POV-Ray : Newsgroups : povray.advanced-users : How to calculate Banking of Bezier-Splines...? Server Time
23 Jun 2026 04:45:16 EDT (-0400)
  How to calculate Banking of Bezier-Splines...? (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: How to calculate Banking of Bezier-Splines...?
Date: 23 Feb 2002 07:24:04
Message: <3C7789EC.8C504189@gmx.de>
The problem is, I don't need the tangent (I was able
to figure that out, still, thanks for the reply). I need
to find the centrifugal-force, and I don't know if
tangents actually help me there...
Tim Nikias
Date: 23 Feb 2002 07:40:05
Message: <3c778da5@news.povray.org>
"Tim Nikias" wrote:
> Bezier-Splines stay longer on the beginnings and
> ends of a curve
I'm not sure what you mean by "stay longer".
> and when using very small values for the difference
> between the Ts, the three positions may line up,
> resulting in weird centrifuges.
I don't understand. If the three points line up it's either because there's
no centrifugal force at that point or because you're using so small
differences in T values that POV-Ray don't give you precise enough results.
Can't you just use larger differences in T values?
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 23 Feb 2002 09:34:39
Message: <3C77A883.A442B0E3@gmx.de>
If you place spheres on a bezier-spline (just an example),
they will clutter up on beginnings and ending of a section.
Each section is defined by the already mentioned 2 Nodes
and their 2 directions. When using tiny T amounts, the
calculated positions may be very close to each other,
resulting in no centrifugal force.
It's like looking at a millimeter of a 100 meter curve...
In general, a section has some sort of curvature, and I would
like to use some general sort of the centrifugal force.
Its not very easy to explain...
Tim Nikias
Date: 23 Feb 2002 10:26:00
Message: <3c77b488@news.povray.org>
"Tim Nikias" wrote:
> If you place spheres on a bezier-spline (just anexample),
That really depends on the lengths of the tangents (the two direction
vectors). The way I usually use bezier splines, the spheres are not
cluttered up around the ends. And thinking about it, when they *do* clutter
up around the ends due to short tangents, it's actually because the
curvature is higher near the ends... The curved parts usually have denser
spheres in general.
As I said, why not use bigger differences in T values?
See above.
Hmm, apparently not... :(
Rune
Date: 23 Feb 2002 10:52:38
Message: <chrishuff-5AD572.10522923022002@netplex.aussie.org>
In article <3C7789EC.8C504189@gmx.de>, Tim Nikias <tim### [at] gmxde>
Find the tangent at the point, and the tangent a little distance ahead.
The amount of force will be related to the angle between these tangents
(normalize them, and the dot product will be the cosine of the angle)
and the distance between the two points on the spline.
Find the angle first, if it is too small just don't bother with the
force calculations.
A vector perpendicular to the direction of the force can be found by
taking the cross product of the two tangents. You can then find the
direction of force by getting the cross product of this vector with the
first tangent.
Date: 23 Feb 2002 16:59:34
Message: <3C7810D0.3D0DECEF@gmx.de>
Very elaborate, thank you!
I don't want to calculate the actual force, but only the
centrifugal-vector. When thinking about your advice
with the cross-products etc, I'm wondering, if
I can be 100% sure, that the resulting vector
will be the centrifuge, or perhaps may be the
inverse (which would also be perpendicular)?
I'll try. Thanks for your help!
Tim Nikias
Date: 23 Feb 2002 17:01:45
Message: <3C781153.ACCF0564@gmx.de>
Christopher Hames Huff has replied and given me
some mathematical insight with cross-products
and dot-products. I'll guess going from there, I'll
find a solution to what I am heading for. Your
replies are still thanked for. Its worth noting that
you actually spend time on others problems...
Thank you very much!
Tim Nikias
Date: 23 Feb 2002 18:51:30
Message: <3c782b02@news.povray.org>
I didn't know that was your problem. :)
It's worth noting that the solution I suggested still is valid. Chris Huff
suggested a method involving angles and checking the spline at four
different places (in order to get two tangents), while my method doesn't
involve angles (or dot products) and needs only the spline tested at three
places.
But you basically get the same thing. It sounds like your problem was that
you wanted the centrifugal force vector calculated to be perpendicular to
the tangent of the spline at that point. Using my own example as basis this
is very easy as you already have the tangent, which is (B-A). Now you just
need to adjust the vector (P-C) so that it's perpendicular to the vector
(B-A). POV-Ray 3.5 has a macro to do that, called VPerp_Adjust. The
VPerp_Adjust macro do automatically the things with vcross that Chris Huff
talked about. You can read about the macro in the documentation.
Rune
Date: 23 Feb 2002 22:09:46
Message: <chrishuff-12FCA8.22093623022002@netplex.aussie.org>
In article <3c782b02@news.povray.org>,
> places.
Actually, my method only needs 3 points tested...I was just trying to
simplify my explanation when I said 2 tangents. It would probably work
better with 4 though, less opportunity for precision error. The basic
idea is to look ahead to two points to estimate the direction and amount
of curvature of the spline, find the normal of the plane the spline is
in at that point (the three points form a triangle), and get a vector
perpendicular to that, which will be perpendicular to the spline and in
the "outward" direction of curvature.
I have a sneaking suspicion our two solutions are mathematically the
same, just arrived at differently...
VPerp_Adjust() is defined as:
vnormalize(vcross(vcross(Axis, V), Axis))
Which is basically what I wrote. Ah, well...
Date: 24 Feb 2002 05:18:44
Message: <3c78be04@news.povray.org>
"Christopher James Huff" wrote:
> The basic idea is to look ahead to two points to
> estimate the direction and amount of curvature of
> the spline
I think it's better if the point in question is the middle one of the three
points rather than the back one.
> mathematically the same, just arrived at differently...
The same, or very close.
My point exactly. I use that macro a lot by the way - it's really useful. :)
Rune
