POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
4 Mar 2026 15:39:29 EST (-0500)
  New LuxRender web site (http://www.luxrender.net) (Message 51 to 60 of 175)
Subject: Re: Brute force renderers
Date: 20 Feb 2008 14:39:43
Message: <47bc81ff$1@news.povray.org>
Gilles Tran wrote:
> Tie this with the SDL and the ability to render directly from Blender and
> then we'd have a killer product...
the povanim script works just fine with Blender.  It comes with a nice
settings graphical interface and I usually just export to pov files, but
you can also directly call povray to render it.
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 20 Feb 2008 14:45:00
Message: <47bc833c@news.povray.org>
Orchid XP v7 wrote:
> "LuxRender is better than POV-Ray" is an opinion.
are you suggesting I said that?  can you point it out, then?
> I didn't say POV-Ray *is* better - I just asked you not to call people
> names when they suggest that it might be. People have opinions. That
> doesn't mean that anybody with an opinion different to yours is stupid.
like I said, photorealism is not a matter of opinion.
> False, as demonstrated. Sometimes things "look" wrong when they are in
> fact physically correct.
like?...
of course, photorealism originally meant "realist like a photo" and this
is not quite what raytracers and other renderers mean by it.  Because if
they did, perhaps they should include lens distortion, glare and other
effects only really seen through photographic lenses...
Date: 20 Feb 2008 14:47:46
Message: <47bc83e2$1@news.povray.org>
Sure it is.  It all depends on one's perception of the image.  You might
look at an image and say "gee, that looks really photorealistic", and I
might respond "are you on drugs?  Look at that shadow, that's clearly not
right".  You might disagree about that particular shadow (whatever it is).
Have you ever been to a movie with someone who thinks the CG effects are
outstanding and "the most realistic effects they'd ever seen", only to
tell them that they were crap effects?
Same principle.
Jim
Date: 20 Feb 2008 14:53:33
Message: <47bc853d$1@news.povray.org>
> You can do nothing at all about
> aliasing of edges against very bright backdrops.
Yes you can, go back to a POV-Ray version that clipped colors *before*
antialiasing.
Date: 20 Feb 2008 15:01:25
Message: <47bc8715$1@news.povray.org>
if I saw at a sharp shadow and said it was photorealistic, I'd sure be
on drugs. ;)
People's opinions on whether something is photorealistic is irrelevant
as to whether it is or not.  The only way to test it out would be to
take a photo, model a scene similar to it and render.  Then diff the
render and the photo.
Date: 20 Feb 2008 15:09:52
Message: <47bc8910@news.povray.org>
>> might look at an image and say "gee, that looks really photorealistic",
>> and I might respond "are you on drugs?  Look at that shadow, that's
>> clearly not right".  You might disagree about that particular shadow
>> (whatever it is).
> on drugs. ;)
Now I didn't necessarily say a sharp shadow, did I?
>> are outstanding and "the most realistic effects they'd ever seen", only
>> to tell them that they were crap effects?
I've seen photos that don't look photorealistic to me.  It most certainly
is a matter of opinion.
You might opt to take a - shall we say - religious view towards your
correctness; that doesn't mean you're right. ;-)
Jim
Date: 20 Feb 2008 15:17:07
Message: <47bc8ac3@news.povray.org>
I'd say that's a technical stance.
Date: 20 Feb 2008 15:27:47
Message: <47bc8d43$1@news.povray.org>
You measure photorealism in one way - and that's fine.  Doesn't mean
that's the way everyone measures it.
For one thing, your view of photorealism depends on the scene actually
being able to be photographed.  So, for example, how would you do a
photorealism check on, say, Battlestar Pegasus?
Jim
Date: 20 Feb 2008 15:50:00
Message: <web.47bc9197983c54177d55e4a40@news.povray.org>
>   Am I incorrect if I get the impression that these unbiased renderers
> offer nothing else than unbiased rendering? In other words, even the
> simplest of scenes will take hours to look ungrainy, no matter what
> you do?
I know of at least one (Kerkythea) that supports unbiased rendering as well as
other methods; you select the rendering algorithm you want to use from a list,
which includes conventional raytracing. You can't mix methods within the same
render, of course.
I don't find it surprising that most of these apps focus on one particular
rendering algorithm, though, considering the effort it takes to get even one of
them right, with features that make such apps useful.
Tom
Date: 20 Feb 2008 16:30:56
Message: <47bc9c10$1@news.povray.org>
nemesis wrote:
> Or you can just buy top hardware, model, texture and drop accurate
> lighting in your scene and let an unbiased rendering method handle it
> overnight.
If you buy top hardware, model, texture, and drop accurate lighting in
your scene, PoV can do it, too.
The trick is the accurate lighting.  It's not impossible to do in PoV.
And sometimes, you want something that's intentionally inaccurate.
(Ever put a diffuse value of, say, 1000 on a texture in a radiosity
scene?  How about negative-intensity light sources?  Negative value for
fade power?)
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
