POV-Ray : Newsgroups : povray.advanced-users : Parsing vs. Rendering Performance Server Time
7 Jul 2026 00:26:51 EDT (-0400)
  Parsing vs. Rendering Performance (Message 11 to 20 of 37)
Subject: Re: Parsing vs. Rendering Performance
Date: 29 Dec 1999 08:19:51
Message: <386a0a77@news.povray.org>
Wow, hey, large difference in the render time for those two.  I didn't think
there would be any significant change.  Must be a Mac thing.
Just tried it myself and got a 9 sec parse with 3 sec again for render in
MegaPOV for Windows (although the =render= time has switched between 2 to 4
seconds on successive trials).
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-375B5B.07144329121999@news.povray.org...
> In article <38698759.90BDCD6B@pacbell.net>, lin### [at] povrayorg
> wrote:
> > Benchmark testing generaly relies on the amount of time it takes
> > to render a given scene. If one were to design a scene that was
> > parsing intensive rather than render intensive how well would it
> > evaluate a systems performance ?
> > For example I designed this scene to take exactly 30 sec. to parse
> > on my system. There is a camera added simply to ensure that it was
> > not pointed at any object and there are no lights added so that I
> > rendered a black screen only. Render time at 640x480 with aa = 0.3
> > was only 8 sec. which is inconsequential. A pigment was added to
> > the object to ensure that no CPU cycles were spent on sending no
> > pigment warnings messages to the message window for each object
> > created by the scene code.
> > camera {location < 0, 0, -3 >look_at  z*-6}
> > #declare A = 0;
> >   #while (A<29500)
> >     sphere{<0,0,A>,1 pigment{rgb 1}}
> >   #declare A=A+1;
> > #end
> With the official 3.1g.r2, cache set to maximum:
> Time For Parse:    0 hours  0 minutes  13.0 seconds (13 seconds)
> Time For Trace:    0 hours  0 minutes   8.0 seconds (8 seconds)
>     Total Time:    0 hours  0 minutes  21.0 seconds (21 seconds)
> With MacMegaPOV:
> Time For Parse:    0 hours  0 minutes  14.0 seconds (14 seconds)
> Time For Trace:    0 hours  0 minutes   1.0 seconds (1 seconds)
>     Total Time:    0 hours  0 minutes  15.0 seconds (15 seconds)
> My computer is a Power Macintosh G3 266 "beige" desktop, with  96MB RAM,
> booting from an external SCSI 9.1GB LaCie hard drive. The OS I ran these
> tests under is Mac OS 8.6(I haven't gotten Mac OS 9 yet, and have been
> too busy to do anything with LinuxPPC).
> I would suggest a scene file that does some more complex calculations
> instead of just creating a bunch of objects.
> Chris Huff
> e-mail: chr### [at] yahoocom
> Web page: http://chrishuff.dhs.org/
Date: 29 Dec 1999 08:26:50
Message: <386A0CD9.790ED969@pacbell.net>
> Bob
You guy's are still missing the point here. I give up.
Wishing you Seasons Greetings and A Happy New Millennium !
Date: 29 Dec 1999 08:35:02
Message: <386A0DF0.A9F73E70@gci.net>
I always thought that the render was the most system intensive
part of the process.
> #declare A = 0;
>   #while (A<29500)
>   #declare A=A+1;
> #end
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 29 Dec 1999 08:36:25
Message: <386a0e59@news.povray.org>
Back to the root of this thread.
  The render time is obviously a video aspect to a machine, whereas the
parse time is going to be the real guts of it, ie. the CPU and associated
bus (and memory usage).
  Ken is just saying his test script is an example of such a thing, unlike a
render intensive benchmarking.  That should be the focus of this
conversation I guess, right Ken?
  I would suggest leaving off the render part entirely for that matter, at
least by using the -d switch or Display=Off.  How about the file
riting?  -f or Output_to_File=Off.
  I think Niemenin is onto something about the more complex parsing,
although the question might be then could it be independant of platform
used?  Say, not work a CPU in a set way for one particular machine and
another differently?  Actually I suppose that's one point about benchmarks
anyway.
Date: 29 Dec 1999 08:42:26
Message: <386A0FD8.56A20AA4@mailbag.com>
Comment:
- Rendering relies heavily on floating point operations.
- Parsing often relies more heavily on integer operations.
- Parsing can often use a lot of memory, so it can test memory
performance.
- Not that you asked, but lots of includes, big external files, etc. can
test disk performance.
Much depends on the nature of the code being parsed.  You could write
code that requires a lot of floating point, tests the branch prediction
in your CPU, overflows cache and has to hit main memory a lot, etc.
I would suggest that benchmarks that don't rely on much extraneous
parsing would be most useful for determining how quickly a system
renders scenes, although a suite of scenes (rather than a single
skyvase.pov) might be useful.
-Mark Gordon
Date: 29 Dec 1999 10:19:54
Message: <386a2576.162126908@news.povray.org>
Well, you're evaluating a part of the process that typically takes a
lot less time and doesn't tax the same parts of the architecture that
a render does.  In particular, parsing is more concerned with file I/O
and memory allocation performance than with floating point
performance, so you're likely to see huge differences from filesystem
to filesystem and from OS to OS, even on the same computer.
Your example is probably more dependent on memory allocation than
anything else, so it might be a good measure of how fast your computer
can allocate memory.  Whether that's a good gauge of performance is up
to you, but I'd say no.
Date: 29 Dec 1999 10:45:11
Message: <386A2C19.EDEE9237@xs4all.nl>
Parsing has more than one aspects to it. I'm no tech-expert so I can't
say much about it really but you might at least consider the actual
parsing (reading the scene), calculating (influenced by the type of
calculations - perhaps this is sytem-specific), creating objects and
memory management.
Perhaps you should have more then one benchmark file to test against all
of these (and more?) things.
Remco
Date: 29 Dec 1999 10:52:26
Message: <386A2DCC.B45A86C5@xs4all.nl>
> lot less time
Sorry for cutting most of the message but this was the only thing I
think perhaps I disagree on. Most of the time rendering may take more
time than parsing but not in all cases. At the moment I'm rendering a
series of images where the parse time exceeds the render time. This, of
course is not very smart 8) In extreme cases it's better to do the heavy
calculations in an external program which will need only a fraction of
the time. Unfortunately this doesn't always work. I have noticed that
with the increasing power of my system I've concocted increasingly
complicated scenes which, even on a faster system, on average take
longer to render but even more so to parse (the more memory, the more
objects, the more parsing).
Just my two eurocents...
Remco
Date: 29 Dec 1999 12:30:03
Message: <henris-8B0D14.19312729121999@news.povray.org>
In article <386a0a77@news.povray.org>, "omniVERSE" <inv### [at] aolcom>
> think
My educated guess is that it is a compiler issue.
To get back to the original topic:
If you want to benchmark the parsing algorithm without benchmarking the
disk, storing the scene file on a RAM disk should help.
Henri Sivonen
hen### [at] clinetfi
http://www.clinet.fi/~henris/
Date: 29 Dec 1999 13:08:49
Message: <386a4e31@news.povray.org>
I've rendered out to a ramdrive before.  There wasn't a difference, in
overall time anyway.
"Henri Sivonen" <hen### [at] clinetfi> wrote in message
news:henris-8B0D14.19312729121999@news.povray.org...
> > think
> Henri Sivonen
