POV-Ray : Newsgroups : povray.off-topic : One of the problems with the Blender UI Server Time
15 May 2026 06:33:25 EDT (-0400)
  One of the problems with the Blender UI (Message 1 to 10 of 51)
Subject: One of the problems with the Blender UI
Date: 8 Nov 2009 16:11:01
Message: <4af733e5$1@news.povray.org>
You go back to it after a couple months not using it, and even the simple
trivial stuff like making a box bigger is once again completely unobvious.
Sheesh.
Subject: Re: One of the problems with the Blender UI
Date: 8 Nov 2009 18:40:00
Message: <web.4af756567ff898a1c91ba7e00@news.povray.org>
> Sheesh.
since you've already forgot it, why not try the new 2.5 build?  Vastly improved
interface, possibly far more intuitive to n00bs.
Date: 8 Nov 2009 20:10:39
Message: <4af76c0f$1@news.povray.org>
>> Sheesh.
I'm mean, it's probably more productive to complain about the new
interface than the old legacy one. ;)
Date: 8 Nov 2009 22:35:32
Message: <4af78e04@news.povray.org>
Heh, yes. I'm trying to get used to Wings, which seems a lot easier until
you screw up the geometry, and then you're pretty much hosed as far as I can
tell. What do you do when you have a face where points are connected when
viewed from the top of the face and not when viewed from the bottom? I don't
even know how I manage such a thing. :-)
Date: 9 Nov 2009 02:37:57
Message: <4af7c6d4@news.povray.org>
> Sheesh.
True! I'm working on something, and it seems I'll need good ol' Blenda for
some of the more intricate geometry in the scene. I'm trying to remember
how to extrude along a curve and BOY the interface isn't helping a bit.
I wonder if the upcoming 2.5 revamp is going to make it much easier or
harder, and how well existing Blender experience will translate for users
who must now use a new interface...
Stefan Viljoen
Date: 9 Nov 2009 02:40:52
Message: <4af7c784@news.povray.org>
> can tell.
I had that problem too.  I always seemed to end up with some weird situation
where a triangle or line would be in totally the wrong place (ie not
physically possible) and it would seem there isn't enough flexibility to fix
it without destroying half your model.
Date: 9 Nov 2009 09:59:59
Message: <4af82e6f$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4af78e04@news.povray.org...
> can tell. What do you do when you have a face where points are connected
> when viewed from the top of the face and not when viewed from the bottom?
> I don't even know how I manage such a thing. :-)
The tricky thing about Wings is that it can't have orphaned edges or
vertices, and it only works correctly when every edge is touching exactly
two faces. If you delete some edges, or loop cut an odd shape away, or some
such, Wings is going to merge the faces that used to be separated by edges
into a single face, often leaving it severely non-planar. However, it's
still going to ask the OpenGL engine to draw the face, and it will look
really odd from different angles. Most of what happens in Wings I find to be
really intuitive (I love its interface better than any other modeler) but
this one thing takes a lot of getting used to.
What I find I have to do is visualize what I want the geometry to have
looked like, then select the right vertices (usually rotating the model so I
can see the parts I want) and connecting them to make new edges.
I used Blender for about a year and never got the hang of it, but I was
making models in Wings inside of two weeks. I am planning to look at the 2.5
interface when it comes out for general use... I've been using C4D for about
six months and I see a lot of similarities, so I'm thinking I might be able
to pick it up again. I'd like to be able to do fluid simulations without
having to spend another wad o' case. :D
Jack
Date: 9 Nov 2009 10:24:27
Message: <4af8342b$1@news.povray.org>
I hope existing Blender experience will /not/ translate at all, because
my existing Blender experience is way deep in the negative realm :-P
Date: 9 Nov 2009 11:51:35
Message: <4af84897$1@news.povray.org>
> into a single face,
Personally, I'd classify behavior in a modeler that let you corrupt its
internal structures as a "bug". :-) I mean, really, doesn't an edge need a
point at either end? How do you end a face without edges all the way around?
Yes, this is cool.  After having done some modeling with Blender and H:AM,
Wings makes much more sense than it did when I tried it as my first modeler.
If you can fix it, it's not that bad. I just usually have no idea what I
just did wrong. :-)0
I managed to get a few things working OK. The more sophisticated stuff is
too buggy for me to want to use, and it's all mostly undocumented, which is
what drives me nuts. Wings has the benefit of coming with a manual telling
you how the thing works and what each option is.
I do enough G**D*** exploratory screwing around with the software at work. I
don't want to spend 20 minutes on google learning how to find the button
that adds a vertex to an edge when what I really want to be doing is putting
a window in a wall.
Actually, I think the real problem with all the modelers is they all want
you to do operations that fit well with their internal data structures, and
they all treat solids as connected surfaces. So, for example, you can't take
a cube and drill a hole through it. You have to first add vertexes to edges,
connect them, then delete the faces in the middle, and etc.  There's CSG,
but that's still not quite the same thing, methinks. It's not like clay
where you can say "here's a block. Here's a cylinder. Stick the end of the
cylinder to the block."  Wings comes about closest with things like Intrude
and "Lift" and such, where it adds the extra faces it needs.
Date: 9 Nov 2009 11:53:22
Message: <4af84902$1@news.povray.org>
I must say, I was quite amused how one video talking about it said how very
cool it was that you could right-click on a button and tell it to show you
the documentation for it, like this wasn't technology back in Win3.1. :-)
Even more amusing was the person going on to say "I won't do it, because it
doesn't work yet, but..."
Yeah, it'll probably help once people get around to filling in what all the
buttons do on the right pages of the Wiki it references. I just think
Blender isn't quite ready to be used by someone uninterested in contributing.
