POV-Ray : Newsgroups : povray.advanced-users : Inset texture maps Server Time
12 Apr 2026 06:27:49 EDT (-0400)
  Inset texture maps (Message 1 to 10 of 22)
Subject: Inset texture maps
Date: 24 Jan 2000 04:35:51
Message: <388C1D49.F23C00E1@gte.net>
I'm trying to create a sword. So far, it's basically a flattened
cylender that has it's upper and lower surfaces clipped off by a thin
cube.
The effect that I'm trying to create is where the flat part of the blade
sinks into the sword a little bit, and is filled with engravings and
etchings. This seems like something that could be done with surface
normals.
So far, I've got some pretty organic patterns with bumpy normals, but I
want to give the illusion that they are carved at a sleightly lower
altitude than the surface of the sword.
Is it possible to create a normal_map (or similar) that does something
like this, or do I have to resort to adding another cube?
-Jon
Subject: Re: Inset texture maps
Date: 24 Jan 2000 06:11:46
Message: <388c3372@news.povray.org>
Perhaps you should read the documentation about slope_maps.
Date: 25 Jan 2000 00:25:39
Message: <388d33d3@news.povray.org>
Jon Wooldridge wrote in message <388C1D49.F23C00E1@gte.net>...
A normal_map or bump_map using negative bump heights should work.  (No
guarentees, I've never used bump/normal maps).
Mark
Date: 25 Jan 2000 00:46:00
Message: <388D37D6.54EE2FA0@pacbell.net>
> Mark
  Another thing you can do with bump maps images is to use black patterns
on a white background. What this does is leave low areas where the pattern
is and raises the rest of the surface in effect giving you negative bump
mapping. On a two sided object such a sword blade you may have to split
it into two pieces, front and back, to get a different pattern on each
side and then union the two halves back together.
Date: 25 Jan 2000 05:55:43
Message: <388D808E.CEF10360@xs4all.nl>
> something
> (No
> > Mark
> patterns
> pattern
> bump
> split
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing
> Links:
> http://home.pacbell.net/tylereng/index.html
> http://www.povray.org/links/
Would it be stupid to use a heightfield for this?
Remco
Date: 25 Jan 2000 06:31:44
Message: <388D88E5.5B715DA5@pacbell.net>
> Remco
It would be difficult. The effect he wants is engraving rather than raised
areas. HF's would not apply well in this application I do not believe.
Date: 25 Jan 2000 09:26:48
Message: <388db2a8@news.povray.org>
Remco de Korte wrote in message <388D808E.CEF10360@xs4all.nl>...
>Remco
I've used height fields before for cutting pieces out of a surface and it
works quite well.
I do tend to have a problem getting the height field aligned, but that could
be just me.
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
* Definition of an upgrade: Take the old bugs out, put new ones in*
Date: 25 Jan 2000 11:15:00
Message: <ccuNOBU7nNJfNvylbDzYA2dOirii@4ax.com>
>> Remco
Actually a HF is a very good idea for this case. The whole blade (half
of it anyway) can be modelled using a HF. Or, the HF clipping trick
can be used -- make a union of the HF clipped by the blade and the
blade clipped by the HF (see hfclip.pov in the standard demo files).
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 25 Jan 2000 12:48:21
Message: <388DE144.11049093@xs4all.nl>
> >> Remco
See PBI for a quick experiment.
The heightfield was cooked up with PSP, not the best tool for that.
Remco
Date: 30 Mar 2000 23:20:15
Message: <38E5893F.2DB15EED@gate.net>
> > something
> > (No
> > > Mark
> > patterns
> > pattern
> > bump
> > split
> > Links:
> Remco
I see no reason you couldn't use a HF for this. The reason you wouldn't
want to is that the bump-map should be quite a bit faster than actual
geometry. That's determined by your situation, of course. If the camera is
going to be REALLY close to the sword, the HF will give you better results.
If not, don't bother.
