POV-Ray : Newsgroups : povray.off-topic : Geometric puzzle Server Time
2 Jul 2026 17:55:37 EDT (-0400)
  Geometric puzzle (Message 161 to 170 of 201)
Subject: Re: Geometric puzzle
Date: 17 Dec 2009 12:49:25
Message: <4b2a6f25@news.povray.org>
Darren New escreveu:
> tried writing code in blender's Python. It doesn't work. It's buggy.
The hundreds of Blender scripts both official and by users out there
seem to contradict that.
a game sig: http://tinyurl.com/d3rxz9
Date: 17 Dec 2009 12:50:28
Message: <4b2a6f64@news.povray.org>
> nemesis wrote:
>> a huge hate thread about Blender,
> I find it funny that you're reading "hate" into any of the posts.
I find it funny that you don't notice it in-between the lines.
Date: 17 Dec 2009 12:52:56
Message: <4b2a6ff8$1@news.povray.org>
It only took me writing two and having them both not work to convince me
otherwise.
Note that it's possible to be "buggy" and yet still work for lots of people.
Maybe I was just doing things that nobody else tried to do, or if they tried
and it failed, they didn't complain or try to fix it but rather just gave up
on it (like me).
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Date: 17 Dec 2009 12:53:34
Message: <4b2a701e$1@news.povray.org>
Maybe hatred of inanimate objects just isn't something I relate to.
Date: 17 Dec 2009 13:11:33
Message: <4b2a7455@news.povray.org>
Maybe only people who love perfectly round surfaces can relate to. ;)
Date: 17 Dec 2009 14:08:31
Message: <4b2a81af$1@news.povray.org>
scott wrote:
>> This puzzles me. I'm not disputing you're wrong - usually there's some
>> option to set the number of subsamples taken - but since a GPU can
>> *only* draw straight lines, you'd think they could just use the
>> closed-form formulas for doing mathematically perfect AA on polygon
>> edges. It takes about 3 float-ops. No subsamples required.
> That method has problems when you are drawing triangles adjacent to each
> other.
Like what?
> Also how does your method work with a pixel shader?
If I actually knew what a pixel shader is, I could maybe answer. :-)
>> I still find it rather hard to believe that you can take a complex
>> shape such as the surface of a water splash and automatically
>> tesselate it.
> If you're going for physical accuracy then your simulation data will be
> in voxels or something anyway,
Unless it's a particle method.
> so using marching cubes or similar will get you your tesselated mesh directly.
I see.
http://blog.orphi.me.uk/
Date: 17 Dec 2009 14:53:22
Message: <4b2a8c32$1@news.povray.org>
nemesis escreveu:
> Invisible escreveu:
>> I think because fundamentally I dislike trickery. Modelling solid
>> objects as true solids with a real inside and outside, and real
>> curves, and real patterns, etc. seems so much superior to faking it
>> with lots of straight lines and pixels.
> Fine, give us your perfectly curved SDL phone and we'll all agree with
> you.  I'll give you the benefit of doubt and more 10 minutes.
I take it you can't prove your arguments, right?  Or perhaps you need a
whole day to provide a pure SDL, perfectly curved phone?
Date: 17 Dec 2009 15:13:19
Message: <4b2a90df$1@news.povray.org>
For your benefit, I will repeat myself: *most* man-made objects have
lots of straight or simply-curved edges and are very easy to model with
CSG. However, highly-curved non-random objects such as car bodies or
trainers or similar are difficult to model using only CSG.
Then again, given that I personally can't model them with triangles
either, it's kind of moot at this point.
Date: 17 Dec 2009 15:26:40
Message: <4b2a9400$1@news.povray.org>
Orchid XP v8 escreveu:
>>> with you.  I'll give you the benefit of doubt and more 10 minutes.
>> a whole day to provide a pure SDL, perfectly curved phone?
> CSG.
No, they aren't easy.  Which is why you're backing off.
You can't because you're stubborn and does not listen to advice, but
other people can because they learn instead of whine.
Bevels in Blender go about as easily as selecting the appropriate
modifier from a drop-down list.  How many clever lines of SDL code do
you have to go through to add perfectly curved bevels to your hard-edged
CSGs?  don't mind, it's rhethoric.  You could ask clipka, because his
train was the best piece of beveled pure CSG I've ever seen...
Date: 17 Dec 2009 15:30:30
Message: <4b2a94e6$1@news.povray.org>
>> with CSG.
So you're seriously telling me that if you wanted to model, say, an
engine, you'd actually draw billions of triangles rather than just take
a cube and intersect a few cylinders out of it, and then make the
pistons to go in it, etc?
Um, why?
Or rather, because they've spent more time reading the documentation
than I have so far?
I'll believe it when I see it. :-P
