POV-Ray : Newsgroups : povray.advanced-users : Constrained motion Server Time
22 Nov 2026 22:47:08 EST (-0500)
  Constrained motion (Message 1 to 11 of 11)
Subject: Constrained motion
Date: 1 Oct 2002 09:51:48
Message: <3d99a874@news.povray.org>
Suppose an object is acted on be several forces at once. The resultant force
is represented by the vector V. Suppose, say, V = <5, -7, 9> So, we can
divide this by the mass of the object and thus discover it's acceleration.
But... suppose the object is contrained to the X-Y plane. (And let's suppose
that whatever mechanism "constrains" it has no friction - impossible but
simpler to compute ;-) What do we do now? Do we just write V = <5, -7, 0>
and continue as usual? Or does something more ellaborate need to be done?
(I'm not worried about the orientation of the object - it's a sphere. And
this sphere is not in any way deformable, so there's no extra complications
there ;-)
Sorry to keep pestering!
Thanks.
Andrew.
Subject: Re: Constrained motion
Date: 1 Oct 2002 10:14:05
Message: <3D99ADA8.6722C2B9@gmx.de>
There are mainly two possibilities to achieve this:
1) use coordinates that completely and uniquely describe the motion of the
object and at the same time do not violate the constraints.  In this case
it would mean calculating the whole thing in 2d in the x-y-plane.
2) introducing additional forces to make the object fit the constraints
(commonly known as penalty methods) This is quite easy, also for
complicated constraints but if you want the objects to fit the constraints
very precisely the integration of the equations of movement will be quite
difficult (small stepsize required).
Date: 1 Oct 2002 10:29:10
Message: <chrishuff-1ADA6D.10262801102002@netplex.aussie.org>
In article <3d99a874@news.povray.org>,
The component of force perpendicular to the plane can be ignored. If you
have a perfect horizontal plane and the only force on a ball sitting on
it is gravity, the ball won't move, and if there is no friction, the
gravity won't affect the force required to move it in any direction
parallel to the plane.
http://tag.povray.org/
Date: 1 Oct 2002 10:42:39
Message: <3d99b45f@news.povray.org>
Thanks guys. It seems it's as I thought... at least, if we're talking about
being constrained to a plane.
Now... what happens if my moving particle is contraigned to a sphere? In
other words, there is a mass-less inextensible "string" teathering it to a
fixed point in space. (The force will always be acting in such a way that
the "string" remains taut - there is no possibility of it 'going slack',
which makes things a bit easier.)
If an unconstrained object were acted upon by a resultant force F, it would
accelerate in a path along F. So do I just need to find the nearest curved
path along the sphere? (And gosh, how the hell am I gonna do that? ;-)
Just thought I'd try making my Chaos Pendulum into an actual "penulum" - the
flat view I did was a deliberate simplification.
Thanks.
Andrew.
Date: 2 Oct 2002 12:37:00
Message: <3d9b20ac@news.povray.org>
If the string remains taut the part of the force that is colinear with the
string will get compensated. In other words the particle will always move
in the plane perpendicular to the string! This means that all you have to
do is to project your force into this plane.
Given n the unit vector which is colinear with the string and f the vector
of your force, the projection f' of f into the plane is given by:
 f' = f - n*vdot(n,f)
An example: is the string along the y-axe then the normal vector is <0,1,0>
and therefore:
 f' = f - <0,1,0>*vdot(<0,1,0>,f)
Now vdot(<0,1,0>,f) is equal to f.y and hence:
 f' = f - <0,f.y,0> = <f.x, 0, f.z>
You could also check if the string remains taut by looking if vdot(n,f) is
negative or positive (you have to fix the direction of n (that means choose
if it points from from string base to particle or the other way round).
Hope I got this right
- Micha
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Date: 2 Oct 2002 20:24:48
Message: <chrishuff-80994A.20214202102002@netplex.aussie.org>
In article <3d9b20ac@news.povray.org>, Micha Riser <mri### [at] gmxnet>
Not quite...if you move it along a straight line in the direction of
force, the "string" will get longer and longer with time. You need to
move it along a curved path:
strLen is the "string" length.
strOrig is the pivot point, the non-moving end of the string.
1: Figure out the force as you said.
2: Compute the distance (partDist) and direction (partDir) the particle
would move for this time step without any restrictions.
3a: The particle moves the same distance along the surface of a sphere
with radius == the string length. Compute the angle (angDist) of an arc
segment with a length == partDist and a radius == strLen. This is the
angle between the start and end positions from the string origin.
3b: Find a vector perpendicular to the plane of the string and the
particle direction vector (rotAxis): vcross(partPos - strOrig, partDir)
4: Rotate the particle around strOrig by angDist around the axis
rotAxis. Use vaxis_rotate() or the Axis_Rotate_Trans() macro.
Date: 3 Oct 2002 05:24:57
Message: <3d9c0ce9@news.povray.org>
Late last night I figured out the part that Micha said by myself...
(Typical! You ask for help then figure it out yourself anyway... lol) But
it's more complicated than that...
Will have a go and see where I get to...
Thanks folks!
Andrew.
Date: 4 Oct 2002 08:24:00
Message: <3d9d8860@news.povray.org>
>> the string will get compensated. In other words the particle will always
>> move in the plane perpendicular to the string! This means that all you
>> have to do is to project your force into this plane.
Yes, I did not think at this. While the force and also the velocity is
always perpendicular to the string, you need to correct the error made by
the Euler method.
I have digged out my sliding macro and adapted it to run with POV-Ray 3.5.
You can find the source and some examples in p.b.s-f. There I use trace to
place the slider on the surface again after it has moved. You could use a
similar thing in your case: trace against the imaginary sphere that limits
the orbit of the particle.
I have made a pendulum animation (see p.b.animation) with exactly this way.
The friction force is still as if it would move on the sphere... so it is
probably not realistic in that respect.
- Micha
Date: 4 Oct 2002 14:03:06
Message: <chrishuff-28CAF8.13594604102002@netplex.aussie.org>
In article <3d9d8860@news.povray.org>, Micha Riser <mri### [at] gmxnet>
Well, you could also have normalized the point and multiplied it by the
length of the string, with the same effect and no need for tracing
against a sphere.
The problem with these methods is that the particle doesn't travel as
far when projected onto the sphere like this, so it will constantly be
slowing down. Computing the angle it would travel if it went the same
distance along the sphere surface and rotating by that amount avoids
this, and you are left with mainly precision errors to worry about.
(though the step size still matters for shifts in direction)
Date: 4 Oct 2002 14:15:33
Message: <3d9ddac5@news.povray.org>
> against a sphere.
Yes, but my macro allows sliding on arbitrary surfaces, so it needed some
general approach.
I just scale the velocity after projecting into the surface so that the
velocity remains the same (if there were no friction).
Date: 4 Oct 2002 14:48:23
Message: <3d9de277@news.povray.org>
OK peeps, just trying to pull my thoughts together here... I'm going to sum
up which (I think!) has been said so far, as I understand it, so folks can
tell me if I've got it right!
Motion constrained to the X-Y plane:
  * Compute the resultant force acting on the particle as normal.
  * Set the Z-part to zero.
  * Compute motion as normal.
Motion constrained to a sphere:
  * Compute resultant force.
  * Constrain the force to a plane perpendicular to the string tethering the
particle.
  * Work out how far the particle has moved.
  * Rotate the particle from it's initial position so that it moves the same
amount.
About that last step... I know how to work out the distance the particle has
moved... How do I work out how far to rotate? Angle = distance / radius or
something?
Andrew.
