynamic dispatch of an operator method to
performing a VM operation on a numeric primitive type is quite a change.
Something like overlapping it with a far more static language...
In article <cjameshuff-C93C28.15390704012005@news.povray.org>,
cja### [at] earthlink net says...
> stage.
Ah hah... I knew I was right about that. I look forward to a more JIT
type system in 4.0, if they do so.
void main () {
else
In article <41db0035@news.povray.org>, Sil### [at] gmx de says...
Except that the frontend is entirely unneeded if you extend the SDL to
support things properly in the first place. Moray does a decent, but not
complete job of acting as a front end and even solves some problems, in a
general way, like animation that are troublesome with pure SDL. But it
falls short of supporting some basic things, like being able to link a
light source to an object, so they move together, let alone some more
complex things. The more abstraction you put between the core functions
and the user, the more limited you end up making their options and the
more the perception becomes, "That program can't do X". Of course, some
times, like with media for subsurface scattering, the 'correct' solution
can actually have the opposite result, making it so complicated to use
the feature that the abstracted simulation of it might be preferable, but
that is generally a far more rare situation. Any abstraction shouldn't be
in the language someone uses to manually edit things in most cases, but
more like Moray, when the abstraction is to a simpler representation of
what it really being done. XML or other structures can't improve the
ability to see that, it only obfuscates the actual process or nature of
the objects in it even more.
void main () {
else
In article <41dc85a1$1@news.povray.org>, Darren New <dne### [at] san rr com>
> > difficult.
> Errr, well, I'd expect there's be a call that says "Trace." :-) Tcl's
> all in C, and it's designed to call C routines pretty seemlessly. I
> wouldn't think you'd implement the shaders in Tcl, but in C.
C is impractical for other reasons...you'd need a C compiler, obviously.
This is a bigger problem than you'd think. The compiler must exist for
all the platforms POV is likely to run on, and is an obstacle to porting
to new platforms.
Then you need to run this external compiler with the shader code and
link in the result. A C development environment is a bit heavy to
include along with the raytracer, and is likely to be a huge source of
problems on different configurations. Plus there's the security risks of
using such a low level language...you'd pretty much have to disable
programmable shaders for a web-driven application, for example.
Also, with no support for vector/color math or operator overloading, C
shaders would get pretty ugly...though if you can solve the compiler
problem, I suppose you could translate from a customized language into
C, as was done for early C++ and Objective C compilers.
In article <41dcb8a3@news.povray.org>, Darren New <dne### [at] san rr com>
> Um, well, yes. I was under the impression POV-Ray is written in C
> already anyway. Indeed, you'd need a C compiler to extend POV-Ray in C.
> If your implication is that no code written in C can be run on a user's
> machine that doesn't have a C compiler installed... erm... :-)
No. I'm saying you'll need a compiler to run C source code, such as
shaders written in C.
> I suspect Tcl already runs on more platforms than POV-Ray, altho I
> wouldn't guarantee it runs on every platform POV-Ray runs on. I suspect
> Tcl runs on more platforms than you think it does, tho. ;-)
I'm talking about the C compiler you suggested using for shaders. GCC
might suffice, if the license allows bundling it like this, but it would
add several megabytes at minimum to the POV-Ray distribution.
> You'd have to compile it, once per platform. Just like any attribute
> you'd add to the SDL anyway. You wouldn't need to recompile the base
> POV-Ray, tho.
But you would still have to compile the shader. It would probably then
be loaded as a dynamic library by the POV executable, assuming the
interface for doing so is reasonably easy to port. Tcl might have
built-in facilities for doing this portably, but it's the first step
that's hard.
> I don't need a C development environment to run POV-Ray. I don't
> understand what point you're trying to make.
Because it has its own custom language for functions, the closest thing
it currently has to shaders. If you used C for a shader language, you
would need a C development environment.
> Yes. Except that's already built into Tcl. It's called a "safe
> interpreter". Been around for about 15 years now. I work with the guys
> who invented it.
I don't see how that helps the security of the code written in C.
> Well, it's possible I just don't understand what you mean by a "shader".
> However, what I was *trying* to say was, you can extend the SDL with C
> if the extension is compute-intensive, and it wouldn't need to be part
> of the official POV-Ray release, but it wouldn't be an entirely new
> program either - just an extention.
That's essentially what a shader is. A mini-program used to do texturing
and lighting calculations for the renderer. (Sometimes other stuff like
geometry as well.)
They're typically compiled to bytecodes and interpreted. I think the big
packages do let you load C object code or libraries, but you need the
development tools...
> Or you can extend it directly in SDL, if the performance is good enough.
> You could, for example, write Tcl code to import Wings3D files directly.
> If that was too slow, you'd build an ImportWings.DLL (an ImportWings.SO
> and etc) to run faster, and write Tcl code that if the DLL isn't there,
> you fall back to the slower method.
But if Tcl doesn't even have built-in numeric calculations, it would
probably be difficult to add them in a way that gets good enough
performance for shaders.
On Wed, 05 Jan 2005 21:35:34 -0800, Darren New <dne### [at] san rr com> wrote:
> I'm not following. Why would I need to compile it myself, any more than
> I need to compile POV-Ray myself? Why would compiling a shader be harder
> than compiling POV-Ray is today?
I have a feeling that what Christoph is referencing here is that current
functions engine can be compiled into so called machine code without any
external C/CPP compiler. AFAIK all is required is kind of table for
"translating" function virtual machine codes into cpu codes as (IIRC) it is
done for (some of) Macs.
4.5.1.1.2 Fast Functions
http://www.povray.org/documentation/view/3.6.1/747/
ABX
In article <l6spt0lpe76t20v524bkp5naifi490qfka@4ax.com>,
No, that's not what I'm referring to. I do know where the
miscommunication is happening though...see other reply.
On Thu, 06 Jan 2005 06:44:34 -0800, Darren New <dne### [at] san rr com> wrote:
> So why would you need a C compiler to do this? That's what I'm not
> following. Why is it easier to do that on POV-Ray 3.6 than it would be
> to do on POV-Ray 4.0? Why not just do it the same way as already works?
I do not know what was meant in earlier discussion here but I suppose that
build-in compiler is in POV-Ray 3.6 because POV-Ray 3.6 is between POV-Ray 3
and POV-Ray 4. In other words, I think that's imposssible to introduce all the
changes in single release without releasing anything for years.
ABX
In article <41dcce25$1@news.povray.org>, Darren New <dne### [at] san rr com>
wrote:
> I don't need a C compiler to run shaders written in C, any more than I
> need a C compiler to run POV-Ray written in C.
You do, since shaders are almost never distributed as native machine
code.
> I'm not sure why you wouldn't distribute shaders (or whatever you wanted
> efficiently) in the same way you distribute POV-Ray now.
Because shaders are written by the users, not the developers. This is
the point I think you've been missing. Shaders are used when the built
in primitives are too limited or awkward to accomplish a given job.
> This has too many typos and pronouns for me to figure out what you're
> talking about. What's "it"?
"It" is POV-Ray. It supports user-defined functions which are compiled
into opcodes for a virtual machine, and optional further compilation
into native machine code. These functions can be used to define
isosurfaces, patterns, and with a little extra work, pigments. Not quite
a full-blown shader language, but the closest thing POV-Ray currently
has.
> I'm not sure what a shader language is. I'm not suggesting a shader
> language, but rather the use of Tcl as the basis for SDL.
Rather than assembling a material out of predefined patterns, the user
writes a "shader program", a function that computes the resulting color
for the renderer. Tcl is probably quite unsuitable for this, so you
would need a separate language just for shaders and similar
high-performance functions. There isn't any particular reason the entire
SDL couldn't use the same VM. Some capabilities, such as defining
objects, would be "low performance" and would be a bad thing to put in a
shader, but I don't see a definite reason to have separate languages.
> I don't know why you're fixated on C.
Because you suggested it as a high-performance alternative to Tcl, for a
shader language.
> You mean, like Tcl.
Superficially. What I was trying to point out was the difference from C,
in that machine-specific forms are rarely distributed widely. You need a
compiler that supports the platforms, or you need a VM capable of high
performance FP math. That practically means a custom VM,
> Of course it has numeric calculations built in. I just said the syntax
> isn't quite as standard as you might want, nor are numeric expressions
> likely as efficient as a language compiled all the way down to machine code.
I might have misunderstood this, but I took it to mean that math is
implemented on top of mechanisms provided by the VM, rather than built
into the VM. The extra abstraction can be useful, but can really hurt
performance in floating-point heavy stuff like shaders.
In article <41dd6fb2$1@news.povray.org>, Darren New <dne### [at] san rr com>
wrote:
> Let's reset a little bit. I'm talking about whether it would be better
> to base SDL 4.0 on an existing extensible scripting language with
> ray-tracing primitves added, rather than basing it on a whole new
> parser/runtime. (Note: I am not suggesting anything about POV4. Just
> talking. :-)
> In either case, if the primitves are inadequate and you don't have a
> precompiled version of the shader, then you're SOL. So maybe I'm missing
> why shaders even came up in the discussion.
It's a reason why a new parser/runtime could be better than an existing
one, like your suggestion of Tcl.
> > has.
> OK. And surprisingly enough, this implementation doesn't require a C
> development environment. So....
POV doesn't currently use a "standard" programming/scripting language
like Tcl. It uses its own language, and its own VM, designed
specifically for floating point functions. Isosurfaces would render a
lot slower if their functions were written in Tcl. They'd be faster if
they were written in C, but that isn't very practical.
> Actually, I'd expect it to be quite suitable, but relatively slow since
> it is after all byte-compiled. If you wanted it to be fast, you'd either
> do something like POV-Ray does now, or you'd write the shader primitve
> you're interested in in a faster compiled language like C and
> dynamically load it as needed, or you'd write it in Tcl with possibly an
> option to look for the already-compiled code and load that if it's
> available.
We're talking about something that could be a complex function evaluated
for every ray traced, possibly hundreds of times per pixel...thousands
of times with antialiasing. Much more with blurred reflection, media
shaders, and so on, and there's no reason the intersection calculations
themselves couldn't be done in it for custom shapes. "Relatively slow"
is too slow. Interpreted languages are barely suitable but practically
necessary, which is why the POV-Ray function VM has hooks for JIT
compilation. You really need a language optimized for floating point
calculations, preferably with optimizations for colors, points, and
normals.
> The benefit having to do with compiled shaders is the same, regardless
> of what syntax you use for the SDL. Either you support user-defined
> shaders in some custom language, or you support them as C libraries, or
> you don't support them at all, and all three of those are available
> regardless of the syntax of the language.
But once you have a custom language for shaders, why do you need another
language like Tcl for the SDL? You could use one language, one VM for
both purposes. The result is less internal code, and less stuff for
people to learn.
> Well, ask yourself why. It's not like *no* software is widely
> distributed precompiled. If it's easy to dynamically load shaders on
> demand, there's no reason they couldn't be precompiled. Imagine an SDL
> that would do a google search for a precompiled shader for your platform
> if it ran into a Tcl implementation of that shader....
They can't be precompiled because they are written and distributed by
users! You can't expect every user that wants to write shaders for
others to use to have a C development environment with cross-compilers
for every platform someone might want to use it on.
In article <41ddac99@news.povray.org>, Darren New <dne### [at] san rr com>
wrote:
> Translating the description of the shader into specific machine code or
> specific byte codes would be the same amount of work to implement
> regardless of whether you used Tcl or not to invoke the scripts.
Writing and maintaining both a shader language + VM and a Tcl SDL would
be more work than writing and maintaining an SDL that also serves as a
shader language. If you have a decent custom language already in the
project, I see no reason to add another one.
> I expect the way you would use Tcl in this project is to implement
> "sphere" in Tcl to output the appropriate bytecodes for the optimized
> VM. I don't see writing the ray-tracer itself (i.e., the thing that
> follows the rays and calculates pixel colors) in Tcl to be feasible any
> more than doing so in SDL is feasible.
But maybe you don't want a plain sphere. Maybe you want a sphere with
ripples on it. Thus, you need to execute user-defined code, and the
faster the better.
With an improved custom-purpose SDL, replacing most of the raytracer
with user-written code would be slower, but perfectly feasible. You
could even implement your own raytracer, though there would be no reason
I can think of to do so.
> Basically, you'd use Tcl to build the scene, and then your specific VM
> to interpret the stream. Layering, ya know?
But what purpose is there to another layer?
> The language that builds the VM byte stream doesn't have to be
> especially fast. I mean, heck, POV-Ray 3.x (as far as I understand)
> actually reparses the source text to do so. Tcl would be faster because
> after the first time thru the loop, the parsing is byte-compiled.
But not fast enough. Not all VMs are equal. It's byte compiled, so are
POV functions. However, the POV function VM is built for crunching
numbers, and is almost certainly much faster at it than Tcl.
> The "custom language" would be Tcl.
No, the custom language I'm speaking of here is the shader language.
Tcl's too slow for that.
> > You could use one language, one VM for both purposes.
> Well, are you assuming that a VM needs a custom language to write a
> compiler for? That may be the miscommunication.
No, of course not. The "custom language" could be essentially a clone of
Tcl, with floating point and vector optimizations. Then there'd be even
less reason to use standard Tcl.
> You can expect, however, that there is at least one person who has a
> compiler for your platform, or POV-Ray wouldn't be running there. The
> stumbling block isn't that compiled versions don't work for some reason.
Yes, it is! I can't run x86 machine code on my iBook. Without a
compiler, I can't run stuff I just wrote in C. Having someone else
compile stuff for me every time I tweak the code just isn't an option.
> The stumbling block is a lack of distribution facilities where you can
> find it precompiled. If there's a central place holding shaders, there's
> a central place where people could contribute executable versions.
No, it isn't. I can't go download a compiled version of a shader I just
wrote. Again, shaders are written by *users*. They need to be able to
write the code, then run it. It needs to run as fast as feasible.
> Plus, if the shaders are written to compile down to some VM, the VM
> code could be either built into POV or could be distributed along
> with or instead of the source.
That is exactly what is done with many shaders, though it is a bit more
flexible and useful to distribute the source.
> I mean, Tcl has a whole bunch of executable extensions that are written
> and distributed by users. It's really not that hard. :-) And I suspect
> that POV-Ray doesn't run on *so* many platforms that, say, 6 different
> executables wouldn't satisfy >95% of the users using it, and the other
> 5% probably have the development environment anyway.
Requiring people to have a 6-way cross-compiling development environment
in order to write and distribute a reasonably advanced scene is
ridiculous. Alternatively, requiring them to have a development
environment for their own system or know someone who does in order to
render the scene is equally ridiculous. Interpreted languages are
practically necessary for useable shader languages. However, even the
fastest ones are also nearly too slow to be of practical use for that.
"Chris B" <c_b### [at] btconnect com> wrote:
> It is already possible to use VRML to describe a scene (not a POVRay scene).
> VRML has been about since about 1994.
> There is a project working to convert it to an XML base (xVRML) as it was
> originaly based on SGML principles. In fact I think they released an XML
> schema for it way back in 2003.
yes
and the xVRML Project has mad significant strides
since this note was posted...
see: http://www.xvrml.net/
the spec sections for static scene elements are almost completed
and the sections for dynamics come next
an initial tech-demo viewer application is avail through the above URI
> I think there are probably lots of people on the VRML news groups and in the
> xVRML community that are interested in such a system.
I would agree
> I myself took a brief interest in this before discovering POVRay.
interesting the paths we all follow...
I took the opposite route
shifting my energy from PoV to VRML in 1994
and these past couple of years
focusing on developing an XML-based VR language (xVRML)
> put me off VRML (and the concept of using tagged markup languages for scene
> description in general) is the enourmously verbose manner used to describe
> an object.
> As has already been mentioned, POVRays Scene Description Language provides a
> highly elegant and concise yet flexible way to describe objects.
IMHO: PoV and other static-image-oriented systems
have different target domains and audiences than web-based VR
so I think of this as comparing apples and doughnuts
Constructivist approaches in education include
structuring lessons to "build on prior knowledge"
and we are trying to apply that lesson to xVRML
anyone who can understand HTML code
can learn to understand xVRML in a **very** brief time
because it is deliberately structured to take advantage of
existing understanding of HTML and other tag-based markup languages
already held by new content creators
I have been testing this out this Quarter
at the college where I teach...
I am teaching the same "intro to vr" class
which I have taught for five years now...
the students seem to have
about the same base of prior knowledge as always
and are about as smart as always
and yet this term
I switched to using the current (beta) xVRML version
and to using the current (alpha) tech-demo viewer app ("Carina")
and suddenly I have a class going through the material
at literally twice the rate that classes have done
so over the past 5 years
so I feel there is at least preliminary/anecdotal evidence
that this approach is working effectively
> scenes, and even then I've never seen any VRML scenes that come close to the
> sophistication of some of the newbie POVRay scenes posted on the povray
> newsgroups.
but of course...
the PoV newbies are working to create things which
consist of one rendered frame at a time
and which is not necessarily going to be
downloaded off of the web
while VR scene newbies are working to create things which
people can "fly through" at a decent multi-framerate
and which *are* necessarily going to be
accessed over the Web
different targets and domains
IMHO a lot of people who want to generate
photorealistic raytraced stills
and slowly-constructed animations
can also find a lot of interesting things to do
with lightweight 3D VR
rapidly obtained from the Web
and rapidly rendered as a just-in-time
animation under the control of the user
jeffs
> features just because they are "cool" is questionable. In spite of all POV-Ray
> ABX
I completly agree, POV-Ray shouldn't become an advanced programming language
like C++ or Java, but it should offer POV-artists a much more easier way of
making complex and realistic scenes. I think concentrating on that is the
only way of making POV more efficient.
I don't want to have to learn C++ before using POV, because POV is good as
it is now, the only thing i want is an easier way to make my scenes look
good. Making the language more complex isn't going to help anyone who's not
interested in the technological details, but wants to make a nice scene.
POV's got enough handy programming-features that i use to make my work
easier (like macro's, loops and defining variables and objects), they're
not to hard to understand and i'd like to keep it that way.
One could argue that those two things are actually the same thing.
A fully-featured object-oriented language does not automatically mean
that you *must* learn *all* the intrinsic complicated details of the
language in order to create scenes. I have always wondered why so many
people seem to think like it does.
Let me present a comparison, using Windows:
Does a regular user, who just wants to surf the net and read his email,
have to learn how to edit the Windows registry?
The answer is naturally: No.
Is it *bad* that Windows includes the means to edit the registry?
Of course not. Those who want to edit it can do so. Is that bad?
The fact that a feature *exists* does not mean that you *must* even
know about its existence in order to use the program.
If fully object-oriented features are added to the scene description
language, so what? It doesn't necessarily mean that you must learn to
use them in order to create scenes.
You have to realize that there are two kinds of POV-Ray users: Artists
and developers.
The idea with enhancing the language is that developers have better
better tools to create easy-to-use libraries for the artists to use.
Wouldn't you like it if you could just write 'import("scene.3ds")' and
magically the 3ds file is imported and rendered?
If the SDL is enhanced enough and if some developer creates such a
library, then you can do exactly that, ie. import 3D-Studio files with
a one-liner (without even having to know that something called
"object-oriented programming" even exists).
So I more or less completely disagree with you: POV-Ray *needs* and
would greatly benefit from a fully-featured programming language.
Hanki elämä, hanki Linux.
OK, I agree, but what if you have to deal with it once, just once, and you
haven't got a clue what to do, you could seriously damage your system.
So a little knowledge is always easy.
No, I don't know POV-Ray SDL inside-out to, but now, if I have to make
something that isn't done by anyone else, it's at least understandable,
and i don't have to code too large amounts of code for it. You're gonna get
confronted with the ins and outs of the code one day.
> and developers.
If you're gonna make SDL an object-oriented language, you have to be
prepared
to start from scratch, because the current implementation isn't even close
to
that ideal. That means a new syntaxis with classes, structs, ... which
inevitably means relearning the whole deal!
Here's an other objection to extending SDL : security. With more
implementations
on file I/O in the SDL, it would be possible to overwrite crucial
systemfiles
(on Windows, doubtably on Linux), and corrupt the entire system. (thinking
virus or trojan!)
Another thing, what if you do rewrite SDL, and you do, as you say develop
libraries for artists, that means double shifts, wright because you can't
release it before the libraries, or no artist would understand it. (I might
be willing to learn, others won't)
> prepared
> to
There's no reason why the new SDL could not resemble the current one.
Some small changes may be necessary, but it shouldn't be something
unsurmountable. Besides, a compatibility import-mode for old SDL code
is also possible.
> implementations
> systemfiles
> virus or trojan!)
You can already do that with the current SDL (assuming you haven't
configured the file restrictions correctly), so what's the big deal?
You don't need libraries to create the basic scenes you can already
create with the current SDL. Just some small syntactical changes would
need to be learnt.
> systemfiles (on Windows, doubtably on Linux),
Windows has as many, if not more, restrictions on overwriting crucial
system files than Linux does. Linux has only the permission system to
restrict it. Windows has System Recovery to fix it and the backup DLL
directory that automatically fixes it as soon as you change one.
The samba was clearly inspired
by the margarita.
> need to be learnt.
I didn't look at it that way, i must admit. But if you're working with this
syntaxis day in day out, you eventually have to deal with the small anoying
stuff that come along with it. Not everything is premade somewhere, by some
programmer. You're gonna have to be able to write it yourself at some
point.
But if you're willing to learn, i think a new and improved SDL is quite
powerfull, but it just takes some more time to learn.
PS: Sorry for late responses, limited access to internet. :)
HELLO. i am late but i am here.
the idea of an POV-XML, i think is to take control of the scene for
multiples reasons, enginering aplications, etc. Of course the pov syntax
will be the same for every one. Why not think about an universal language
for the 3d world like X3D. I never saw the x3d specification but the
philosophy i think is ok.
When will people understand that XML, and all derivatives, is
*DOCUMENT* oriented ? Not processing oriented !
If you are ready to drop all the algorithms from Pov SDL, then yes,
please go on and go back to DBKTrace 2.12...
It was a time were you had to write in C (or whatever) a code that
would generate the thousands sphere statement needed to make that
nice sea-shell...
I means, no #local, no #declare, not only of scalar, but also of
object, texture, and so!
No loop, no conditional statement...
I'm not even sure about animation...
Also, #include in XML are a PITA to perform, until you have a
portable network architecture for a valued-added repository.
I do not mind about an XML/X3D OUTPUT for povray (once the scene has
been parsed, just add the method to output that to a stream...), but
parsing... No Thanks. And for the output, I hope you have some
Multi-Tera-bytes drives availables.
(Do not talk about "compressed" XML/X3D... if you really want
compressed syntax, let's use the best one: PER-ASN.1, unaligned!
that's one is impressive, opened, but analysis by hand might take
you about two hours for a line once you're an expert of it...)
Last, about Universal 3D... there is no universal 3D usage... and 3D
must be optimised, otherwise the volume of data is far too big.
Can you draw the conclusion by yourself ?
Eifersucht ist die Leidenschaft, die mit Eifer sucht, was Leiden
schafft.
Eco: -8.75 Soc: -6.72
http://www.politicalcompass.org/
It should be no problem to write a xsl transformation that makes
POV-Ray code out of some xml scene description.
