How does povray rotate around the x-axis?
This way:
<0,1,0>*< 1, 0, 0,
0, C, S,
0, -S, C>
Or this way:
< 1, 0, 0, *< 0
0, C, S, 1
0, -S, C> 0>
Of course I cutted out the fourth row.
Thanks in advance,
Remco Poelstra
Remco Poelstra wrote:
> Hi,
> This way:
> <0,1,0>*< 1, 0, 0,
> 0, C, S,
> 0, -S, C>
> Or this way:
> < 1, 0, 0, *< 0
> 0, C, S, 1
> 0, -S, C> 0>
Deciding from matrices.c POVRay multiplies vector row with matrix. But
why is it important?
Subject: Re: rotating around x-axis inside povray
Date: 26 Feb 2001 15:32:30
Message: <3A9ABDC9.70904@home.nl>
Because I'm writing a program that does some matrix calculations and
outputs to povray.
Now I was wondering how the matrices on
http://enphilistor.users4.50megs.com/matrix.htm
are constructed. I redesigned them by hand, and came out by the same
matrices, except that I use the second method to multiply. ie, the
vector as a column, not a row.
Remco Poelstra
It's the difference between multiplying the vector to the right or left. I
believe a 1by4 vector is multiplied to the right by the 4 by 4 matrix in
POV-Ray
Josh
> outputs to povray.
> Remco Poelstra
eng### [at] spiritone com
"He who hebetates is last."
> outputs to povray.
If 3x3 matrix (i.e. without transformations) is used then matrix is
same, regardless of multiplying vector row with matrix (i.e. vectors are
seen as rows) or matrix with vector column (vectors are seen as
columns). Difference comes, when You use 4x4 matrix, then matrix is
different (translation is either in last row or column).
Duh, it should be------------> translations
> > outputs to povray.
Actually, they don't. If v = <a,b,c> and M is a 3x3 matrix, multiplying the
row vector on the left gives you a different answer than multiplying the
column vector on the right.
v = <a,b,c>
M = d e f
g h i
j k l
vM = <ad+bg+dj, ae+bh+ak, af+bi+cl>
Mv = <ad+be+cf, ag+bh+ci, aj+bk+bl>
If you switch the order of the vector and the matrix, you have to transpose
the matrix
> [Something very false]
Duh, of course, You're right :-( Next time I'll think more carefully,
what I write.
I'll not post false facts to usenet.
[98 x more]
> [98 x more]
Not bad, but this is not usenet - better try it again and this time add
"... or private news servers"
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
Home page http://www.hot.ee/margusrt
"Margus Ramst" <mar### [at] peak edu ee> wrote in message
news:3A9C044A.51FD6E87@peak.edu.ee...
> > [98 x more]
#declare N = 1;
#while(N<=100)
#debug "I'll not post false facts to news.povray.org\n" #declare N = N +
1;
