![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
What are the hard limits on the isosurface object?
How does the code scales wrt expression complexity?
what is the hard limit on the function in terms of operations and what are
practical limits?
Is it feasible to have a function of the form:
s(x) = p(x) + SUM{lambda * phi(|x - xi|), i=0..N}
where x and xi are vectors, with N very large (circa 100000)?
Alex
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> practical limits?
In short: RTFM.
Practical limits: Your computer's memory and your patience.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Fri, 30 Aug 2002 18:08:47 +0200, Christoph Hormann <chr### [at] gmx de>
And your computer's cooler ;-)
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <web.3d6f93d0dbb361415e7f0160@news.povray.org>,
What hard limits do you mean? Isosurface limitations are mainly the same
as for other objects, though they may be more vulernable to precision
problems.
> practical limits?
The documentation lists all these limits. Did you even bother to try
looking it up?
Functions can't handle vectors. You might be able to do this at least
partially with functions, it depends on how it is done and what you are
trying to accomplish.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Actually there was a limit on how many operands you can have in a function.
I don't remember now how much it was.
Also the amount of funtions in total was limited.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But that's only a soft limit. You could get around it by splitting your
function into several bits and pre-declaring them, then declaring your
main function in terms of those bits. And if that's not enough you can
split the bits into smaller bits.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Christopher James Huff wrote:
>In article <web.3d6f93d0dbb361415e7f0160[at]news.povray.org>,
>problems.
>> practical limits?
>looking it up?
>http://home.earthlink.net/~cjameshuff/
My bad, I was on a karma-burning streak yesterday.
Apologies to all involved.
I did bother to look it up, after you pointed your finger to it.
That answered my ques nicely.
Alex
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
