POV-Ray : Newsgroups : povray.off-topic : 4D Server Time
18 Apr 2026 09:14:13 EDT (-0400)
  4D (Message 31 to 40 of 64)
Subject: Re: 4D
Date: 21 Oct 2009 09:26:43
Message: <4adf0c13$1@news.povray.org>
Saul Luizaga schrieb:
>>> Or maybe you leave your 3D body and become a 4D spirit that then will
>>> incarnate a 4D being and so on...
>> But if so, how could you possible remember and/or integrate the
>> experience with a 3D mind? Maybe you could remember that *something*
>> happened, with a gained benefit of a new spiritual perspective...
> Is a possibility, but again, who remembers being a 2D person before this
> life? maybe is part of the "instinct" of each person, but who knows...
You can't be (and never could have been in any prior life) a "2D
person": Evidently, there /are/ 3 dimensions (or more), so each "2D"
being must also be embedded in 3D space, and therefore /be/ a 3D being.
Similarly with 4 (space-like) dimensions: Either we /are/ 4D beings, or
there is no such thing as a 4th dimension.
Subject: Re: 4D
Date: 21 Oct 2009 09:27:37
Message: <4adf0c49$1@news.povray.org>
>> It is worth nothing, however, that the time dimension is *not*
>> identical to the space dimensions (one would hope not!) and distances
>> are measured differently in time than in space.
> Well, AFAIK there's actually no fundamental reason to apply different
> "measuring tapes" to time and space: The constant vacuum speed of light
> can serve as a ruler for both, with the distance of a light second
> equating a second.
> It just happens that it's still more practical to use meters for
> space-like dimensions and seconds for time-like dimensions.
When you start measuring "events" which happen at different points in
space and different points in time, it becomes worth using a "spacetime"
measurement which simultaneously encodes both.
(Not that I know much about such things...)
Subject: Re: 4D
Date: 21 Oct 2009 09:30:02
Message: <4adf0cda$1@news.povray.org>
It seems to me people are confusing mathematical formalisms with reality.
4D Euclidian geometry is an interesting mathematical system. 4D
time-dimension geometry is an interesting mathematical system. 2D Euclid
is an interesting mathematical system. (Euclid was reputedly so
fascinated by it that he was speared to death by some random Roman.)
Whether these systems have any baring on the Real World which we inhabit
is an entirely orthogonal question. ;-)
Subject: Re: 4D
Date: 21 Oct 2009 09:43:12
Message: <4adf0ff0$1@news.povray.org>
>>>> will incarnate a 4D being and so on...
>> this life? maybe is part of the "instinct" of each person, but who
>> knows...
You're missing the point: by 2D person we mean you live in a 2D world as
we live in a 3D world, without being able to experience any other
dimension. Of course 2D, 3D, 4D, etc are included in a nD universe but
we're not gonna call everything a nD being or object, we have to call
the object dimensional feature by how many dimensions that being/object
is able to experience not by how many dimension that being/object is
included in.
read above.
Subject: Re: 4D
Date: 21 Oct 2009 09:44:57
Message: <4adf1059$1@news.povray.org>
ANd nobody knows if we were or not 2D beings.
Subject: Re: 4D
Date: 21 Oct 2009 11:06:04
Message: <4adf235c$1@news.povray.org>
Invisible wrote:
> These are two seperate, unrelated geometries.
> 4D Euclidian space is interesting because it's a straight extension of
> 3D Euclidian geometry.
I should read more about this, sounds interesting.
> Somewhat weirder is hyperbolic geometry, where multiple "straight lines"
> through a single point do not intersect each other [except at that
> point]. You really need to play with this:
> http://cs.unm.edu/~joel/NonEuclid/NonEuclid.html
I'll check it out.
I've been trying to figure out how to calculate hyperbolic geometry, so
I may create new "circle limit" Poincare disk tesselations. I figure it
must be possible to create such a thing with POV-Ray functions, but so
far all my attempts have been total failures :(
Subject: Re: 4D
Date: 21 Oct 2009 11:15:28
Message: <4adf2590$1@news.povray.org>
3D Euclidian space = the place where we (apparently) live.
4D Euclidian space = the place where objects such as the hypercube live.
4D non-Euclidian space = any space with 4 dimensions that *isn't* 4D
Euclidian space. This includes a system where time is the 4th dimension,
but also many other kinds of space as well.
>> lines" through a single point do not intersect each other [except at
>> that point]. You really need to play with this:
> I'll check it out.
I believe you can use ordinary 2D coordinates for hyperbolic space, you
just need to remap them when plotting them in normal 2D space.
(Unfortunately, I can't find any formulas for doing this.)
Note that there is more than one way to project hyperbolic space into
trying to copy Escher's Circle Limit.
Subject: Re: 4D
Date: 21 Oct 2009 11:40:26
Message: <4adf2b6a$1@news.povray.org>
It's not measured *quite* the same way... The distance between two events is
sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Subject: Re: 4D
Date: 21 Oct 2009 11:41:13
Message: <4adf2b99$1@news.povray.org>
> events is sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Hence "non-Euclidian space".
Subject: Re: 4D
Date: 21 Oct 2009 12:03:25
Message: <4adf30cd$1@news.povray.org>
> equating a second.
I think that this becomes problematic for measuring between points which
aren't connectible by a lightlike geodesic, but maybe there's some
clever way around that (although I don't see how).
In any case, I was referring to the fact that under special relativity
spacetime has a metric that differs from that of a 4D Euclidian space
along the dimension corresponding to time.  For instance, the length of
a vector can be negative, which is impossible under a Euclidean metric.
