POV-Ray : Newsgroups : povray.windows : Anti-Aliasing in self-compiled POV-Ray Server Time
5 Feb 2026 19:11:52 EST (-0500)
  Anti-Aliasing in self-compiled POV-Ray (Message 1 to 10 of 12)
Subject: Anti-Aliasing in self-compiled POV-Ray
Date: 5 Jun 2001 14:34:52
Message: <3b1d264c@news.povray.org>
Hash: SHA1
Hello,
I just compiled the source code of POV-Ray for Windows. Surprisingly,
there seems to be problems with anti-aliasing, it just won't work and
a low-quality picture is produced. Is it just me, or has anyone else
experienced this (and maybe can help me out)?
Thanx in advance,
Martin
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 7.0.3 for non-commercial use <http://www.pgp.com>
iQA/AwUBOx0mRawCKNUlUgPdEQLVWACfXIFhsL4zicmL13DB0eIFDHNL0UAAnAuf
n3tcysJdDW0bFU79gHC+B/M0
=zA1F
-----END PGP SIGNATURE-----
Subject: Re: Anti-Aliasing in self-compiled POV-Ray
Date: 5 Jun 2001 14:38:35
Message: <3B1D2781.CAAF74B9@gmx.de>
Some more detailed information would probably be good, like:
- what compiler
- what antialiasing options
- maybe a sample piture shaowing the 'low-quality' in p.b.i
Date: 5 Jun 2001 15:03:37
Message: <3b1d2d09@news.povray.org>
Hash: SHA1
"Christoph Hormann" <chr### [at] gmxde> schrieb im Newsbeitrag
news:3B1D2781.CAAF74B9@gmx.de...
> > Surprisingly, there seems to be problems with anti-aliasing, it
> > just won't work and a low-quality picture is produced. Is it just
> > me, or has anyone else experienced this (and maybe can help me
> > out)?
> - what compiler
> Christoph
Hi Christoph,
I used VC++ 6. The anti-aliasing options is a threshold of 0.3 (one
of the render option sets provided by the POV-Ray GUI). And take it
for granted: the output is the same, regardless whether I use
anti-aliasing or not.
BTW: What is p.b.i. ?
Thank you,
Martin
iQA/AwUBOx0tAqwCKNUlUgPdEQKJzACeJWfpluw2pQl7Rj8ArGa2GBhKtU8AnjbZ
ia+zlx98665c+duRqT529g5a
=3eg8
Date: 5 Jun 2001 15:26:24
Message: <3B1D32B6.9368CD21@gmx.de>
> Hi Christoph,
Does it say that antialiasing is used in the render statistics?
the povray.binaries.images newsgroup.
Date: 5 Jun 2001 15:38:29
Message: <slrn9hqd9n.3bg.ron.parker@fwi.com>
Does the message pane tell you that AA is on or off when you render with
what should be AA?
That is, this is what you should see without AA:
Tracing Options
  Quality:  9
  Bounding boxes.......On  Bounding threshold: 3
  Light Buffer.........On  Vista Buffer.........On  Draw Vista Buffer...Off
  Antialiasing........Off
  Radiosity...........Off
And this is what you should see with it on:
Tracing Options
  Quality:  9
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 5 Jun 2001 16:48:04
Message: <3b1d4584@news.povray.org>
Hash: SHA1
news:3B1D32B6.9368CD21@gmx.de...
> > Hi Christoph,
> > (one of the render option sets provided by the POV-Ray GUI). And
> > take it for granted: the output is the same, regardless whether I
> > use
> Christoph
Hello again,
that was one of the first things I checked, and the answer is: no, it
does not use anit-aliasing (if I go by the render statistics)
although - after I replaced pvengine.exe with the originally
distributed binary - the original POV-Ray does it (using the same
rendering options).
What now?
Thanks in advance,
Martin
iQA/AwUBOx1Ff6wCKNUlUgPdEQIaIQCfcaArpUzbXjEVuyqWzcAE7jhECVQAnj9c
9/49tFuaNTe6JQAAS1lIiqYR
=/YYq
Date: 5 Jun 2001 16:51:40
Message: <3b1d465c@news.povray.org>
Hash: SHA1
"Ron Parker" <ron### [at] povrayorg> schrieb im Newsbeitrag
news:slr### [at] fwicom...
> >use
> with what should be AA?
> Tracing Options
>   Quality:  9
> Buffer...Off
> Tracing Options
>   Quality:  9
> Buffer...Off
> Jitter 1.00)
Hello,
please see my answer to Christoph Hormann's posting, for he asked for
the same details as you. As you might have assumed, no anti-aliasing
was used according to the rendering statistics (and according to the
picture quality ;-).
Bye,
Martin
iQA/AwUBOx1GV6wCKNUlUgPdEQJ/gACdEZNrek9GbCq7F+nKoLX3Khz6ipoAn1Qu
p6836IbBe6fwqcEyM0dRSxyY
=ETAB
Date: 5 Jun 2001 18:07:30
Message: <Xns90B81453EF76seed7@povray.org>
Maybe a stupid question, have you tried what happens if you set the
anti-aliasing on the command line +a0.3 instead of using the
predefined settings?
Ingo
Date: 5 Jun 2001 18:34:48
Message: <3b1d5e88$1@news.povray.org>
Hash: SHA1
"ingo" <ing### [at] homenl> schrieb im Newsbeitrag
news:Xns### [at] povrayorg...
> Ingo
I am ashamed ... but: how would I do that? I am only used to the
POV-Ray GUI, not to the command line port ...
bye,
Martin
iQA/AwUBOx1egawCKNUlUgPdEQJ1AgCgmxPfMxdHBmj/uVmolJBvpWmZ1TEAn0OP
QISl4RAlQXTT/ZX/P2wqmU+T
=MhBe
Date: 5 Jun 2001 21:20:13
Message: <3B1D84C5.29E09CF2@pacbell.net>
Press alt+c to open the command line dialog. At the bottom of the window
you will see a place to put command line options. Enter +a0.3 there and
close the window. Every time you render the commands you enter on this
line will over ride any .ini file options you may have specified such
as those quickres.ini uses in GUI drop down list.
Ken Tyler
