POV-Ray : Newsgroups : povray.pov4.discussion.general : A view more ideas Server Time
10 Jan 2026 05:36:35 EST (-0500)
  A view more ideas (Message 1 to 10 of 16)
Subject: A view more ideas
Date: 16 Jan 2008 08:30:02
Message: <web.478e05b48b8be34ecdd74ce00@news.povray.org>
Hi people,
I've thought about a few nice features, I would like to see in PovRay:
- A camera map_type. That makes is possible to render background images by using
the sky_sphere.
- A camera_plane to measure distances for DOF.
- Blurred reflection
- 3D-pattern in fog (with a maximum distance for the pattern, to prevent endless
pattern calculations)
- A pre_pass2bin function: This function save a binary file, of what is parsed.
This is help full when making a low-resolution test rendering. If you like the
rendering, just "parse" the binary file. (Sometimes I have to wait longer for
the parsing, but for the rendering)
- Motion blur: by giving a translation_vector for normal objects or cameras. And
for the mesh2 object a motion-vector-block, define each vertex motion.
- Fresnel pattern
- Additional channels like z, alpha, normal...
- A low-level syntax for programming shaders (something like PovMan maybe..)
Hope there is one or two things, you also like :)
Holger
Subject: Re: A view more ideas
Date: 16 Jan 2008 08:39:26
Message: <478e090e@news.povray.org>
> the sky_sphere.
  How exactly would that work?
  I'm not sure how that would work either.
  Already possible. (See eg. http://warp.povusers.org/pics/RubiksRevenge2.jpg )
  How is that different from media?
  One reason for creating pov4 has been to making it easier to export and
import things.
Date: 16 Jan 2008 09:10:00
Message: <web.478e0ec649ba4740cdd74ce00@news.povray.org>
The camera "projects" the mapping to the object: lower left corner of the
rendered image is uv:<0,0> on the object, upper right is uv:<1,1>
The camera_plane works the same way: its an object, that has exactly the size of
the projection_plane. By increasing the distance, the camera_plane will become
bigger (in normal cases) to fill up the picture. Its always orientated to the
camera and has llc uv:<0,0> and urc uv:<1,1>
Ups.. didn't know this. How is the syntax for this?
> > - 3D-pattern in fog...
A media is a clipped_by a object. It would be very easy, just to put a pattern
inside the fog statement.
> import things.
Sounds cool :)
Date: 16 Jan 2008 09:15:00
Message: <web.478e115449ba4740f48316a30@news.povray.org>
I'd like to see more developers first and foremost.
Importing binary mesh formats would be nice too.
Exporting media densities another plus.
Tesselating isosurfaces to polygons would be cool.
How about a plane negative component for blobs?
Programmable shaders is nice and a more modular SDL.
Path tracing anyone?
but really povray is in bad need of a Steve Ballmer and his mantra...
"developers, developers, developers"
Date: 16 Jan 2008 10:19:49
Message: <478e2095@news.povray.org>
  I still didn't fully understand. :(
  There's no syntax. There's a technique to achieve it (IIRC it was first
discovered by Ron Parker). It's describe here:
http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
Date: 16 Jan 2008 15:10:01
Message: <web.478e643649ba47407d55e4a40@news.povray.org>
Isn't it a bit early? From what I see here the requirements for POV 4 aren't
anywhere near known, and until they are you don't need programmers.
Tom
Date: 17 Jan 2008 08:02:38
Message: <478f51ee$1@news.povray.org>
I understood it to mean texture coordinates generated from the screen
coordinates.  Like a projector at the camera point projecting a texture into
the scene.
Could be tidied up into just 1 or 2 extra paremeters inside the reflection{}
block though?
Date: 17 Jan 2008 11:37:10
Message: <478f8436@news.povray.org>
> block though?
  With the same flexibility? Hardly.
Date: 17 Jan 2008 12:00:01
Message: <web.478f88a949ba4740773c9a3e0@news.povray.org>
No programmers also mean povray 3.7 in beta status for a few more years and
povray 4 nowhere in sight.  Povray needs developers, not offtopic whinners.
Date: 17 Jan 2008 12:40:00
Message: <web.478f92b449ba47407d55e4a40@news.povray.org>
I can't find anything about more developers being wanted for 3.7 on
www.povray.org, which might be one reason why there's any shortage. I didn't
even realise you could apply to work on 3.7 - are you entirely sure about this?
Tom
