POV-Ray : Newsgroups : povray.advanced-users : Waterdrops on Glass... How? Server Time
11 Apr 2026 07:05:58 EDT (-0400)
  Waterdrops on Glass... How? (Message 1 to 10 of 34)
Subject: Waterdrops on Glass... How?
Date: 8 Jan 2003 14:24:59
Message: <3e1c7b0b@news.povray.org>
Hello all!
I've been working on my "Worldbowl" image again,
and am trying to update it with my most recent macros,
making things look better and more detailed, in order to
achieve a very pleasing and realistic image which I might
put on Zazzle. In my oppinion, its one of my images which
actually have the option to be made something very
special...
Well, to get to the point, I have come to the conclusion that
some nice raindrops on the window would look very nice
and add some tiny detail to the otherwise boring outside
view.
Right now, I'm just placing blob-components (more or less
random, I'm working on that part), but the main problem I have
is the refraction due to the water. Normally, Water has an ior
or 1.33 and glass one of 1.45 or so. In order to get rid of the
coincident surface problem, I'm just clipping the blob with a box.
This leaves an open shell on the glass surface.
I'm one of those ulra-realistic guys, so I'd like to know either
how I can either calculate an ior for the water to simulate the
refraction taking place between water and glass surfaces.
In this case, its not a big problem, I could just play with different
ior settings for the water till I get a look I like.
But let's not take a glass window, but one for drinking. In that case,
an "open shell" water would be a disc in the glass to simulate the
water surface. But I want to simulate the correct refraction taking place
when the viewing rays passes through the glass into the water.
Sounds pretty complicated and I'm not too sure if I make myself
clear. The other way round:
Most of the time, us POVers leave a little gap between two transparent
surfaces in order to avoid coincident surfaces. But when refracting rays,
the effect taking place is different as opposed to two surfaces touching
each other.
Any ideas?
Thanks in advance,
Tim
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Waterdrops on Glass... How?
Date: 13 Jan 2003 19:16:31
Message: <3e2356df$1@news.povray.org>
Hm. Seems like I'm not raising much attention with this question,
eh?
Tim Nikias
Date: 13 Jan 2003 19:42:29
Message: <3e235cf5@news.povray.org>
3e2356df$1@news.povray.org...
> eh?
Can't help, I've had this little problem for years and I was never able to
solve it properly. Nothing I tried seemed to work as it should.  See :
http://www.oyonale.com/ldc/images/abeillesdetail2.jpg
The main issue, though, is less the surface problem than the distribution of
the droplets themselves. Ideally, their position should be the product of a
dynamic process, so that simple random positionning always seems wrong.
Perhaps Rune's particle system could help, I don't know. Blobs doesn't
behave like real water either, which is another problem.
G.
- Graphic experiments
- Posters
Date: 13 Jan 2003 19:47:12
Message: <cjameshuff-A31848.19470813012003@netplex.aussie.org>
In article <3e1c7b0b@news.povray.org>, "Tim Nikias" <tim### [at] gmxde>
> each other.
Overlap them a bit. POV does things so that refraction is handled
correctly in this case. The gap method simulates an air gap.
Designing the textures properly also helps. I usually use perfectly
transparent textures and use interior attenuation or media to provide
any coloration.
http://tag.povray.org/
Date: 14 Jan 2003 01:10:51
Message: <3e23a9eb@news.povray.org>
> Any ideas?
Hi Tim!
Maybe, you can tinker with clipped_by, to clip the surface of the drop which
would contact the window. I don't know wether the ray remembers the ior of
the object it currently is in or not. But if it's so, the ray would go from
1.33 straight into 1.45. which should be right...
Hope could help
Kalle
Date: 14 Jan 2003 03:19:05
Message: <3uh72v0viblg0mea8cq2o0qhrhrh3v12kl@4ax.com>
Hey Kalle, that's *extremely* neat - did you try it? It does sound
plausible...
Peter Popov ICQ : 15002700
Date: 14 Jan 2003 06:49:00
Message: <3e23f92c$1@news.povray.org>
That's what I'm currently doing, but I'm not sure
if it works as we think it does. As far as I understand
the raytracing technique, POV will stay with ior 1.45 from
the glass until it hits the surface of the water, and gets
refracted the way it should when exiting a 1.33 ior to
1.00 ior (water to air). But I'm not too sure about that,
and also no quiet sure how I should test that...
Tim Nikias
which
of
from
> plausible...
Date: 14 Jan 2003 06:52:13
Message: <3e23f9ed$1@news.povray.org>
It "does things"? What does it do? Just curious.
Though doing that with blobs is still kinda difficult...
Instead of clipping, I'd have to difference it away
position it slightly inside the window... Pretty tracing
intensive, hu? I'll try and look what happens. Thanks
for the suggestion though,
Tim
Tim Nikias
rays,
> > each other.
> any coloration.
Date: 14 Jan 2003 07:22:57
Message: <3e240121$1@news.povray.org>
You're definitely right about placing the droplets.
I've written a small include, which scatters droplets
randomly across an area (the whole thing was designed
so far only for windows), and also creates "trails":
At one spot, it starts, and moves downward (a little
randomly moving towards right or left), and leaves
very small droplets on the way, and at the end, a big droplet.
Just like those drops that get big enough to flow down.
I've uploaded a zoomed-version on the window,
http://www.digitaltwilight.de/no_lights/rain_1.jpg
Its 100kb, but shows how the results look so far. I'm
fiddling a bit with size and numbers to see if I can
get something near-realistic with this method.
I guess Rune's Particle System won't be of use, cause
it doesn't have particle-particle-interaction, and that
would be what droplets on windows are screaming for.
Perhaps I'll try to create an include file for windows, but
doing it with curved survaces and other objects... Way
too difficult. Got to have a running particle-system to do
that...
But near-realistic isn't too bad. Its all about the looks.
How did you place those droplets of yours? Using trace?
Though some look like the gravitational-pull is actually
affecting the droplet. How'd you do that?
Tim
Tim Nikias
of
a
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 14 Jan 2003 07:35:42
Message: <3e24041e@news.povray.org>
Using google this came up when looking for
"water droplets simulation":
http://www.cs.unc.edu/~lin/COMP259/LEC/29b.ppt
Its pretty interesting and perhaps, when I get the time to
understand it, I'll implement it. Could be useful, at least
for meshes (and windows can easily be done with
meshes).
Tim Nikias
