POV-Ray : Newsgroups : povray.tools.poser : Future implementations of Poseray. A wish list Server Time
30 Mar 2026 02:58:06 EDT (-0400)
  Future implementations of Poseray. A wish list (Message 13 to 22 of 22)
Subject: Re: Future implementations of Poseray. A wish list - an additional wish
Date: 3 Nov 2009 12:00:17
Message: <4af061a1$1@news.povray.org>
Thomas de Groot wrote:
> "clipka" <ano### [at] anonymousorg> schreef in bericht
> news:4aef52aa@news.povray.org...
>> Why? It only complicates matters; for instance, if you want to use
>> different include files for different frames of an animation, having the
>> same figure carry the same name is of an advantage.
>> If it is about getting two figures of same base name in a single scene, it
>> may be easier, too, as in:
>> #declare MyFigures = array[10];
>> #local i = 1;
>> #while (i <= 10)
>>   #include concat("Beggar", str(i,0,0), "_POV_geom.inc");
>>   #declare MyFigures[i-1] = object { Beggar_ }
>>   #local i = i + 1;
>> #end
> Well, it seems inconsistent to me. If I change the name of the file for one
> reason or another (for instance because I changed the materials but want to
> keep the original too at the same time), I expect the name of the figure to
> change too in order to avoid inconsistencies and confusion later in the POV
> scene.
> Your example is of course also valid, so maybe this change should be
> optional.
> Thomas
I will look into making it optional if it relatively easy to do.
FlyerX
Subject: Re: Future implementations of Poseray. Place of uv_mapping code
Date: 12 Nov 2009 04:40:18
Message: <4afbd802$1@news.povray.org>
It appears that the place were the uv_mapping code is placed in the latest
version of Poseray generates a faulty rendering of transparant materials.
In the present version, uv_mapping is coded in the xxxx_POV_mat.inc file as
follows:
#declare MyTex_=
material{
texture{ pigment{uv_mapping p_map1}
        finish{specular 0 roughness 0.00286312 ambient rgb <0.00,0.00,0.00>
diffuse 0.8   reflection{0 } conserve_energy}}
or, in the case of a transparancy map:
#declare MyTex__opaque=
        normal{uv_mapping p_map2 bump_size -6.192}
#declare MyTex_=
material{
texture{  pigment_pattern{uv_mapping p_map3}
texture_map{[0 pigment{Clear}]
            [1 MyTex__opaque]
In particular the alpha channel of the first example does *not* work for the
shadow casting. In order for this to work in all cases, the code should be
written as in a previous version of Poseray, i.e. the uv_mapping code is
written in the xxx_POV_geom.inc file and *not* in the xxx_POV_mat.inc one.
As follows:
//Model assembly from the meshes
#declare My_Figure_=
union {
object{My_Figure_1_  uv_mapping material{MyTex_1_}}
object{My_Figure_2_  uv_mapping material{MyTex_2_}}
etc...
This construction provides a correct render of the transparancy of the alpha
channel.
Date: 12 Nov 2009 05:38:17
Message: <4afbe599@news.povray.org>
> union {
> etc...
> channel.
> Thomas
I see your point but as I do never use the material files as generated
by PoseRay this would force me to also edit the geometry file every time
I convert an object file. I *need* separate control about the pigment or
normals or both being uv_mapped for multiple reasons.
A solution that should help us both would be to put the uv_mapping
statement directly into the texture block and not into the
pigment/normal blocks like:
material {
     uv_mapping
     pigment {MyPigment}
     normal {MyNormal}
As far as I do remember this does also solve the transparency by alpha
channel problem.
-Ive
Date: 12 Nov 2009 08:22:01
Message: <4afc0bf9@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4afbe599@news.povray.org...
> I see your point but as I do never use the material files as generated by
> PoseRay this would force me to also edit the geometry file every time I
> statement directly into the texture block and not into the pigment/normal
> blocks like:
> material {
>   texture {
>     uv_mapping
>     pigment {MyPigment}
>     normal {MyNormal}
> channel problem.
Yes indeed. This is also the solution proposed by Clipka by the way and it
is certainly more elegant. My suggestion was just a step back to an earlier
version, but I admit that it is not the most ideal.
When using a transparency map instead of using the alpha channel, the code
in Poseray should then also be as follows (note the place of uv_mapping)
e.g.:
//Material definitions
#declare MyTexTex__opaque=
  uv_mapping
  pigment { p_map1}
  normal {MyNormal}
  finish {MyFinish}
#declare MyTexTex_=
material {
    uv_mapping
    pigment_pattern { p_map2}
    texture_map {
      [0 MyTex__opaque]
      [1 pigment {Clear}]
Date: 12 Nov 2009 08:26:07
Message: <4afc0cef$1@news.povray.org>
OK. To reduce confusion as I typed twice the same term:
  uv_mapping
  pigment { p_map1}
  normal {MyNormal}
  finish {MyFinish}
#declare MyTex_=
material {
    uv_mapping
    texture_map {
      [0 MyTex__opaque]
      [1 pigment {Clear}]
Date: 12 Nov 2009 12:23:33
Message: <4afc4495@news.povray.org>
> e.g.:
> texture {
>   uv_mapping
>   pigment { p_map1}
>   normal {MyNormal}
>   finish {MyFinish}
> #declare MyTexTex_=
> material {
>   texture {
>     uv_mapping
>     texture_map {
>       [0 MyTex__opaque]
>       [1 pigment {Clear}]
As a side note, usually I do use a construct like this:
#local MyTexTex_opaque =
    uv_mapping
    pigment { p_map1}
    normal {MyNormal}
    finish {MyFinish}
#local MyTexTex_trans =
    uv_mapping
    pigment { p_map1 transmit 1}
    normal {MyNormal}
    finish {MyFinishButWithoutAnySpecularPhongAndReflection}
  #declare MyTexTex_=
  material {
      uv_mapping
      texture_map {
        [0 MyTex_opaque]
        [1 MyTex_trans]
This does not make *much* of a difference but occasionally for closeup
shots and things like lace pattern or trans-mapped hair it looks better.
-Ive
Date: 12 Nov 2009 15:34:38
Message: <4afc715e@news.povray.org>
I put the uv_mapping inside the pigment and normal for more control. As
shown in the POV-Ray manual it can inside or outside of these
statements. I did not notice a problem because I have not used textures
with alpha channels in a very long time. Automatically putting
uv_mapping outside the pigment and normal should not be a problem.
Thanks for the suggestions.
The material structure has changed significantly in format in the latest
PoseRay because it now supports specular and transparency mapping at the
same time. Also I dropped the use of the predefined Clear pigment with
transparency mapping since I was having problems with it. I replaced it
by color rgbft<0,0,0,1,1>. I do not remember exactly the reason (I will
have to review my notes) but I believe the transparency at the edges was
not working well with Clear.
I will try to release a preliminary version of PoseRay this week since
it has some of the many changes that were suggested in this forum plus
other fixes.
Below are samples of the new PoseRay-generated materials. They have the
transformation at the end of each map. If any of you see anything wrong
with them please let me know (besides the uv_mapping issue). Most likely
I will have to define the textures before plugging them into the
texture_map entries so that uv_mapping could be placed outside the pigment.
pigment only:
http://mysite.verizon.net/sfg0000/files/p.txt
pigment only but multiplied by a color:
http://mysite.verizon.net/sfg0000/files/p_m.txt
pigment+transparency:
http://mysite.verizon.net/sfg0000/files/p_t.txt
pigment+finish+normal+transparency:
http://mysite.verizon.net/sfg0000/files/p_n_f_t.txt
pigment+finish+normal:
http://mysite.verizon.net/sfg0000/files/p_n_f.txt
pigment+normal:
http://mysite.verizon.net/sfg0000/files/p_n.txt
FlyerX
>> code in Poseray should then also be as follows (note the place of
>> uv_mapping) e.g.:
>> texture {
>>   uv_mapping
>>   pigment { p_map1}
>>   normal {MyNormal}
>>   finish {MyFinish}
>> #declare MyTexTex_=
>> material {
>>   texture {
>>     uv_mapping
>>     texture_map {
>>       [0 MyTex__opaque]
>>       [1 pigment {Clear}]
>  texture {
>    uv_mapping
>    pigment { p_map1}
>    normal {MyNormal}
>    finish {MyFinish}
>  texture {
>    uv_mapping
>    normal {MyNormal}
>  #declare MyTexTex_=
>  material {
>    texture {
>      uv_mapping
>      texture_map {
>        [0 MyTex_opaque]
>        [1 MyTex_trans]
> -Ive
Date: 13 Nov 2009 04:57:15
Message: <4afd2d7b@news.povray.org>
"FlyerX" <fly### [at] yahoocom> schreef in bericht
news:4afc715e@news.povray.org...
>shown in the POV-Ray manual it can inside or outside of these statements. I
>did not notice a problem because I have not used textures with alpha
>channels in a very long time. Automatically putting uv_mapping outside the
>pigment and normal should not be a problem. Thanks for the suggestions.
Youa re welcome :-)
> transparency mapping since I was having problems with it. I replaced it by
> color rgbft<0,0,0,1,1>. I do not remember exactly the reason (I will have
> to review my notes) but I believe the transparency at the edges was not
Ah yes. I think that I have noticed that as a side effect indeed.
> I will try to release a preliminary version of PoseRay this week since it
> has some of the many changes that were suggested in this forum plus other
> fixes.
Great! Looking forward to it!
> with them please let me know (besides the uv_mapping issue). Most likely I
> will have to define the textures before plugging them into the texture_map
> pigment only:
- I am not sure if a diffuse 1 is such a good idea. I prefer 0.6, or 0.8
when using an image map, like in the current version .
- Why a *double* declare for the pigment? It seems to me that only one
should be enough, either PR_MAP_DIFFUSE or PF (well, I see some consistency
now with the other pigments)
- Neat! I like this. I believe that this will work much better than the
current, rather crude, texture layering.
- OK. I see the change from Clear. Certainly works better.
- This is a difficult one. I need to test this to see how it works. My first
impression is that it looks fine however.
- Same as above.
> pigment+normal:
- I think you put the wrong example file here. No normal visible.
Looking good overall. I am thrilled!
Date: 13 Nov 2009 11:51:14
Message: <4afd8e82@news.povray.org>
> Youa re welcome :-)
>> fixes.
>> pigment only:
> - Same as above.
>> pigment+normal:
> Thomas
Fixed the pigment+normal sample. The double pigment comes from the color
multiplication. To avoid extra coding I just left it as is in case the
material has other layering. It is wasteful and I will look into
cleaning that up.
FlyerX
Date: 14 Nov 2009 03:34:19
Message: <4afe6b8b$1@news.povray.org>
news:4afd8e82@news.povray.org...
> material has other layering. It is wasteful and I will look into cleaning
> that up.
Looking good. I think this is going to be a major improvement of Poseray.
Maybe others will come up with further comments, but at this stage I see
nothing wrong. A little testing round later may of course bring up
something.
