POV-Ray : Newsgroups : povray.advanced-users : max_intersections problem Server Time
29 Jul 2024 22:22:18 EDT (-0400)
  max_intersections problem (Message 1 to 4 of 4)
Subject: max_intersections problem
Date: 8 Feb 2001 13:01:28
Message: <3A82DEF8.8D3F50A6@gmx.de>
I'm working on my IRTC entry and am continuously getting I-Stack overflows
although i'm already using max_intersections above 1000.
1) Are there other things apart from intersection/difference affecting
this and what are the CSG constructions needing a high max_intersections -
intersections containing a lot of objects or highly nested CSG?
2) How does increasing max_intersections influence the rendering speed in
general, anyone any experience concerning that?
Subject: Re: max_intersections problem
Date: 10 Feb 2001 18:44:57
Message: <3a85d279@news.povray.org>
If its any help - I had a problem using around 6000 spheres to make a
rounded (welded) inside corner on a curve. Using merge{} instead of
union{} and playing with max_trace_level and
max_intersections in global settings eventualy helped.
Except in glass objects with that obstinate couple of black pixels, I
can't see much change increasing m_t_l above around 30. Sorry, but I
don't remember what m_i did to speed.
I used DOS versions of pov3.1g and mp0.6 and the stats output gave
useful help about progress.
Alf
news:3A82DEF8.8D3F50A6@gmx.de...
overflows
affecting
max_intersections -
speed in
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 12 Feb 2001 07:15:30
Message: <3a87d3e2@news.povray.org>
Alf Peake <alf### [at] peake42freeservecouk> wrote:
: I had a problem using around 6000 spheres to make a
: rounded (welded) inside corner on a curve.
  Unrelated to the thread, but...
  When you need that huge amount of spheres to make something that's usually
an indication that using (only) spheres is not the best solution.
  Usually when making curved pipes or whatever, one of the best solutions is
to use cylinders to connect the points and spheres (with equal radius) at
the connection points.
  There are, of course, other solutions as well.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 12 Feb 2001 09:24:48
Message: <3A87F230.54E25C88@gmx.de>
Thanks, although it does not help much in this case.  I now use
max_intersections 2000 and it works while not being recognizable slower.
It would of course be nice to have something like 'eval' for
max_intersections meaning to have a high limit and testing how much of it
is used.
