POV-Ray : Newsgroups : povray.advanced-users : Lizard skins or condensation droplets patterns Server Time
28 Mar 2026 11:24:43 EDT (-0400)
  Lizard skins or condensation droplets patterns (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Lizard skins or condensation droplets patterns
Date: 8 Sep 2000 12:17:23
Message: <39B91112.2C0FBB2A@spiritone.com>
Oh wow. You and Rune are truly pigment masters.
Josh
Gilles Tran wrote:
> Josh English wrote:
> > Bozo and Crackle? how about something like this, which I adapted from
> > Rune's incredible pigment:
> Interesting... Not exactly what I'm looking for but this could be useful.
> Here is another version  (try the different patterns) :
> #version 3.1
> #include "colors.inc"
> global_settings{  assumed_gamma 1.0}
> camera{ location  <0.0, 0.5, -4.0>  direction 1.5*z  right     4/3*x
> look_at   <0.0, 0.0,  0.0>}
> light_source{  0*x   color red 1.0  green 1.0  blue 1.0    translate <-30,
> 30, -30>}
> #declare MyPigment =
>    pigment {
>       granite scale 5
> //      bozo scale 1
> //      wrinkles scale 1.2
> //      agate scale 2
> //      crackle scale 1.2
> //      dents scale 1.5
> //      wood triangle_wave rotate <60,40,0> scale 2
>       pigment_map {
>          #declare X = 0;
>          #declare Y = 255;
>          #declare rd=seed(0);
>          #while (X<Y)
>             #declare V = X/Y;
>             [V,
>                crackle scale (0.3*V+0.2)*0.4 // rotate 30*z
>                color_map {
>                   [0, color rgb Black]
>                   [1, color rgb <rand(rd),1,rand(rd)+0.5>*1.5]
>             #declare X = X+1;
>          #end
>       scale 0.4
> sphere { 0.0, 1 texture {pigment{MyPigment}  finish{specular 0.5 roughness
> 0.001}} }
> plane{z,0 texture {pigment{MyPigment}  finish{specular 0.5 roughness 0.001}}
eng### [at] spiritonecom
Date: 8 Sep 2000 13:07:46
Message: <39b91ce2@news.povray.org>
Hi Gilles the only things I can think of that might help are blackhole warps
and perhaps as a last resort image maps!
Mick
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:39B7C8C8.3D5EB9D4@inapg.inra.fr...
> I've been wondering about how to make these, either as a pigment
> pattern, or at least as a function enabling to position and scale
> objects. Basically, it looks like crackle, but with zones of increasing
> or decreasing cell sizes. I've made  experiments using a blob density
> function that attracts/repels the elements (spheres) according to their
> proximity to centres. The size (radius) of each object is afterwards
> calculated as the minimum distance from its 8 neighbours (it's in 2D).
> It works, but it's very difficult to control to obtain a desired effect
> (like a pinching or bulging at a particular place). Anyone would have
> pointers to algorithms, or ideas ???
> G.
Date: 8 Sep 2000 13:18:12
Message: <39B91EC9.344FF226@inapg.inra.fr>
No, no, I just took your code and replaced the color_map shift by scaling,
something I had done before, but much more clumsily. Other transformations could
be interesting and I'm sure other people have been there.
But the results are pleasantly weird.
G.
Date: 8 Sep 2000 13:36:45
Message: <39B92322.421E2745@inapg.inra.fr>
To be more precise, I'd like to find a way to position droplets of water on a
surface. From real-life observation, condensation droplets are not positionned
at random, but follow a pattern that looks like reptilian scales. So I thought
that the solution could be in a "reptilian scale" pattern algorithm, something
like a voronoi diagram but with some weight added to some of the points. My
investigations so far are good enough for my current projet, but I'd like a
better and more general solution.
For a texture, though, black holes are something worth investigating.
G.
Date: 11 Sep 2000 13:02:50
Message: <39bd103a@news.povray.org>
I wrote a simple scene for waterdrops..
placing every single drop makes it quite memoryextensive
I think you should be able to tweek the txture of the drops to
your needs,
I'm not such a master in texturing like you are ...
I'm not sure it's what you wanted but an idea I had when reading
your Post ...
look in p.t.scene-files and p.b.images ...
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Gilles Tran <tra### [at] inapginrafr> schrieb in im Newsbeitrag:
pigment
scale
increasing
density
to their
afterwards
in 2D).
desired effect
would have
> G.
Date: 12 Sep 2000 09:14:12
Message: <39be2c24@news.povray.org>
Hmm, from a physical standpoint, it seems the droplets form based upon the
surface tension and the amount of water available.  I don't know how true
this is to real life, but I'd try something like scattering points on the
surface.  Those are the drop points.  Then, for any other point on the
surface, add it's strength (assume all points have uniform strength) to the
point closest to it.  Once you've simulated long enough (where long enough
is probably on the range of 10 - 1000 * number of drops), each drop can be
formed based on its weight.  Other statistics (direction?) could be kept to
shape the drop rather than having them all spherical.  You should get
something approximating the right pattern, I'd think.
But that's all idle speculation.  I dunno if it'd work.
Geoff
Date: 12 Sep 2000 12:15:50
Message: <39BE5632.DA08E5D@inapg.inra.fr>
Not that idle. I like the idea. I'll give it a try if I find the time (the potential
parsing time is scary).
Thanks
G.
> Geoff
Date: 13 Sep 2000 08:16:32
Message: <39bf701f@news.povray.org>
Trust me, I understand.  I'm not adverse to high parse times, though.  Some
of my code takes ~2 hours to parse, then another 2-3 to allocate
memory/bounding boxes, etc.  *then* I get to render.  It gets about three
lines in 12 hours.  I run it over night/while I'm at work (which means I get
to reparse each night.  Ghods I wish there was a 'pickle' function for
parsed POV files!).  It might be done by Christmas.
But even I have limits.  I wrote a particle system for simulating cloth, and
even with relatively small numbers of points (~200), it took forever.  So I
rewrote it in C++.  Now, the above idea could be coded in C++, but that
requires knowing the points on the surface, which means you have to code the
surface in c++.  I'd probably do it in 3 stages. Create object and choose
drop points (in POV).  Use the output system to output those drop points.
Read file as input to a c++ program which takes them, finds some reasonable
distribution (minimum distance between drops?), then does the simulation.
In any reasonable programming language, the simulation is almost trivial to
run.  It's only a couple of million points after all.  May take 10 minutes,
but compared to render time....
Tell me if it works.  I'm curious.
Geoff
Date: 14 Sep 2000 07:07:48
Message: <chrishuff-5D6A44.06094214092000@news.povray.org>
In article <39bf701f@news.povray.org>, Geoff Wedig
>  Some of my code takes ~2 hours to parse, then another 2-3 to
> allocate memory/bounding boxes, etc.  *then* I get to render.  It
> gets about three lines in 12 hours.  I run it over night/while I'm at
> work (which means I get to reparse each night.  Ghods I wish there
> was a 'pickle' function for parsed POV files!).  It might be done by
> Christmas.
"Pickle" function?
You could have it output the objects after calculating them, so the
calculations don't have to be done again. The file sizes would probably
be quite big, though.
You might also get a speedup by turning vista buffering off...doing that
will slow down rendering, but the 2-3 hours you save by not calculating
them might make it worth it. It will also cut your memory usage down a
bit.
If not all of the objects are visible and they aren't reflective or
transparent, consider dropping some of them from the scene.
> cloth, and even with relatively small numbers of points (~200), it
> took forever.  So I rewrote it in C++.  Now, the above idea could be
> coded in C++, but that requires knowing the points on the surface,
> which means you have to code the surface in c++.  I'd probably do it
> in 3 stages. Create object and choose drop points (in POV).  Use the
> output system to output those drop points. Read file as input to a
> c++ program which takes them, finds some reasonable distribution
> trivial to run.  It's only a couple of million points after all.  May
> take 10 minutes, but compared to render time....
Instead of writing a separate program, you could do what I did with my
particle system, and turn it into a POV patch. If you want to get points
on an object, you have all the necessary tools right there.
Christopher James Huff
Date: 14 Sep 2000 09:09:12
Message: <39c0cdf8@news.povray.org>
>> Christmas.
> "Pickle" function?
Sorry, python term.  Pickling an object is taking it and turning it into a
file. Basically, I'm thinking of something like a memory map of the object
space saved to disk.  This would require no parsing, basically, because the
memory map could then be reloaded and just placed in memory.
*very* big.  The current image is >200,000 objects, most with their own
textures (based on an algorithm).  I don't think that's practical.
> bit.
Unfortunately, many of the objects are small, so removing vista buffers and
bounding boxes would be fatal (I think.  I must admit I don't know for sure)
already done.  There were a few that cast particular shadows that I removed
after those shadows were rendered (because I'm doing this incrementally, I
can do that)
Most of the problem is related to disk thrashing, I must admit.  I have 256
MB, and after the parse it never goes to disk, but while it's parsing, the
disk goes non-stop.  It's pretty ugly.
To be honest, I could reduce a lot of the work done in the macros given the
new features added in Megapov.  I just haven't had time so far to fiddle
with the code.
I didn't have the time to learn the POV code.  Secondly, I really wasn't
certain that doing it in pov was the best thing (from an efficiency
standpoint) and finally, I could run my simulation on a different computer,
so it could run while I rendered other stuff.
I haven't looked at your particle system patch yet, but I plan to the next
time I have a reason to use it.
Geoff
