POV-Ray : Newsgroups : povray.off-topic : Whoot! First video game Server Time
10 Jul 2026 22:53:20 EDT (-0400)
  Whoot! First video game (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Whoot! First video game
Date: 7 Jan 2011 04:00:07
Message: <4d26d617$1@news.povray.org>
> Wow. Not even a single remark? Poop.
Yes, you need a windows version, I guess most of us in here don't have
an xbox.  But it's cool you finished a game and people are buying it - I
wish I could ever find the motivation and time to get to that stage!
Date: 7 Jan 2011 05:54:03
Message: <4d26f0cb@news.povray.org>
Nekar Xenos <nek### [at] gmailcom> wrote:
> Hmm, I wonder if it would be possible to port Pov-Ray to X-Box ;)
  I think the xbox360 limits quite a lot what files you can transfer to
and from it, so it could prove difficult to transfer any .pov files to
it so that it could render them.
  You could write a text editor for the povray port (the xbox360 supports
USB keyboards), but that would be quite a bit of work. (And it would also
mean that you can only render what you write directly.)
Date: 7 Jan 2011 10:18:35
Message: <4d272ecb@news.povray.org>
Am 07.01.2011 08:30, schrieb Nekar Xenos:
I bet.
Essentially all you'd need is a C++ compiler for that thing, then you're
in business. Would need a new front-end of course - I don't think the
X-Box knows what a command line is; or does it, Darren?
Date: 7 Jan 2011 12:27:41
Message: <4d274d0d$1@news.povray.org>
Nekar Xenos wrote:
> Are you going to make a windows version as well so we can try it  out?
Well, technically, it's already a Windows version as well. You just need to
install the compiler to get enough of the runtime. My next task is upgrading
the compiler to the latest version (since people are starting to release
games with the new compiler and the old compiler won't deal with the forward
compatibility), after which I might very well take the time to #ifdef in
Windows support.
With lots and lots of work.  The amateur xbox games have to be written in
C#, not C++. And there isn't a whole lot of memory on the xbox (512M if I
remember?)
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 7 Jan 2011 12:31:26
Message: <4d274dee$1@news.povray.org>
Again, speaking only of the amateur xbox stuff (aka XNA), there is sadly no
good way to get any files on or off. The program can only network to other
instances of the same program running at the same time, and it can only read
files it created itself. (Part of the security MS imposed to let you put
software on their machine that they haven't vetted.)
> USB keyboards),
I'm not even sure XNA will read the keyboard. It would read the chatpad, but
that's like coding pov-ray files on your cell phone's keyboard.
   Serving Suggestion:
Date: 7 Jan 2011 12:38:36
Message: <4d274f9c$1@news.povray.org>
> I bet.
Honestly, all I've touched is the XNA, which is only C# (because it's
safety-enforced and controlled), not C++. The commercial companies are using
C++ for games like Batman or Half-Life, of course, but I think to do that
you need like a special XBox that doesn't enforce the security, along with
I'm sure complex contracts with Microsoft to get one and such. (That's how
the other platforms work, at least.)
Given that, I don't know if it has a CLI or not. On the other hand, I'm not
sure why you'd need a CLI anyway.  And given that, a GUI with a text-entry
box is a CLI. :-)
But I don't know if the XBox is running something like a Windows shell or
CLI inside, or whether the shell is canibalized enough that you only get the
dashboard even while you're developing.
   Serving Suggestion:
Date: 7 Jan 2011 12:40:04
Message: <4d274ff4$1@news.povray.org>
OK, how many people have an xbox controller for their PC? That's really more
of a problem than making it run under Windows without the compiler
installed. That's a whole another remapping of stuff.
(Of course, in this game, I'm not really using analog joysticks or anything,
so polling the keyboard could be trivially mapped to the buttons on the
controller. But that won't be the case with following games.)
   Serving Suggestion:
Date: 7 Jan 2011 13:55:20
Message: <4d276198@news.povray.org>
  Regular PC gamepads (eg. the ones made by Logitech) *almost* work for
games which expect an Xbox 360 controller, but not quite (the button
mapping is different, of course, but more importantly one of the axes
of one of the thumbsticks is inverted).
  There exists a dll out there which you simply put in the same directory
as the main game executable, and it will emulate an Xbox 360 controller
with your regular PC gamepad and it works quite well (PC gamepads usually
don't have analog trigger buttons, though, so if any game depends on them
it will be a problem).
  Of course if you don't have even a PC gamepad, then playing a game
expecting one could prove difficult. (You could probably find some
program out there that emulates a gamepad using the keyboard, but you
won't get analog thumbstics nor triggers.)
Date: 10 Jan 2011 03:45:20
Message: <4d2ac720$1@news.povray.org>
> to install the compiler to get enough of the runtime.
When you use the "Publish" option from VS, doesn't it make an installer
with the correct code to download and install necessary runtimes?  Of
course that doesn't fix the button remapping issue for people without
xbox controllers.
I wrote a simple "InputManager" class to allow games to map multiple
physical controls from multiple devices to a single action in-game.  The
digital bit works fine, but I never got around to finishing off the
analogue part.  My idea was to be able to mark a particular logical
control as "analogue", then if you mapped a digital physical control to
it, it would work in an analogue way (with adjustable sensitivity etc).
  I needed that for the steering of vehicles in my game.
> I remember?)
Yeh, I wonder what spec PC would match the performance of the xbox at
POV?  The xbox architecture is optimised for 3D games (that 512M is
shared between the GPU and CPU IIRC, so no delay transferring data
between the two like in a PC).  IMO the PS3 would be better for POV, you
used to be able to install Linux on it (and Intel had a C++ compiler
that used all the cores in the CPU), so it seems more feasible than on
the xbox.  There are some demo videos floating around of real-time
raytracing on the PS3.
Date: 10 Jan 2011 12:58:19
Message: <4d2b48bb$1@news.povray.org>
It is supposed to, yes. I understand there were some bugs in the 3.1
installer in that respect, and I've never really banged on it hard enough to
make one of those work.
Yeah, I just haven't needed to do that on my game, since I hadn't really
planned to release a PC version anyway.  All the code to support such a
thing is there.
Almost undoubtably. I just saw an announcement of FreeBSD released for the
creacked-PS3.
   Serving Suggestion:
