POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
21 Mar 2026 10:45:51 EDT (-0400)
  New LuxRender web site (http://www.luxrender.net) (Message 136 to 145 of 175)
Subject: Re: Brute force renderers
Date: 21 Feb 2008 15:12:04
Message: <47bddb14$1@news.povray.org>
Jim Henderson wrote:
> Ah, so you've decided Darren and I were right after all, then? ;-)
yes, now I'm a satanist. :P </sarcasm>
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 21 Feb 2008 15:13:45
Message: <47bddb79$1@news.povray.org>
Orchid XP v7 wrote:
> As best I can tell, the algorithm described just sounds like POV-Ray's
> radiosity with an infinitely low error_bound. (I.e., always resample.)
> But applied to *all* terms, not just diffuse illumination...
That's the key. I'm not too sure POVRay's radiosity gives an unbiased
result even with all settings turned up to the best quality. If there is
just one reflective surface in the mix I'm downright sure it does not...
Even throwing photons in I believe there are situations POV will not
handle correctly. Can we do a wall lighting one side of a room because
it is itself lit by a light reflecting in a mirror?
Yeah, I should try myself :-)
Vincent
Date: 21 Feb 2008 15:22:52
Message: <47bddd9c$1@news.povray.org>
"Light shines onto a white diffuse wall. Reflected light from the wall
creates caustics through a glass sphere. That is diffuse -> Specular
(caustics). I got the idea for this scene from a document by Henrik Wann
Jensen describing some difficult test scenes."
http://www.winosi.onlinehome.de/Gallery_t15.htm
Date: 21 Feb 2008 15:27:31
Message: <47bddeb3$1@news.povray.org>
Ah yes now I remember seeing this one... Well it is expected that
unbiased renderer are able to tackle this, of course...
Vincent
Date: 21 Feb 2008 16:05:51
Message: <47bde7af@news.povray.org>
I do recall somebody rendered a radiosity scene with no photon maps at
all, and yet a large curved mirror still produced correct caustics. (It
was a damn long time ago now though, so I'd never be able to find the
image...)
Radiosity ought to do it - although it may or may not require some
fairly crazy settings...
http://blog.orphi.me.uk/
Date: 21 Feb 2008 16:11:40
Message: <47bde90c@news.povray.org>
don't forget higher than 1600 count limit...
Date: 21 Feb 2008 16:13:59
Message: <47bde996@news.povray.org>
  Except that POV-Ray doesn't have the concept of BRDFs.
  Also, brute-force renderers take a slightly different approach at
rendering than POV-Ray's radiosity. What the latter does is that when
a ray intersects a surface, it sends tons of rays to all directions
(unless it can interpolate from nearby values calculated earlier).
AFAIK brute-force renderers only send one ray to a random direction.
This means that a ray hitting a surface doesn't spawn a thousand new
rays, but only one.
  There are advantages and disadvantages with this. The advantage is that
the renderer never gets stuck on things like highly reflective/refractive
objects because it's only following one path, not thousands (each one of
which in turn would spawn thousands of new paths, etc). Another advantage
is that you don't have to fix a number of rays to send per intersection
point, but you can simply let it run for as long as you want.
  The disadvantage is the graininess, of course. Overall, however, the
correct result is approached faster in this way than with the method
POV-Ray uses. (This is assuming we are looking for the perfect solution.)
Date: 21 Feb 2008 16:22:47
Message: <47bdeba7@news.povray.org>
I think another advantage is it works well with deadlines. Instead of
worrying if you'll finish the render by the IRTC deadline, you just let
it run till the last minute. It may be more or less grainy, but at least
you have the whole image. With a normal raytracer, you'd have the top
half of the image...
Date: 21 Feb 2008 16:26:10
Message: <47bdec72$1@news.povray.org>
>> is just one reflective surface in the mix I'm downright sure it does
>> not...
> image...)
Well, strange...
In the docs it is written:
The brightness of radiosity in POV-Ray is based on two things:
    1. the amount of light "gathered"
    2. the 'diffuse' property of the surface finish
<http://www.povray.org/documentation/view/3.6.1/270/>
So it seems pretty clear that radiosity does not take the specular path,
ever, because the "reflection" property is not considered. Which means
that rays doing:
Light->specular->diffuse->diffuse->camera (the situation I described)
or Light->diffuse->specular->diffuse->camera (as in the image Nicolas
posted)
are never created.
But if there is a scene proving me wrong I'd be glad to see it.
Vincent
Date: 21 Feb 2008 16:28:26
Message: <47bdecfa$1@news.povray.org>
Ah, then you didn't understand our point. ;-)
Jim
