POV-Ray : Newsgroups : povray.advanced-users : Photons and Normals Server Time
29 Jul 2024 18:29:52 EDT (-0400)
  Photons and Normals (Message 1 to 8 of 8)
Subject: Photons and Normals
Date: 27 Oct 2001 12:56:53
Message: <MPG.1645065181f49d3b9896a5@news.povray.org>
Hi everybody,
I have the problem that photons are nearly invisible on surfaces with
normals. It may be a bug, maybe it is realistic, but it is very annoying,
because surfaces without normals usually don't look good (unless they are
Isos with much "true" detail, but I didn't test yet if those work better
with photons).
Does anybody know a way around this problem? (an bright, small spotlight
aimed at the reflecting/refracting object might do the trick in some
cases, but it has the disadvantage that every additional lightsource
slows down glass-like objects significantly)
Lutz-Peter
Subject: Re: Photons and Normals
Date: 27 Oct 2001 13:16:35
Message: <3BDAEBED.CA07490B@gmx.de>
Lutz-Peter Hooge wrote:
> Hi everybody,
> with photons).
I experienced the same, see for example the balcony demo scene in Povray
3.5.  If you remove the normal of the cloth, the caustics on the table are
much stronger.
I'm not sure if this should be considered as a bug, a test with normals
and heightfield/isosurface alternative would clarify things.
Date: 27 Oct 2001 14:07:28
Message: <3BDAF7DB.20FED1F5@pacbell.net>
> > Hi everybody,
> > with photons).
> much stronger.
I wouldn't necessarily classify this as a bug. It is more a limitation
with the implementation of the normal perturbation method that POV-Ray
uses.
Ken Tyler
Date: 27 Oct 2001 14:50:45
Message: <MPG.1645210baa7a8ee99896a6@news.povray.org>
In article <3BDAF7DB.20FED1F5@pacbell.net>, tyl### [at] pacbellnet says...
> uses.
Are you sure?
I just testet it now with an Isosurface and a heightfield (without a
normal map of course).
The results are the same as with a normal.
However, this is not realistic. I tried it with a glass of water and
placed different objects in the caustics. Leather, paper, and cloth.
In all cases the caustics remained very visible, they relative brightness
to the rest of the object didn't chage significantly.
Lutz-Peter
Date: 27 Oct 2001 15:16:57
Message: <MPG.16452732cbcf31ad9896a8@news.povray.org>
In article <MPG.1645210baa7a8ee99896a6@news.povray.org>, lpv### [at] gmxde
says...
I postet the test to the images.binaries group. subject "photons & rough
surfaces"
Date: 28 Oct 2001 05:02:20
Message: <3BDBD7AC.F4436542@gmx.de>
I agree and although i don't know what the reason is, there really seems
to be something going quite wrong.  Seem my post in p.b.i.
Date: 28 Oct 2001 06:02:28
Message: <3BDBE5CA.5255E47A@engineer.com>
The edge problems disappear when more photons are used but
the shading on the sphere is not right. Problem in normal
scaling?
_____________
Kari Kivisalo
Date: 28 Oct 2001 06:31:06
Message: <3BDBEC7A.E7EDF9D@gmx.de>
> scaling?
To me it seems to have something to do with the surface curvature, even
with more photons, the edges of the box stay dark (although the dark parts
are thinner)  Of course this could be the side effect of something totally
different.
