POV-Ray : Newsgroups : povray.unofficial.patches : Compile error during Megapov XRS server make Server Time: 19 Nov 2008 22:37:31 GMT
  Compile error during Megapov XRS server make (Message 1 to 10 of 13)
Subject: Compile error during Megapov XRS server make
Date: 18 Nov 2006 21:40:00
Message: <web.455f7c9597f164dbf826bd4d0@news.povray.org>
Am having a problem getting Megapov XRS server make to complete
successfully. It generates several compile errors.
Running the latest full cygwin on WinXP-Pro x64 v2003sp1 on a system with
AMD Athlon 64x2 dual core processor 4200+.
Downloaded and unpacked megapov-xrs_core-1.2.1-2.1.1.tar.bz2. Accomplished
Step 0 and verified with:
praeth@PRAETH-PC
/cygdrive/c/program_files/cygwin/tmp/megapov-xrs_core-1.2.1-2.1.1/megapov-xrs_server-1.2.1-2.1.1
$ pkg-config --modversion libiqxmlrpc
0.7.3a
Steps 1 and 2 went smoothly.
Step 3 went through the configure process without error.
Step 3 failed during the make process due to several compile errors:
g++: unrecognized option `-pthread'
xrs_serverthread.cpp: In member function `void
xrs_gjp::rpc::ServerThread::operator()()':
xrs_serverthread.cpp:74: error: expected primary-expression before '>' token
xrs_serverthread.cpp:75: error: expected primary-expression before '>' token
xrs_serverthread.cpp:76: error: expected primary-expression before '>' token
xrs_serverthread.cpp:77: error: expected primary-expression before '>' token
xrs_serverthread.cpp:78: error: expected primary-expression before '>' token
xrs_serverthread.cpp:79: error: expected primary-expression before '>' token
xrs_serverthread.cpp:81: error: expected primary-expression before '>' token
xrs_serverthread.cpp:82: error: expected primary-expression before '>' token
xrs_serverthread.cpp:83: error: expected primary-expression before '>' token
make[3]: *** [xrs_serverthread.o] Error 1
make[3]: Leaving directory
`/cygdrive/c/program_files/cygwin/tmp/megapov-xrs_core-1.2.1-2.1.1/megapov-xrs_server-1.2.1-2.1.1
source/patches'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory
source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
make: *** [all] Error 2
Many thanks for whatever insights you may have.
Best,
Peter.
Subject: Re: Compile error during Megapov XRS server make
Date: 19 Nov 2006 02:25:01
Message: <web.455fbfafe1423b92c0bad8570@news.povray.org>
> praeth@PRAETH-PC
> 0.7.3a
> source/patches'
> source'
Hi Peter, I'm still puzzled because that's the compile error you'd get when
using the unsupported 0.8.x libiqxmlrpc, but you're using the correct
0.7.3a version.. what's your g++ version? Mine is:
themaxx@megatron ~
$ g++ --version
g++ (GCC) 3.4.4 (cygming special) (gdc 0.12, using dmd 0.125)
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Thanks,
George
> Best,
> Peter.
Date: 19 Nov 2006 03:35:00
Message: <web.455fd0a3e1423b92c0bad8570@news.povray.org>
> themaxx@megatron ~
> $ g++ --version
FYI I confirmed that I could ./configure and make the same version of
megapov-xrs_server as yours on my cygwin setup:
themaxx@megatron
1
$ unix/megapov_xrs_server.exe 9000
    __  ___                                     _  __ ____  _____
   /  |/  /__  ____ _____ _____  ____ _   __   | |/ // __ / ___/
  / /|_/ / _ / __ `/ __ `/ __ / __  | / /   |   // /_/ /__
 / /  / /  __/ /_/ / /_/ / /_/ / /_/ / |/ /   /   |/ _, _/___/ /
/_/  /_/___/__, /__,_/ .___/____/|___/   /_/|_/_/ |_|/____/
          /____/     /_/
Megapov XRS adds network rendering capability to MegaPOV
Renderer version......... megapov 1.2.1
XRS core version......... xrs_server_core 2.1.1
XRS protocol version..... XRS 2.0.0
Xtreme Render System designed and implemented by:
George J. Pantazopoulos <http://www.gammaburst.net>
This program is a modified, unofficial version of POV-Ray
and is not supported by the POV-Ray team.
returned from povray_init()
returned from unix_create_globals()
Listening for XML-RPC commands on port 9000
Cooperate_Render_Flag = 0
themaxx@megatron
1
0.7.3a
I'm running Windows XP Service Pack2 on a Pentium4 (Northwood, 32-bit)
HTH,
George
Date: 20 Nov 2006 13:00:01
Message: <web.4561a633e1423b92f826bd4d0@news.povray.org>
Prior to realizing that v0.7.3a was needed instead of v0.8.2a I had
installed that later version. Later, I installed the earlier version. Is it
possible that the two are interfering with each other? How would one
completely uninstall v0.8.2a? I could not find an uninstall procedure.
Many thanks for your patient assistance.
Best,
Peter.
Date: 20 Nov 2006 13:25:00
Message: <web.4561abe0e1423b92c0bad8570@news.povray.org>
Hi Peter, for many unix packages you can do "make uninstall" just as you
originally did "make install". This should work for libiqxmlrpc.
Also for cygwin, check /lib, /usr/lib, and /usr/local/lib. On my Cygwin
system, /lib and /usr/lib seem to be two names for the same underlying
folder.
HTH,
George
> Best,
> Peter.
Date: 21 Nov 2006 14:25:01
Message: <web.45630b30e1423b92f826bd4d0@news.povray.org>
> folder.
Ah.... Most satisfying. Other than some warnings on variable type
conversions, the make went well.
This was a trial process performed on my desk machine. Will now move over to
our Windows cluster. Will install on two nodes and test. Then will go to the
rest of the nodes.
Our application is in atmospheric physics.
Many thanks George.
Best,
Peter.
Date: 21 Nov 2006 14:30:00
Message: <web.45630cb5e1423b92c0bad8570@news.povray.org>
> > folder.
> rest of the nodes.
> Many thanks George.
Your welcome, Peter! Let me know how it goes. I'm also very curious about
your application. If you can tell me, I'd love to hear more.
Rock on,
George
> Best,
> Peter.
Date: 28 Nov 2006 20:40:01
Message: <web.456c9e48e1423b92f826bd4d0@news.povray.org>
Was able to get povray, megapov, and megapov_xrs installed on cygwin. Was
also able to verify correct operation for povray and megapov.
Megapov_xrs_server starts up ok and starts listening.
Megapov_xrs_client terminates with the following error:
+L/cygdrive/c/program_files/cygwin/tmp/povray-3.6.1/include
Traceback (most recent call last):
  File "pyxrsclient.py", line 55, in ?
    import gtk
  File "/usr/lib/python2.4/site-packages/gtk-2.0/gtk/__init__.py", line 37,
in ?
    from _gtk import *
RuntimeError: could not open display
The pyxrsclient.py is:
#! /bin/python
# pyxrsclient.py
# George Pantazopoulos
# http://www.gammaburst.net
# Python client for distributed rendering using Megapov XRS Servers
# 28 Aug 2006
# Hyper-threaded, sweet buttery goodness.
# Server URL's, followed by the base POV directory (pov_basedir)
# URL's should be in the form "http://ip-address:port"
# pov_basedir should contain the following subdirs
# and be duplicated on all servers:
# fonts/
# imagemaps/
# include/
# LightsysIV/
# scenes/
# Only one of these directory structures is needed per machine
# even it has more than one CPU
# Server info format.
# ("http://server-ip:server-port", /"pov_basedir/for/this/server"),
# Edit this variable (last entry should not have a comma):
g_server_urls = [("http://localhost:9000",
"/cygdrive/c/program_files/cygwin/tmp/povray-3.6.1")]
# Required subdirs on all servers. Ordering counts! (not yet implemented)
#g_required_subdirs = ["scenes", "include", "fonts", "imagemaps",
"LightsysIV"]
# Max tiles to queue per server (default=4)
# Increase if servers are spending too much time in the READY state
g_max_tiles_to_queue = 4
g_polling_delay_sec = 1.0 # default=1.0. increase if there are many servers.
# Disable this is if it causes problems.
g_enable_status_display = True
import sys
if len(sys.argv) < 2:
    print "Usage: " + str(sys.argv[0]) + " povray-args"
    sys.exit(1)
import pygtk
pygtk.require('2.0')
import gtk
import xmlrpclib
import time
import threading
import socket
import gc
import Queue
import gobject
import os
import os.path
import re
from tilelib import genStartAndEndCoords, MakeTileGrid, MakeSpiralTileList
from xrslib  import STATE_IDLE, STATE_INIT, STATE_READY,
                    STATE_RENDERING, STATE_CLEANUP, STATE_ERROR
g_parser = 0
g_name    = "pyxrsclient"
g_version = "0.6.10"
class CommandLineParser:
    def __init__(self, arglist):
        # Create a single string out of the argument list.
        self.cmd = ""
        for s in arglist:
            self.cmd += s
            self.cmd += " "
        # Process the cmd so that any backslashes are replaced with
        # forward slashes.
        self.cmd = self.cmd.replace("\", "/")
        # Force the display off. There is a bug in megapov_xrs_server
        # version <= 2.0.4 that segfaulted on a user's AMD64 system
        # unless -D was specified on the command line
        self.cmd += " -D"
        # The user can specify tile size using the POV-Ray 3.7 compatible
        # +BSn option. However, we need to remove it from the POV-Ray
        # string. This is for client use only.
        # First match the n portion of the blocksize arg "+BSn"
        rs_blocksize = re.search("(?<=[+-]BS)[0-9]+", self.cmd)
        if rs_blocksize == None:
            self.blocksize = 64
        else:
            self.blocksize = int(rs_blocksize.group(0))
        # Then, match the whole +BSn string
        # and excise it from the pov command line
        rs_blocksize_str = re.search("([+-]BS[0-9]+)", self.cmd)
        if rs_blocksize_str == None:
            pass
        else:
            self.cmd = self.cmd.replace(rs_blocksize_str.group(0), "")
        # remove any +o options
        output_name_rs = re.search("([+-]o[^ ]*)", self.cmd)
        if output_name_rs == None:
            pass
        else:
            self.cmd = self.cmd.replace(output_name_rs.group(0), "")
    def getCmd(self):
        return self.cmd
    def getImgWidth(self):
        imgwidth  = int(re.search("(?<=[+-]w)[0-9]+", self.cmd).group(0))
        return imgwidth
    def getImgHeight(self):
        imgheight = int(re.search("(?<=[+-]h)[0-9]+", self.cmd).group(0))
        return imgheight
    def getBlockSize(self):
        # TODO: take this out of the POV-ray command line afterwards!
        return self.blocksize
    def getImgFormat(self):
        # Extract the user's image type preference
        # TODO if not found, or a different type, enforce PNG (+fn)
        image_format = re.search("(?<=[+-]f)[^ ]+", self.cmd).group(0)
        return image_format
    def getScenePath(self):
        # Extract the scene file path. Path must not contain spaces.
        #scene_path = re.search("(?<=[+-]I)[^ ]+", self.cmd).group(0)
        # The Scene Path may or may not be preceded by a +I
        # Thus, we search using the .pov extension, and strip
        # away the +I, if present
        scene_path = ""
        rs_scene_path_option = re.search("([^ ]+)(?=.pov).pov", self.cmd)
        if rs_scene_path_option == None:
            raise "Could not find a .pov file in the command string"
        else:
            scene_path_option = rs_scene_path_option.group(0)
            # strip away the +I, if present
            # Use a positive lookbehind assertion.
            # Match the rest of the string, if the +I was present
            xim = re.search("(?<=[+-]I)[^ ]+", scene_path_option)
            # If there was no +I, we can use the scene path as is
            if xim == None:
                scene_path = scene_path_option
            else:
                # The matching process stripped away the +I
                scene_path = xim.group(0)
        return scene_path
    def getSceneFile(self):
        scene_file = os.path.basename(self.getScenePath())
        return scene_file
    def getBaseDir(self):
            # Until 'scenes' appears in the 'tail' portion
            # keep splitting. Unsuccessful is head becomes the empty string
            p = self.getScenePath()
            import os.path
            base_dir = ""
            x = os.path.split(p)
            while (x[1] != 'scenes') and (x[1] != ''):
                    x = os.path.split(x[0])
            if (x[1] == ''):
                    base_dir = None
            else:
                    base_dir = x[0]
                    # Ensure that base_dir contains a trailing slash
                    base_dir += "/"
            return base_dir
# Give the xmlrpclib's ServerProxy the ability to store
# other useful info, such as the working directory
class XrsProxy(xmlrpclib.ServerProxy):
    def __init__(self, url, base_dir):
        xmlrpclib.ServerProxy.__init__(self, url)
        self.base_dir = base_dir
        # ensure the base_dir has a trailing slash
        self.base_dir += "/"
        self.url = url
        return self.base_dir
    def getUrl(self):
        return self.url
def PrintServerSettings(server_info):
    for i in server_info:
        print "URL: " + str(i[0])
        print "POV BaseDir: " + str(i[1])
        print ""
def CreateServerProxies(server_urls):
    """ Returns a list of active ServerProxies """
    server_proxies = []
    # For each Server URL, create a ServerProxy
    for u in server_urls:
        sp = XrsProxy(u[0], u[1])
        # Try connecting to this server proxy
        # If we don't get an exception, then we can add
        # it to our list.
        try:
            sp.Status()
            server_proxies.append(sp)
            print "Server " + str(u[0]) + "... OK"
        except socket.error, msg:
            print "Server " + str(u[0]) + "... " + str(msg[1])
        except xmlrpclib.ProtocolError, msg:
            print "Server " + str(u[0]) + "... " + str(msg)
    return server_proxies
g_rendered_tiles   = Queue.Queue()
g_tiles_to_display = Queue.Queue()
g_tiles_to_render  = Queue.Queue()
def GenerateTiles(img_w, img_h, nx, ny):
    tileGrid = MakeTileGrid(img_w, img_h, nx, ny)
    return MakeSpiralTileList(nx, ny, tileGrid)
class DisplayThread(threading.Thread):
    stopthread = threading.Event()
    def __init__(self, tile_q):
        threading.Thread.__init__(self)
        self.tile_q = tile_q
    def run(self):
        # loop until until terminated
        while (not self.stopthread.isSet()):
            try:
                # block on queue and wait for a tile to become available
                tile = self.tile_q.get()
                # If we got woken up on purpose so we can exit,
                # we want to exit here, before trying to display a fake tile
                if (self.stopthread.isSet()):
                    return
                # Extract the base64data from the tile and convert to binary
                b = xmlrpclib.Binary()
                b.decode(tile['base64data'])
                # Save the image data to a temp file so it can be loaded by
gtk
                output_dir = "./"
                file_ext = "png";
                filename = "retrieved_tile" + str(tile['id']) + "." +
file_ext
                full_path = output_dir + filename
                out_file = open(output_dir + filename, "wb")
                out_file.write(b.data)
                out_file.close()
                # Display the tile
                # Paste our tile into the appropriate location in the main
pixbuf
                id = int(tile['id'])
                sc = int(tile['sc'])
                ec = int(tile['ec'])
                sr = int(tile['sr'])
                er = int(tile['er'])
                tile_width  = (ec-sc) + 1
                tile_height = (er-sr) + 1
                x_offset = sc - 1 # sc starts at 1
                y_offset = sr - 1 # sr starts at 1
                # Now that we have a file saved, create a gtk Pixbuf
                # To hold our tile.
                gtk.threads_enter()
                #print "file info: " +
str(gtk.gdk.pixbuf_get_file_info(full_path))
                tile_pb = gtk.gdk.pixbuf_new_from_file_at_size(full_path,
g_parser.getImgWidth(),
g_parser.getImgHeight()) #height
                #POV-Ray creates PNGs with incorrect size params
                # (the size of the original image). So we need to extract
                # our actual rendered region/
                # For now, only use vertical stripe tiles
                tile_pb.copy_area(x_offset, 0,#y_offset, # This hack is
necessary to work with POV's screwed up PNG's
                                  tile_width, tile_height,
                                  g_pbmain,
                                  x_offset, y_offset)
                # update the main pixbuf
                g_image.set_from_pixbuf(g_pbmain)
                # With PyGTK, the pixbuf does not get destroyed
                # when we go out of scope, leading to increasing memory
usage.
                # According to the FAQ,
                # the solution is to prod the garbage collector.
                # Hopefully this won't slow things down too much here.
                gc.collect()
                # delete the image file now that we don't need it anymore.
                os.remove(full_path)
                gtk.threads_leave()
            # This should catch Decompression errors with POV's wierd PNGs
            except gobject.GError, msg:
                print "Caught exception in DisplayThread: " + str(msg) + "
.... continuing"
                # we must do this before continuing!
                gtk.threads_leave()
                continue
            except OSError, msg:
.... continuing"
                gtk.threads_leave()
                continue
    def stop(self):
        self.stopthread.set()
        # Put in a fake tile to unblock thread.
        self.tile_q.put_nowait(None)
# Each Render thread will handle one XRS Server.
class RenderClientThread(threading.Thread):
    tiles_in_progress = Queue.Queue()
    def __init__(self, sp):
        # Must invoke the base-class ctor
        # The ServerProxy
        self.sp = sp
        myname = "Render Thread for Server " + str(sp.getUrl())
        self.setName(myname)
        global g_parser
        self.pov_basedir = sp.getBaseDir()
        client_scene_path  = g_parser.getScenePath()
        client_pov_basedir = g_parser.getBaseDir()
        self.scene_path = client_scene_path.replace(client_pov_basedir,
                                                      self.pov_basedir)
        self.scene_dir = os.path.dirname(self.scene_path)
        self.library_path =
                "+L" + "." + " " +
                "+L" + self.scene_dir + "/ "
                "+L" + self.scene_dir + "/maps/ "
                "+L" + self.pov_basedir + "/include/" + " " +
                "+L" + self.pov_basedir + "/LightsysIV/" + " "
                "+L" + self.pov_basedir + "/ "
                "+L" + self.pov_basedir + "/imagemaps/" + " "
                "+L" + self.pov_basedir + "/fonts/" + " "
        # Pass along the povray command, but first edit out the
        # the client's pov_basedir and replace it with our own
        self.cmd = g_parser.getCmd()
        self.cmd = self.cmd.replace(client_pov_basedir, self.pov_basedir)
        # Add the library paths we just generated
        self.cmd += " "
        self.cmd += self.library_path
        print "Command to be sent to Server " + str(self.sp.getUrl()) + ":"
        print self.cmd
        print ""
    def run(self, **kwargs):
        scene_id = 0
        # Try to start a NewScene on the Server
        try:
            scene_id = self.sp.NewScene({'command':self.cmd})
            #print "NewScene id = " + str(scene_id)
            print "Caught exception in RenderClientThread: " + str(msg) + ".
Exiting thread"
            return
        except xmlrpclib.Fault, msg:
Exiting thread"
            return
        # Ok, a NewScene() command was accepted.
        # Note, the previous scene could still be cleaning up.
        # Thus, we need to wait for the new scene's id to appear
        # in the status response.
        self.updateStatus()
        while self.status['scene_id'] != scene_id:
            self.updateStatus()
            state    = self.status['state']
            scene_id = self.status['scene_id']
##            print "scene_id=" + str(scene_id)
##                  + ", " + "state=" + str(state)
            if self.stopthread.isSet():
                return
            time.sleep(0.5)
        # Wait for our scene to be ready.
        while self.status['state'] != STATE_READY:
            self.updateStatus()
##            print self.status
            if state == STATE_ERROR:
                print "Server reported STATE_ERROR for scene_id " +
str(scene_id)
                return
                return
            time.sleep(0.5)
        # Refresh the status
        self.updateStatus()
        # Give the Server its first tile to render
        # TODO: if the server comes late to the party,
        # there could be no tiles available, causing an exception.
        try:
            tile = g_tiles_to_render.get_nowait()
            self.sp.RenderTile(tile)
            self.tiles_in_progress.put_nowait(tile)
        except Queue.Empty:
            print "no tiles to render. continuing wait loop"
            return
        time.sleep(0.1)
        self.updateStatus()
        # Loop as long as the Server is not in STATE_ERROR
        while self.status['state'] != STATE_ERROR:
            global g_polling_delay_sec
            time.sleep(g_polling_delay_sec)
            self.updateStatus()
                # Stop the Server from rendering by sending it a NewScene()
                # with an empty command.
                self.sp.NewScene({'command':""})
                self.status['state'] = 'STOPPED'
                g_server_status[self.sp.getUrl()]['state'] =
                return
            try:
                # Goal:
                # Make sure Server has tiles to work on at all times,
                # especially while it's transferring a bunch of
                # rendered tiles.
                num_tiles_ready = self.status['tiles_ready']
                if num_tiles_ready > 0:
                    # Before we transfer any tiles that are ready
                    # Give the Server more work to do.
                    num_tiles_queued = self.status['tiles_queued']
                    global g_max_tiles_to_queue
                    max_tiles_to_queue = g_max_tiles_to_queue
                    tiles_to_queue = max(0, max_tiles_to_queue -
num_tiles_queued)
                    for i in range(tiles_to_queue):
                        # Give the Server a new tile to render.
                        self.updateStatus()
                        if (g_tiles_to_render.qsize() > 0):
                    # Now that the Server will be rendering, transfer the
                    # rendered tiles.
                    for i in range(num_tiles_ready):
                        self.updateStatus()
                        rendered_tile = self.sp.GetRenderedTile()
                        # If we made it here, then we retrieved a rendered
tile image
                        #print "retrieved image: " +
rendered_tile['filename']
                        # Pop the rendered tile from the server.
                        self.sp.PopRenderedTile(rendered_tile['id'])
                        # put the tile into the list of rendered tiles.
                        g_rendered_tiles.put_nowait(rendered_tile)
                        # Queue the tile up for display.
                        g_tiles_to_display.put_nowait(rendered_tile)
                        # When the tile is downloaded, remove it from
                        # our "in progress" queue.
                        # We assume that the Server preserves the ordering
of any
                        # tiles it's given to render.
                        self.tiles_in_progress.get_nowait()
+ " Continuing..."
                continue
            # No more tiles to render.
            except Queue.Empty:
                continue
        print "RenderClientThread finished"
    def getServerProxy(self):
        return self.sp
    def updateStatus(self):
        self.status = self.sp.Status()
        # Update the status display
        g_server_status[self.sp.getUrl()]['state'] = self.status['state']
        g_server_status[self.sp.getUrl()]['tiles_queued'] =
        g_server_status[self.sp.getUrl()]['tiles_ready'] =
##            print str(self.sp) + ": " + "scene_id="  + str(scene_id)
##                  + ", " + "state="        + str(status['state'])
##                  + ", " + "tiles_ready="  + str(status['tiles_ready'])
##                  + ", " + "tiles_queued=" + str(status['tiles_queued'])
    def getTilesInProgress(self):
        # This is meant to be called after the thread has stopped
        # so qsize() will be stable.
        # This 'uses up' the tiles.
        tiles = []
        print "***** " + str(self.tiles_in_progress.qsize()) + "tiles to
recover"
        for i in range(self.tiles_in_progress.qsize()):
            tiles.append(self.tiles_in_progress.get_nowait())
        return tiles
    def stop(self):
def main_quit(obj):
    print "doing gtk.main_quit()"
    g_status_window.destroy()
    gtk.main_quit()
    print "gtk.main_quit() done"
# GUI Bootstrap
def InitGui():
    global g_pbmain, g_image
    g_pbmain = gtk.gdk.Pixbuf(gtk.gdk.COLORSPACE_RGB, False, 8,
g_parser.getImgWidth(), g_parser.getImgHeight())
    g_image = gtk.Image()
    g_image.show()
    window = gtk.Window(gtk.WINDOW_TOPLEVEL)
    window.add(g_image)
    window.connect('destroy', main_quit)
    window.set_title("Render Preview - " + g_name + " " + g_version)
    window.show_all()
    global g_status_window
    g_status_window = gtk.Window(gtk.WINDOW_TOPLEVEL)
    pass
class MasterRenderThread(threading.Thread):
    def __init__(self):
        global g_parser
        self.stopthread = threading.Event()
        self.renderClientThreads = []
        self.num_total_tiles = 0
    def run(self):
        global g_rendered_tiles
        global g_tiles_to_render
        global g_server_proxies
        global g_parser, g_num_x_tiles, g_num_y_tiles
        # Generate tiles
        unrendered_tiles = GenerateTiles(g_parser.getImgWidth(),
g_parser.getImgHeight(),
                                         g_num_x_tiles, g_num_y_tiles)
        unrendered_tiles.reverse()
        num_total_tiles = len(unrendered_tiles)
        for t in unrendered_tiles:
            g_tiles_to_render.put_nowait(t)
        # Spawn Render Client Threads, one for each ServerProxy
        print "spawning render client threads"
        self.spawnRenderClientThreads(g_server_proxies)
        # while the number of rendered tiles is less than
        # the total tiles, wait.
        while g_rendered_tiles.qsize() < num_total_tiles:
            time.sleep(3)
            # If any of the render threads need work,
            # assign some to them.
                # If we've run out of rendered tiles
            # scene_file must be just a filename, no directories
            scene_file = g_parser.getSceneFile()
            # Separate out the .pov extension.
            image_base_name = os.path.splitext(scene_file)[0]
            output_filename = image_base_name + ".png"
            g_pbmain.save(output_filename, "png", {})
            # Check that at least one render thread is alive
            num_threads_alive = 0
            for thr in self.renderClientThreads:
                if thr.isAlive():
                    num_threads_alive += 1
            if num_threads_alive == 0:
                print "all render threads have died. exiting Master Render
Thread.."
                break
            # If a render thread died, reclaim the tiles
            # it was working on and requeue them.
                if (not thr.isAlive()):
                    tiles = thr.getTilesInProgress()
                    for t in tiles:
        self.killRenderClientThreads()
        global g_start_time, g_stop_time
        g_stop_time = time.time()
        print "Master Render Thread is done"
        print ""
        print "- Render Stats
        total_time = g_stop_time - g_start_time
        print "  Total Render time: " + str(total_time) + "s"
        print
        print ""
    def spawnRenderClientThreads(self, server_proxies):
        for sp in server_proxies:
            self.renderClientThreads.append(RenderClientThread(sp))
            self.renderClientThreads[-1].start()
    def killRenderClientThreads(self):
        for t in self.renderClientThreads:
            t.stop()
    def stop(self):
class StatusDisplay:
    def __init__(self, server_proxies):
        # Create a list of dictionaries. One for each server.
        # These will contain the widgets that can be dynamically updated
        # as the info changes.
        #self.serverinfo = []
        self.widgets = {}
        for k in g_server_status.keys():
            gtk.threads_enter()
            entry_name = gtk.Entry()
            entry_name.set_editable(False)
            entry_name.set_text(k)
            entry_status = gtk.Entry()
            entry_status.set_editable(False)
            entry_status.set_text(g_server_status[k]['state'])
            entry_tq = gtk.Entry()
            entry_tq.set_editable(False)
            entry_tq.set_text(str(g_server_status[k]['tiles_queued']))
            entry_tr = gtk.Entry()
            entry_tr.set_editable(False)
            entry_tr.set_text(str(g_server_status[k]['tiles_ready']))
            self.widgets[k] =
            {'name_label':entry_name, 'state_display':entry_status,
             'tq_display':entry_tq,   'tr_display':entry_tr}
            gtk.threads_leave()
        # For each serverinfo entry create a horizontal row containing
        # info about the Server's state.
        gtk.threads_enter()
        #self.status_window = gtk.Window(gtk.WINDOW_TOPLEVEL)
        # Seem to need a global window, otherwise it doesn't
        # die when the program reaches the end, causing us to hang.
        self.status_window = g_status_window
        self.status_window.set_title("XRS Server Status")
        self.vbox = gtk.VBox(False,0)
        hbox = gtk.HBox(homogeneous=True, spacing=0)
        label_name  = gtk.Label("Server Name")
        label_state = gtk.Label("State")
        label_tq    = gtk.Label("Tiles Queued")
        label_tr    = gtk.Label("Tiles Ready")
        hbox.pack_start(label_name)
        hbox.pack_start(label_state)
        hbox.pack_start(label_tq)
        hbox.pack_start(label_tr)
        self.vbox.pack_start(hbox)
        for wk in self.widgets.keys():
            # Create a horizonal box to hold a row for a single server
status
            hbox.pack_start(self.widgets[wk]['name_label'])
            hbox.pack_start(self.widgets[wk]['state_display'])
            hbox.pack_start(self.widgets[wk]['tq_display'])
            hbox.pack_start(self.widgets[wk]['tr_display'])
            hbox.show()
            self.vbox.show()
        self.status_window.add(self.vbox)
        self.status_window.show_all()
        gtk.threads_leave()
    def refresh(self):
        global g_server_status
        gtk.threads_enter()
            x = g_server_status[wk]
            self.widgets[wk]['state_display'].set_text(x['state'])
            self.widgets[wk]['tq_display'].set_text(str(x['tiles_queued']))
            self.widgets[wk]['tr_display'].set_text(str(x['tiles_ready']))
        self.status_window.queue_draw()
        gtk.threads_leave()
class StatusDisplayThread(threading.Thread):
    def __init__(self, status_display):
        self.status_display = status_display
    def run(self):
            self.status_display.refresh()
            time.sleep(0.1)
    def stop(self):
import sys
g_parser = CommandLineParser(arglist=sys.argv[1:])
g_num_x_tiles = g_parser.getImgWidth()  / g_parser.getBlockSize()
g_num_y_tiles = g_parser.getImgHeight() / g_parser.getBlockSize()
print ""
print
print g_name + " version " + g_version
print "Python Megapov-XRS Client by George Pantazopoulos
http://www.gammaburst.net"
print
print ""
print "- Image Settings
print "  " + str(g_num_x_tiles) + "x" +
      str(g_num_y_tiles) + " tiles"
print ""
g_client_pov_basedir = g_parser.getBaseDir()
if (g_client_pov_basedir == None):
    raise "POV Base dir could not be located. Path must contain scenes/"
g_pbmain = 0
g_image  = 0
g_server_proxies = []
g_server_status = {}
gtk.threads_init()
InitGui()
# See Master Render Thread for when we stop the timer.
g_start_time = time.time()
print "- XRS Server settings
PrintServerSettings(g_server_urls)
# Create the Server Proxies, and weed out the unconnected servers
print ""
print "- Render Server Status
g_server_proxies = CreateServerProxies(g_server_urls)
print ""
print "Populating g_server_status"
for s in g_server_proxies:
    g_server_status[s.getUrl()] = {'state':'N/A', 'tiles_queued':0,
'tiles_ready':0}
print ""
g_threads = []
print "creating Master Render Thread"
masterRenderThread = MasterRenderThread()
print "Creating Display Thread"
displayThread = DisplayThread(g_tiles_to_display)
if g_enable_status_display:
    print ""
    print "Creating Status Display"
    g_sd = StatusDisplay(g_server_proxies)
    print "Creating Status Display Thread"
    statusDisplayThread = StatusDisplayThread(g_sd)
    g_threads.append(statusDisplayThread)
g_threads.append(masterRenderThread)
g_threads.append(displayThread)
print "Starting helper and work threads"
for t in g_threads:
    t.start()
print "main thread is going into gtk.main()"
gtk.threads_enter()
gtk.main()
gtk.threads_leave()
print "broke out from gtk.main()"
print "stopping threads"
for t in g_threads:
    t.stop()
print "issued stop commmands"
print "waiting for threads to finish"
for t in g_threads:
    t.join()
print "all threads finished"
print "reached end of main thread"
print "Exiting."
The intended application supports work in atmospheric physics. We hope to
improve atmospheric correction in sensor data.
Best,
Peter.
Date: 28 Nov 2006 22:00:00
Message: <web.456cb049e1423b92c0bad8570@news.povray.org>
>     import gtk
> in ?
>     from _gtk import *
Hi Peter,
   Try running "startxwin.bat" in the cygwin prompt first. It should open an
xterm window that looks different than the normal cygwin window. Try running
pyxrsclient in that shell window instead.
   I may have left that out of the instructions. Sorry 'bout that. Note that
your +o will be ignored by the client.
   Also, you don't need cygwin to run pyxrsclient. It should work
just fine with the Windows version of Python (use IDLE or Pythonwin). For
this, you'd need to have PyGTK installed into the Windows Python directory.
See the MegaPOV XRS site for links to all the dependencies.
   I'm real happy to hear how MegaPOV (will shortly) be helping you. Thanks!
I'm curious how would one use a rendering program to help calibrate
atmospheric sensors.
Rock on,
George
Warp-speed renders with MegaPOV XRS:
http://www.gammaburst.net/xrs
Date: 29 Nov 2006 19:55:00
Message: <web.456de3dfe1423b92f826bd4d0@news.povray.org>
Not being a physics type, I am not sure just what he is up to. He seems to
be more interested in raytracing than rendering. His goal is to improve the
calibration of sensor data correction programs, not the sensors themselves.
Eventually want to work with a native windows version. Started with cygwin
since that seemed to be what the documentation called for. This lets me
establish a baseline.
Managed to get startxwin.bat running. Had to modify one line at the top due
to the way cygwin is installed: SET CYGWIN_ROOT=C:\program_files\cygwin.
The xwindow came up with a cygwin prompt. In the pyxrsclient directory,
entered the following command: python pyxrsclient.py +Iwoodbox.pov +V +W800
+H600 +L/cygdrive/c/program_files/cygwin/tmp/povray-3.6.1/include. The
povray parameters are the ones used in successful povray and megapov tests.
Received the following error message (had to type it in so I hope it is
correctly presented:
File "pyxrsclient.py", line 877 in ?
File "pyxrsclient.py", line 131, in getImgWidth
AttributeError: 'NoneType' object has no attribute 'group'
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
