POV-Ray : Newsgroups : povray.unofficial.patches : OpenGL wireframe preview patch available Server Time
16 Mar 2026 15:07:31 EDT (-0400)
  OpenGL wireframe preview patch available (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: OpenGL patch update (June 14/2003)
Date: 15 Jun 2003 19:06:48
Message: <3eecfc08$1@news.povray.org>
> > Plane objects draw using a light gray color
> > to avoid competing with other objects.
> Have you considered using quick_color to define the color for OpenGL
> drawing?
That'd be an option, certainly, especially when
doing solid OpenGL drawing. I wouldn't want to
force it because sometimes you need a constant color
for wireframes, e.g., when making mask overlays.
Ray
Date: 15 Jun 2003 19:27:15
Message: <3eed00d3$1@news.povray.org>
> > Yeah, that file's camera is a tough one for the
> > wireframer to handle. Anything that uses "look_at",
> > actually, is likely to be off. I have to keep
> > working on the camera support.
> You should be able to translate any perspective or orthographic camera
> pretty directly into OpenGL...what are you doing that makes it so hard?
> Just let the existing code parse the camera, and use the values it comes
> up with.
I'm calling gluPerspective() and gluLookAt().
I haven't had time to get into explicitly
setting up the OpenGL projection and modelview
matrices.
But that's the charm of open source -- if it
bothers you so much, and it's so simple to
you what the solution is, then you don't have to wait
for me to "enter the matrix." :)
Ray
Subject: OpenGL patch update (June 15/2003)
Date: 15 Jun 2003 23:08:53
Message: <3eed34c5$1@news.povray.org>
Camera problems have been fixed.
Any POV-Ray perspective camera should work now,
except those with inverted vectors such as rad_def_test.pov,
which will appear flipped horizontally.
Bezier patch had a missing default wireframe method; fixed
(doesn't make it draw nicely, but stops crashing).
Source: http://www.daylongraphics.com/other/povray/patches/povgl.zip
Binary: http://www.daylongraphics.com/other/povray/patches/povglbin.zip
Ray Gardener
Daylon Graphics Ltd.
"Heightfield modeling perfected"
Subject: Re: OpenGL patch update (June 15/2003)
Date: 16 Jun 2003 03:35:37
Message: <3eed7349@news.povray.org>
  Does it also work when using transformations in the camera?
  That is, something like this:
camera
{ angle 35
  translate -z*10
  rotate <35, -40>
  Moreover, a matrix transformation can be applied to the camera, which
can shear the camera.
  It's possible and easy to apply these same transformations in OpenGL
as well (even the skewing ones).
Subject: OpenGL patch update (June 16/2003)
Date: 16 Jun 2003 07:07:06
Message: <3eeda4da$1@news.povray.org>
> camera
> { angle 35
>   translate -z*10
>   rotate <35, -40>
Yes, you can do that now. The "Angle" member of the CAMERA struct
is totally ignored now, and the gluPerspective FOV is computed
strictly from the camera's vectors (the vectors are also the
only thing POV's perspective camera uses, so we have closer
behavioral parity now). I also defaulted the OpenGL camera
using a POV cam minted with Create_Camera(), so a scene without
a camera should render okay too.
These are not supported yet. Eventually I will compose
the OpenGL projection matrix directly, since it is the
more elegant solution. One remaining issue is that
the OGL projection is always off by a few pixels,
moreso for objects farther away from the line of sight
(i.e., the center of the render window), and I'm
guessing it's a loss-of-precision problem stemming
from OGL having to concatonate the projection matrix
with the modelview matrix for each object. OGL is also
working with a unit-length frustrum depth, while POV's is
much larger, so using a different Z divide might be
necessary. But I don't know if that will cause depth buffer
problems, because OGL depths are supposed to be normalized.
But for a preview, it's getting good. I've tried a lot
of the sample POV scenes, and only a handful have
inversion problems; of the rest, all one has to do
is make sure the camera is declared before other objects,
and that's that (usually about 10-30% of the scenes
need that done). In the future, I'll probably wireframe
after parsing instead of during, since that will lift
the make-the-camera-first requirement, and make it easier
to turn the wireframe into a quality setting and use
it to make wireframed animations. I was also thinking
that solid OGL would be a quality step one higher,
so overall the quality levels would be
   OGL wireframe
   OGL solid ambient
   OGL solid w/ lighting
   Raytraced quality levels 0, 1, etc.
What would be really nice is if a wireframe animation is only
moving the camera, then I could persist the object tree in
memory across frames, which will make frames #2 and above
render ultra fast since they can skip the parsing. In fact,
some scenes would wireframe in realtime, so you could
have an .ini file actually "play" a wireframe (or even OGL solid)
movie right on the spot from within WinPOV. Sweet!
Other news:
bicubic/bezier patches tesselate better,
box and disc primitives tesselate, and non-union CSG
groups will recurse towards leaf nodes to call their
specific wireframers (untested). Union CSGs were already
"flattened" into leaf nodes by the parser. A good example
is teapot.pov (but you have to move the camera statement
behind the #include "teapot.inc" line).
allobjects.ini also renders without stopping, so I
think all the primitives have wireframe methods now.
The patches are ID'd with build timestamps when
WinPOV starts up, in the Messages pane, to make
identifying them easier.
Ray
Subject: Re: OpenGL patch update (June 16/2003)
Date: 16 Jun 2003 07:33:12
Message: <3eedaaf7@news.povray.org>
An idea:
  Clicking and dragging on the preview window, perhaps with some hotkey
pressed (as to not to interfere with the partial preview selection)
could rotate the OpenGL camera around the look_at point. This way you
could quickly view the wireframe of the object/scene from different
sides without having to edit the scene file itself. Perhaps with another
hotkey the camera distance from the look_at could be modified.
  If you have ever used Moray, you'll know what I'm after.
Date: 16 Jun 2003 10:58:59
Message: <3eeddb33$1@news.povray.org>
3eedaaf7@news.povray.org...
>   An idea:
I wholly second this idea. To be honest, I still don't see the point of an
OpenGL preview as it is. My tests with the patch resulted in a totally
useless and very black tangle of wireframe lines... But a shadowed view (not
wireframe) with quick color and the ability to walk through the scene would
certainly be a big plus. Add the ability to zoom/pan and to jump back to the
main camera position(s), like in a VRML browser, and this will actually help
scene design. Of course, once this gets done, people will start asking for
the ability to move things around, and then to scale them, and then Ray will
end up creating a modeller!
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 16 Jun 2003 12:40:31
Message: <3EEDF2FE.C3279B65@gmx.de>
That will diminish the usability of your patch quite a lot - various
sample scenes from the official distribution (particularly most i made
:-)) work this way - same applies for scenes generated by Moray AFAIK.
I agree with Gilles that the use of a quick preview is not very
significant without 'interactive' features - those would be difficult (but
not impossible) to implement in a portable way of course.  If it's just
the static preview it does not matter much if it takes 0.1 seconds or 1
second - this can be achieved with raytracing as well when you reduce
quality of the result.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Subject: Modeler within POV-Ray
Date: 16 Jun 2003 13:28:45
Message: <3eedfe4d$1@news.povray.org>
>... Of course, once this gets done, people will start asking for
will
Yeah... yeah. That'd be neat.
For objects that are explicitly instanced, an
extra object member var could store which file and line
created it. Then double-clicking the displayed object would
scroll the .pov file to that point in the editor.
I also like that idea of raytracing single objects.
Click an object, hit a key, and it tells the raytracer
to render the region bounding the object's screen projection.
Or better still, raytraces just the object itself.
Ray
Date: 16 Jun 2003 15:28:37
Message: <3eee1a65@news.povray.org>
  I said "wireframe" but was really talking about any type of OpenGL
preview, be it wireframe or shaded triangles or whatever.
  And besides, a wireframed still image may look very cluttered, but
when the camera is moved, it helps visualizing objects a lot.
