POV-Ray : Newsgroups : povray.off-topic : I just so love Feynman Server Time
18 Oct 2026 01:53:57 EDT (-0400)
  I just so love Feynman (Message 11 to 26 of 26)
<<< Previous 10 Messages Goto Initial 26 Messages
Subject: Re: I just so love Feynman
Date: 7 Nov 2010 12:14:11
Message: <4cd6de63$1@news.povray.org>
Warp wrote:
>   I still don't quite get it. Well, I suppose I will have to submit to the
> fact that I have never understood it, and I still don't understand it.
Well, I'm certainly no Feynman, but you could say all the "gaps" you think
are there are actually full of photons. The photons last only a very brief
time. When the electrons from one atom are close enough to the other that
the photon has time to go between, they interact.  That's really about all I
understand of it also.  I'm not sure that anyone knows better the *why* of it.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 7 Nov 2010 13:31:33
Message: <4cd6f084@news.povray.org>
  Does that mean that the reason why objects can't pass through each other
is fundamentally electromagnetic?
  A photon is the basic unit (quantum) of electromagnetic radiation and
although it has no mass, it's also the force carrier of electromagnetic
force. But how exactly does this work in this situation? What forces are
acting what?
  Additionally, photons have a frequency. If the gaps are full of photons,
what produces them. what is the frequency of these photons and why?
> The photons last only a very brief time.
  Where do they disappear to, and why? Certainly their energy has to go
somewhere, it cannot simply disappear.
  Why doesn't this happen with electrons orbiting the same atom?
  If the repulsive force of the photons produced by electrons is so strong
as to completely forbid two atoms from passing through each other, why are
the electrons in one atom exempt from this same repulsion force?
Date: 7 Nov 2010 16:23:59
Message: <4cd718ef$1@news.povray.org>
Note, again, this is all my layman understanding.
Yes. There's only four forces: gravity, electomagnetic (aka electrostatic or
quantum electrodynamic), the weak force (which I think is what holds the
nucleus together) and the strong force (which I think is what holds the
quarks in a proton or neutron together).  The QED force is photons
interacting with electrons, and nothing else. So, basically, anything not
gravity or "nuclear" is electromagnetic.
> acting what?
Photons and electrons interact. It makes the electrons change which
direction they're going.
> what produces them.
Quantum uncertainty, apparently. At this point, I'm not sure anyone knows
the "why" of spontaneous photon generation. Basically, every possible
combination of giving-off-photons and absorbing-photons is averaged together
(with the appropriate math for "averaged") and the probability that
something happens is based on that.
There are apparently many frequencies. Altho, as I understand it, a photon
doesn't have an actual frequency on its own. Every photon is identical. What
gives a photon its frequency is the relative motion of the source and
destination of the photon. Otherwise relativity wouldn't work.
They get absorbed again. It's like saying the contact between billard balls
lasts a very brief time.
Yes, it is imparted to the electrons. Which is what's holding your ass up in
spite of gravity. The photon pushes chair down and ass up, for a net change
of zero. :-)
The emission of the photon from an electron causes that electron to have
less energy. The absorption causes it to have more energy. Net result is zero.
Very often, photons will be emitted from an electron and almost instantly
reabsorbed by the same electron. That's where the photons come from.
Read the first instance (i.e., the #10 negative energy) of this article:
http://listverse.com/2010/11/04/10-strange-things-about-the-universe/
Essentially, vacuum isn't empty. It's constantly full of random virtual
particles that come into existence, last for a tiny amount of time, and then
annihilate each other (being equal-and-opposite). Photons do this, and
electrons do this, as far as anyone can tell from measurements. So at 10nm
distance, the two plates have excluded enough random particle possibilities
that there's an entire atmosphere of pressure on the outside more than there
is between them, just as an example of how tiny is "tiny".
It does. That's why all the electrons don't collapse onto the
oppositely-charged nucleus. That is the source (I think) of the Pauli
exclusion principle.
Because they're also exchanging photons with the protons. The protons have
an opposite charge, which means they basically move in the opposite
direction (of how an electron would move) when they absorb or emit a photon,
and this causes the electrons to move closer to the proton instead of
farther away. So the electrons are pushing each other apart, but the protons
are pulling them closer, so the more protons, the more electrons it'll hold
onto. Then you can look at the periodic table and see how the "holes" and
"overages" of ionic behavior follow.
Alternately, and I might be misunderstanding/misremembering this, one of the
"nuclear" forces (strong or weak) might be involved here. Oh, OK, according
to wikipedia, the strong force holds protons to other protons (i.e., holds
the nucleus together) *and* holds quarks together. Weird. The weak force
apparently deals with neutrinos, beta decay, and other stuff I understand
nothing about. :-)
Basically, the nuclear forces work on essentially the same principle, except
they have different particles, different likelihoods of interaction, etc.
   Serving Suggestion:
Date: 7 Nov 2010 17:03:42
Message: <4cd7223e@news.povray.org>
  So this is the reason why when you shoot a lone neutron towards an object,
it will (usually) go right through as if there was nothing there (except in
the odd cases where it just happens to collide with a nucleus, as there are
quite many of them there, in which case it's deviated or even reflected),
because neutrons are electromagnetically neutral and thus don't interact
with the electrons and protons? Moreso with neutrinos, which are like
neutrons but a lot smaller (so a lot less chances of colliding with
something in there).
  Btw, I don't remember now what happens if you shoot a lone proton towards
an object. As it's electrically charged, it ought to interact with the
object immediately, if I understand correctly. But what happens?
Date: 7 Nov 2010 18:11:55
Message: <4cd7323b$1@news.povray.org>
That's my understanding of the basics of it, yes. "Charge" is basically the
probability that any given photon will be emitted or absorbed by another
particle. A charge of "1" (plus or minus) means you have about one chance in
137 of a particular photon interacting with a particular electron at any
particular instant they meet.  Nobody knows where that number comes from.
That I don't know about.
Yes, but it's so much bigger than an electron that it can knock an electron
out of orbit (i.e., it can affect an electron with so many photons that the
electron's attraction to the electron's associated nucleus is basically
overwhelmed) without losing much of its own momentum. So it tends to go
quite some way if it's moving quickly, but with the charge it tends to stop
quickly once it slows down (compared to neutrons), in part because it'll
pick up an electron of its own, turn into a hydrogen atom, and now be much
closer to the size of other atoms instead of the size of a nucleus.
In other words, yes, it interacts with (mostly) the electrons and possibly
the protons if it happens to get close, but mostly by smashing through the
substance you're shooting them at if they're going fast.  Electrons, on the
other hand, will run into other electrons and stop quickly, no matter how
fast they're going, because each interaction will on average result in two
electrons with half the momentum (and shooting off a bunch of photons in the
process, which is where you get x-ray machines and CRTs and such). A proton
is some 2000x as heavy, so it can go a lot farther before it stops.
That's why gamma radiation (high-energy photons) takes thick lead to stop,
x-rays (slightly less energetic) takes thin lead to stop, beta radiation
(high-energy electrons) takes a few millimeters of lighter metal to stop,
and alpha radiation (basically helium nuclei) takes like a piece of paper to
stop.
   Serving Suggestion:
Date: 7 Nov 2010 22:51:13
Message: <87hbfsjwuc.fsf@fester.com>
Darren New <dne### [at] sanrrcom> writes:
Freeman Dyson say no:
"A seminal work by Dyson came in 1966 when, together with Andrew Lenard
and independently of Elliott H. Lieb and Walter Thirring, he proved
rigorously that the exclusion principle plays the main role in the
stability of bulk matter.[13] Hence, it is not the electromagnetic
repulsion between electrons and nuclei that is responsible for two wood
blocks that are left on top of each other not coalescing into a single
piece, but rather it is the exclusion principle applied to electrons and
protons that generates the classical macroscopic normal force. In
condensed matter physics"
http://en.wikipedia.org/wiki/Freeman_dyson
Date: 8 Nov 2010 00:02:22
Message: <4cd7845e$1@news.povray.org>
 From what I understand, the exclusion principle is a result of the quantum
electrodynamic theory, which is what used to be called "electromagnetic
theory" before it was quantum.  I.e., it's the same math going on, with
photons interacting with electrons and etc.  Clearly I'm not capable of
talking about it at this level. :-)
   Serving Suggestion:
Date: 8 Nov 2010 23:57:48
Message: <877hgnjdny.fsf@fester.com>
> quantum electrodynamic theory, which is what used to be called
> "electromagnetic theory" before it was quantum.  I.e., it's the same
> math going on, with photons interacting with electrons and etc.  Clearly
> I'm not capable of talking about it at this level. :-)
Could be - I never studied QED. However, it's not plain old
electromagnetics. What Dyson showed was that the electromagnetic
interactions between/among nuclei and electrons is not sufficient to
explain the volume of matter - it would be smaller without the exclusion
principle.
One aspect that keeps particles apart is the exchange interaction, which
is purely due to quantum mechanics (i.e. not, AFAIK, related to
electromagnetics). This was one of those oddities of the quantum world
in undergrad quantum mechanics - that two such particles would prefer to
stay apart even though there is no actual force interaction between them
(even for uncharged particles).
IANAP
kkk
Date: 9 Nov 2010 01:26:41
Message: <4cd8e9a1$1@news.povray.org>
> electromagnetics.
OK. I don't know the difference between QED and electromagnetics. I thought
"electromagnetic" was the pre-quantum formulation of electrical and magnetic
field interactions, i.e., the interaction of electrons with photons.
> principle.
That seems obvious to me. :-) Clearly I'm not educated enough to understand
why that's surprising.
I understand the math of why they try to stay apart. I'll have to re-read
the bit that talks about that and see if I can understand what leads to the
math.
   Serving Suggestion:
Date: 9 Nov 2010 01:31:48
Message: <4cd8ead4@news.povray.org>
http://en.wikipedia.org/wiki/Pauli_exclusion_principle
The consequence of the Pauli principle here is that electrons of the same
spin are kept apart by a repulsive exchange interaction, which is a
short-range effect complemented by the long-range electrostatic or coulombic
force. This effect is therefore partly responsible for the everyday
observation in the macroscopic world that two solid objects cannot be in the
same place in the same time.
Sounds like it's both, holding your butt up. :-)
   Serving Suggestion:
Date: 9 Nov 2010 08:45:12
Message: <4cd95068$1@news.povray.org>
On 11/4/2010 3:25 PM, Darren New wrote:
> http://www.youtube.com/watch?v=wMFPe-DwULM
Microsoft hosts seven Messenger Lectures of Dr. Richard Feynman on their
Project Tuva site.  The lectures were filmed at Cornell University in
1964.  They are well worth the six to seven hours that it takes to view
them all.  You'll need Silverlight...
http://research.microsoft.com/apps/tools/tuva/
-- Kyle
Date: 9 Nov 2010 17:09:10
Message: <4cd9c686@news.povray.org>
  How typical of Microsoft to take some scientific lectures which could
benefit our understanding of the universe... and offer them only if you
have a proprietary software of theirs.
Date: 13 Nov 2010 00:41:05
Message: <4cde24f1$1@news.povray.org>
http://www.youtube.com/watch?v=WAwDvbIfkos
Why don't trains fall off the rails?
   Serving Suggestion:
Date: 13 Nov 2010 08:29:13
Message: <4cde92a8@news.povray.org>
  I certainly didn't know that, and it's once again one of those really
simple yet marvelous shows of human engineering ingenuity. Quite often
problems have the simplest solutions, but it's really difficult for
someone to come up with it, even though it sounds so simple afterwards.
Date: 13 Nov 2010 16:53:26
Message: <4cdf08d6@news.povray.org>
  There seems to be an error or discrepancy with the description of the
Kerr black hole in that page. The image shows the Kerr black hole having
three surfaces: The ergosphere, the outer event horizon and the inner
event horizon. The text also talks about these three.
  However, if you look at the wikipedia article:
http://en.wikipedia.org/wiki/Kerr_metric#Important_surfaces
there are only two surfaces: The ergosphere and the event horizon. What
the article at listverse.com calls "outer event horizon" seems to actually
be the ergosphere, and the description seems to confirm that. It seems
that (assuming the wikipedia article is accurate) the author thought
that the ergosphere and the "outer horizon" are two different surfaces,
rather than just being two names for the same thing.
Date: 15 Nov 2010 13:38:32
Message: <4ce17e28$1@news.povray.org>
I think you're right. But then, what do you expect from "top 10 lists"? :-)
   Serving Suggestion:
