POV-Ray : Newsgroups : povray.advanced-users : Re: What is the frontside of a triangle? Server Time
28 Sep 2024 11:18:06 EDT (-0400)
  Re: What is the frontside of a triangle? (Message 1 to 9 of 9)
Subject: Re: What is the frontside of a triangle?
Date: 8 Jul 2003 12:56:00
Message: <3f0af7a0@news.povray.org>
The problem is how you define the triangle. Normally,
a triangle's corners are given in clockwise-direction
(or counterclockwise). The corners can then just be
fed into a little algorithm calculating the surface-normal,
and thus determine its front- and backside.
Normally, a program will require either clockwise or
counter-clockwise corners. I'm not too sure which approach
POV-Ray takes, but you could just experiment and find
out yourself.
Tim
Tim Nikias v2.0
> Hi,
> can anyone tell me how POV decide what the front or back side
> of a triangle is?
> I can't figure it out, because if you try the following code it changes
> every time.
> If you changes the triangle, then everything changes again.
> #declare TR1 =
> //  triangle {<0.1,0,0>, <0.1,1,0>, <1,1,-1>  // try this also
>   triangle {<0.1,0,0>, <0.1,1,0>, <1,1,1>
>     texture {
>       pigment { rgb <.2, .2, .8> }
>       finish {ambient 1} }
>    interior_texture {
>       pigment { rgb <.8, .8, .2> }
> object { TR1 }
> object { TR1 rotate <0,180,0> }
> object { TR1 rotate <0,180,0> translate <0,1,0> }
> object { TR1 rotate <0,180,0> translate <-1,0,0> }
> object { TR1 translate <0,-1,0> }
> object { TR1 translate <0,-1,0> rotate <0,180,0> }
>              translate <-1,-1,0> rotate <0,180,0> }
> camera { location <0.0, 0.0, -5.0>
>          right x*image_width/image_height
>          look_at   <0.0, 0.0,  0.0> }
Version: 6.0.495 / Virus Database: 294 - Release Date: 30.06.2003
Date: 8 Jul 2003 12:58:43
Message: <estlgv4fv47b0959hobe61tcgql5he8q4a@4ax.com>
On Tue, 8 Jul 2003 18:44:14 +0200, "Jaap Frank" <jjf### [at] xs4allnl> wrote:
> of a triangle is?
The answer is hidden in manual in first sentence of "6.5.2 Finite Patch
Primitives" chapter  :-)
ABX
Date: 8 Jul 2003 13:03:34
Message: <cjameshuff-498B38.12010308072003@netplex.aussie.org>
In article <3f0af44b@news.povray.org>, "Jaap Frank" <jjf### [at] xs4allnl>
> of a triangle is?
It does it by taking the cross product of two sides of the triangle. The
"front" or "outside is determined by the order of the vertices.
"triangle {A, B, C}" faces in the opposite direction of  "triangle {A,
C, B}".
I think the side from which the vertices appear to wind counterclockwise
is the one that is "outside", but you should test it to be sure.
http://tag.povray.org/
Date: 8 Jul 2003 14:29:58
Message: <3f0b0da6@news.povray.org>
"Tim Nikias v2.0" <tim### [at] gmxde> wrote in message
news:3f0af7a0@news.povray.org...
| approach POV-Ray takes, but you could just experiment
| and find out yourself.
This only works in POV-Ray when the triangles are within a mesh
statement. A union of triangles, or a list of triangles as in the
example behaves differently.
 -Shay
Date: 8 Jul 2003 14:53:55
Message: <3f0b1343$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3f0b0da6@news.povray.org...
>  -Shay
I'm afraid this isn't correct for meshes too.
See my conversation with ABX.
The 'inside_vector' by the way, doesn't help to determine
the inside or outside of the triangles for the textures. I think
it's used for CSG only.
Jaap Frank
Date: 8 Jul 2003 15:19:10
Message: <3f0b192e@news.povray.org>
"Jaap Frank" <jjf### [at] xs4allnl> wrote in message
news:3f0b1343$1@news.povray.org...
I'm not making this up.
Cut and paste this code:
camera {location <0,0,-5>  look_at <0,0,0>}
#local P1a = <-2,0,0>;
#local P2a = <0,0,0>;
#local P3a = <-1,1,0>;
#local P1b = P1a+<2,0,0>;
#local P2b = P2a+<2,0,0>;
#local P3b = P3a+<2,0,0>;
#local OuTex = texture{pigment{rgb <1,0,0>}finish{ambient 1}}
#local InTex = texture{pigment{rgb <0,1,0>}finish{ambient 1}}
union { // ignores point order
  triangle {P1a, P2a, P3a}
  triangle {P1b, P3b, P2b}
  texture{OuTex} interior_texture{InTex}
  translate <0,1,0>
mesh { // uses point order
  translate <0,-1,0>
 -Shay
Date: 8 Jul 2003 17:07:37
Message: <3f0b3299$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3f0b192e@news.povray.org...
>   translate <0,-1,0>
I've changed some things.
The union is plane wrong. The order of transformations
give different results too.
But I think something goes wrong with the mesh too.
If the order of the vertices fixes the front side, then
rotation should give the other sides, but this does not happen,
or am I thinking wrong?
// Changed code of Shay:
camera {location <0,0,-8>  look_at <0,0,0>}
#local P1a = <-2,2.5,0>;
#local P2a = <0,2.5,0>;
#local P3a = <-1,3.5,0>;
#local T = <0,4,0>;
   rotate <0,180,0> translate <0,-2,0>
  triangle {P1a-T, P2a-T, P3a-T}
  triangle {P1b-T, P3b-T, P2b-T}
  rotate <0,180,0> translate <0,-1,0>
  translate <0,-2,0> rotate <0,180,0>
Jaap Frank
Date: 8 Jul 2003 17:22:37
Message: <3f0b361d@news.povray.org>
news:3f0b3299$1@news.povray.org...
I looked at your code, and the mesh behaves perfectly. Remember that the
"back" of the red triangle is green and vice-versa. This means that when
you flip the two of them <0,180,0>, you will see an image which looks
the same as before the flip. Try rotating by <180,0,0> (before
subtracting T) and see what I mean.
 -Shay
Date: 8 Jul 2003 17:37:17
Message: <3f0b398d@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3f0b361d@news.povray.org...
>  -Shay
After rotating my mind with <0,180,0> I see that you are right.
Now I've to figure out what's going on in my mesh.
Thanks,
Jaap Frank
