POV-Ray : Newsgroups : povray.advanced-users : Parsing vs. Rendering Performance Server Time
19 Jun 2026 18:15:58 EDT (-0400)
  Parsing vs. Rendering Performance (Message 18 to 27 of 37)
Subject: Re: Parsing vs. Rendering Performance
Date: 29 Dec 1999 10:52:26
Message: <386A2DCC.B45A86C5@xs4all.nl>
Ron Parker wrote:
> On Tue, 28 Dec 1999 20:00:25 -0800, Ken <tyl### [at] pacbellnet> wrote:
> >Benchmark testing generaly relies on the amount of time it takes
> >to render a given scene. If one were to design a scene that was
> >parsing intensive rather than render intensive how well would it
> >evaluate a systems performance ?
> Well, you're evaluating a part of the process that typically takes a
> lot less time
Sorry for cutting most of the message but this was the only thing I
think perhaps I disagree on. Most of the time rendering may take more
time than parsing but not in all cases. At the moment I'm rendering a
series of images where the parse time exceeds the render time. This, of
course is not very smart 8) In extreme cases it's better to do the heavy
calculations in an external program which will need only a fraction of
the time. Unfortunately this doesn't always work. I have noticed that
with the increasing power of my system I've concocted increasingly
complicated scenes which, even on a faster system, on average take
longer to render but even more so to parse (the more memory, the more
objects, the more parsing).
Just my two eurocents...
Remco
Date: 29 Dec 1999 12:30:03
Message: <henris-8B0D14.19312729121999@news.povray.org>
In article <386a0a77@news.povray.org>, "omniVERSE" <inv### [at] aolcom>
wrote:
> Wow, hey, large difference in the render time for those two.  I didn't
> think
> there would be any significant change.  Must be a Mac thing.
My educated guess is that it is a compiler issue.
To get back to the original topic:
If you want to benchmark the parsing algorithm without benchmarking the
disk, storing the scene file on a RAM disk should help.
Henri Sivonen
hen### [at] clinetfi
http://www.clinet.fi/~henris/
Date: 29 Dec 1999 13:08:49
Message: <386a4e31@news.povray.org>
I've rendered out to a ramdrive before.  There wasn't a difference, in
overall time anyway.
"Henri Sivonen" <hen### [at] clinetfi> wrote in message
news:henris-8B0D14.19312729121999@news.povray.org...
> > think
> Henri Sivonen
Date: 29 Dec 1999 15:46:45
Message: <386A732A.DF35C631@compuserve.com>
So, what you want to know is if there is a seperate parsing "engine" and
a rendering "engine"?  And can they be seperately optimized for
benchmarking purposes so that the parsing "engine" is platform
independant?
Or am I just gibbering?
Colin ;)
Ken then wrote:
> You guy's are still missing the point here. I give up.
Date: 29 Dec 1999 16:00:36
Message: <chrishuff_99-FBECF2.16012829121999@news.povray.org>
In article <386A0DF0.A9F73E70@gci.net>, "mr.art" <mr.### [at] gcinet>
wrote:
> I always thought that the render was the most system intensive
> part of the process.
It usually is, but sometimes it is the other way around. For example, if
your POV file includes particle simulations or tree/plant generation
macros, the parse time can easily exceed the render time.
And just as the rendering can be benchmarked, so can the parsing. Doing
tests on the parsing might reveal ways to speed it up or to write faster
parsing scenes.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 29 Dec 1999 16:05:52
Message: <chrishuff_99-B7412C.16064129121999@news.povray.org>
> think there would be any significant change.  Must be a Mac thing.
Well, there is a big difference in the chips. I have a G3, which is
*very* fast at integer calculations, but not very fast at floating
point. Parsing this scene probably uses mostly integer math.
Another thing is that the Mac version of POV-Ray has a memory cache
feature which can really speed things up, especially in allocating
memory(which is mainly what this scene is doing, allocating memory for
those spheres).
And last but definitely not least, the compilers used different. The Mac
version is compiled with CodeWarrior, I don't know about the Windows
version.
Chris Huff
Date: 29 Dec 1999 16:12:34
Message: <chrishuff_99-00B410.16132729121999@news.povray.org>
In article <386a0e59@news.povray.org>, "omniVERSE" <inv### [at] aolcom>
wrote:
>   The render time is obviously a video aspect to a machine, whereas the
> parse time is going to be the real guts of it, ie. the CPU and associated
> bus (and memory usage).
Nope, the video portions of the computer are not used in rendering.
Rendering mostly tests the floating point performance of the
microprocessor and the access speed of the RAM.
The only effect the video parts would have are in displaying the
rendered image on the screen, and that is probably almost unnoticeable.
And you can always turn the display off.
>   I would suggest leaving off the render part entirely for that matter,
> at least by using the -d switch or Display=Off.  How about the file
> riting?  -f or Output_to_File=Off.
That doesn't turn the render off, just the display of the rendered
image. The best way to minimize the render time interfering with the
parse time would be to set a very small image size(like 4*4 pixels).
Chris Huff
Date: 29 Dec 1999 17:37:51
Message: <386A8B14.C1A31EF7@faricy.net>
>   The question right now is not how fast you can render it.
That was entirely the parse time.
Date: 29 Dec 1999 20:29:09
Message: <386ab565@news.povray.org>
> For example I designed this scene to take exactly 30 sec. to parse
> on my system. There is a camera added simply to ensure that it was
> not pointed at any object and there are no lights added so that I
> rendered a black screen only. Render time at 640x480 with aa = 0.3
> was only 8 sec. which is inconsequential. A pigment was added to
> the object to ensure that no CPU cycles were spent on sending no
> pigment warnings messages to the message window for each object
> created by the scene code.
[snip]
I guess what you're mostly measuring with a test such as the one you posted
is the speed of memory allocation and filling (there aren't any complicated
transformations or other CPU-intensive parsing tasks).  This speed would be
affected by the physical speed of your RAM, the amount you have (and the
amount available under multi-tasking OS's), the drivers used to access it,
and probably the compiler used to make the POV-Ray executable.
All in all, benchmark tests of any kind can really only measure the speed of
tasks similar to what the test itself does, and even using POV-Ray there are
wildly different parsing tasks, eg. smoothing large heightfields or creating
subdivided bicubic patches, calling macros (particularly when they are
included from separate files), calculating bounding boxes and vista and
light buffers, etc.
Perhaps the best test of parsing and rendering is a scene which includes
many varied elements, giving something as close to a 'real-world' test as
possible?
Date: 29 Dec 1999 22:49:53
Message: <386AD3DC.E77A8282@aol.com>
> Pentium III 500MHz, 32KB L1 Cache, 512KB L2 Cache, 256MB 100MHz SDRAM,
> 13.4GB ATA66 7200RPM HardDisk.
> Win98SE at 68% Resources.
Damn Bob, when did you get that sweet machine!?  If I'm ever pressed for
time on a render I'll know who to call. :)
-Mike
