Hi All,
I want to add/import an object to a Moray scene file as a link
rather than a new object, the reason being that I want to create several
objects, link them into a new scene, move them, copy them, duplicate
them etc.
If I have to tweak any of the objects, I only have to work on the
original file and it will be automatically updated in the main Moray
scene file.
I have read and re-read the manual, but I cannot find anywhere that
tells me if it can be done, can it be done? and is it in the manual??
Thanks in advance, Alex.
,-._|\ Alex McMurray
/ Oz \ ale### [at] melbpcorgau Melbourne PC User Group.
\_,--.x/Melton. Vic. 3337 Australia
v
Alex McMurray schrieb:
> Hi All,
> them etc.
> scene file.
No, it's not in the manual, 'cause it can't be done like this (up to
now, Lutz?)
What you could do, is putting the object in you scene once, thene create
as many references as you wish (but within that scene) and if you
manipulate the main object within the scene all the references in the
scene will be changed as well. But externel linking to another scene is
not possible.
If anyone knows better, feel free to correct me
Arne
> > Hi All,
> > them etc.
> > scene file.
> now, Lutz?)
> not possible.
> Arne
Hmm, but there might be a way to do it almost the way you like it.
Create an object in a special file, export it as a udo, implement it as
udo in the target file. Then if you change your object in the source
file & export it every time you changned it, it should work the way i
understood your attempt. ???
Anybody else a better idea?
Arne
> now, Lutz?)
> not possible.
> Arne
Thanks Arne,
I was affraid that was the answer, I currently do what you suggested, but
I was hoping that maybe there was an easier way, although I have not tried it,
my son can do it in POV-ray.
Hey Lutz, any chance of it happening in future revisions?
v
It depends on how accurate you want your representation. I've hand coded
udo files more than once, giving a box where the object is, without giving
any detail. If all you care about is placing the object, this is
sufficient. In fact, I do this quite a bit. I make very complex objects in
pov, using aspects that Moray doesn't support (or using Moray to build a
base object, turn it into a pov source, edit that source, create the udo,
and port back in as udo into a different scene) It's not too bad to do
something like this, and can add a lot, without blowing up the moray/pov
files.
Geoff
Hi Alex McMurray, you recently wrote in moray.win:
This is quite a complex undertaking since there could be collisions in
the 'namespace', so to speak. Since there can be no guarantee that
there won't be objects or textures in referenced files, it would be a
real headache to sort out.....
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Thanks Lutz, It was just a thought.
Greg's suggestion sounds like it might be a good work around, create each
object individually in Moray, then link them directily in Pov-ray.
v
