![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Is there any interest in 'PLANE' as a element of the BLOB object? I
introduced it in my private version when I tried to understand how
BLOB works.
It is not so overwhelming but easy to add.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> BLOB works.
Could you elaborate more on the benefits that a plane element brings to
the blob object. I don't really understand where an infinite object would
be useful in that application.
Ken Tyler
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Ken" <tyl### [at] pacbell net> wrote in message
news:40206423.80B7BCC8@pacbell.net...
> > BLOB works.
I can imagine it would be interesting as the "base" element of
a blob ensemble, you could do a plane with things "glued" into it.
Fabien.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 4 Feb 2004 10:57:22 +0100, "Fabien Mosen" <fab### [at] skynet be>
No need to "imagine", you can "see" it with:
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/docu02.html#BlobShape
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <d8d020phautc3e4t63p3rj823bjtpf5372@4ax.com>,
> BLOB works.
Are you aware of the existence of my blob2 patch? It uses a completely
different solver (currently a bisection solver like the isosurface
object uses), and will eventually support plane components (as well as
many other shapes), and it uses an improved falloff function that gives
smoother blobs.
Do you think you could add toroidal components? Or boxes and sharp-edged
cylinder and cone components? The latter two shouldn't be too hard if
you have planes working...
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> BLOB works.
Well, without any other BLOB element it is at least as useful as a
normal PLANE (assuming positive strength value).
In contrast to a normal plane, which divides space into two half
spaces, my plane as a BLOB element has a default thickness (affected
by scaling transformations), so it's equivalent to the intersection of
two anti-parallel planes.
Andreas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 04 Feb 2004 19:33:43 -0500, Christopher James Huff
>> BLOB works.
>smoother blobs.
Not yet. I'll have a look.
You're going to become a manager aren't you ;)
(... shouldn't be too hard ...)
Don't call me, I'll call you :-)
Andreas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> > BLOB works.
(^^^^^^^^^^^^^ You are afraid of Ken, too?)
Just what I thought. (May be I'll be one of the craftspeople providing
the tools, I probably will not be the artist using them).
Andreas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <lhi520p13vl2q8tna8aomgh6n9mgmjm375@4ax.com>,
I hope not...
Heh...well, a box is essentially six plane components with some
clipping. And sharp edged cones/cylinders would involve capping with
plane pieces rather than sphere pieces. The blob2 patch supports these
partially...still a few kinks to work out.
Other ideas: rounded box, superellipsoid, a third kind of cone/cylinder
component with torus-rounded edges, meshes...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 05 Feb 2004 18:38:39 -0500, Christopher James Huff
Oh, oh.
Given a plane (with some thickness as I used it as a BLOB_ELEMENT):
- Intersection: you only have to check where the ray enters/exits the
space of influence ~= distance to the plane's origin.
- Normal: trivial
- Inside: trivial
Now take an arbitrary object:
What is the reference point/plane/surface/... and/or metric in space
to compute the 'field value' which in the end defines the surface of
the element?
If we can provide a consistent solution for a special object type I
would agree, it is not hard to add it (to BLOB).
Let's talk about it, may be we can create some 'tools' for the artists
Andreas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
