POV-Ray : Newsgroups : povray.off-topic : Tell me it isn't so! Server Time
1 Jun 2026 17:07:57 EDT (-0400)
  Tell me it isn't so! (Message 181 to 190 of 473)
Subject: Re: Tell me it isn't so!
Date: 24 Jul 2009 09:50:00
Message: <web.4a69bb8eac52dfd46e32850e0@news.povray.org>
> > *Now* you're talking about something OOP- and programming-related:
> > Modularization. But what on earth does your previous post's talk of "concepts",
> > pens, cars, dogs and cats have to do with this?
>   In object-oriented programming a class is basically a user-defined type,
> and a user-defined type is a concept. For example, "a string" is a concept,
> and a string class is the implementation of that concept.
Yeah yeah yeah... sure... I'm repeating myself here: *I* know how to map your
words to OOP, so you needn't tell me. It still doesn't convince me that
OOP-newbies have any idea what this cats & dogs crap is all about, and
introducing OOP in a much different way would make it much easier to grasp.
Let alone that OOP is not just "OOP". It is a combination of multiple concepts,
many of which don't require each other; the typical blurp tries to introduce
the whole "concept" of OOP all at once, instead of introducing the concepts one
by one.
> [lotsa stuff skipped]
>   Modular programming does know the concept of instantiating modules. For
> example the modula programming language (which is not an OOP language) has
> modules with public and private interfaces, and which can be instantiated
> and referenced. (What makes it non-OOP is that it doesn't support inheritance
> nor obviously dynamic binding.)
.... and that's a very typical example of how modularity is commonly percieved,
huh?
Yes, modules occasionally *are* instantiated and referenced; but in typical
modular projects they're *not*, and instead just resemble code libraries.
Subject: Re: Tell me it isn't C
Date: 24 Jul 2009 10:05:00
Message: <web.4a69bf6e6bcf74ae6e32850e0@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> I remember once way back, having written docs for the library, I was sitting
> there coding it up. (The project was a rewrite from BASIC to C, so I had a
> real good idea what the library needed to do.) I had a stack of
> documentation, and I was implementing each function.  The "best" programmer
> in the company comes up and asks what I'm doing, and I tell him. He points
> to the inch-thick print-out, asks what it is, and I tell him it's the docs.
> He says, sounding baffled, "How can you write the docs before the program?"
> I ask him "How can you know when you're done programming without writing the
> docs first?"
Now, ever wondered what the subtleties between SW development, programming and
coding may be?
What you did was SW development: Designing a program, then coding it.
What the other guy did was programming: Just make sure to produce a program, no
matter how...
(BTW, did you know that your working style costs jobs? 'Cause as long as people
program software instead of developing it, you can't just outsource the coding
part to India... :P)
Subject: Re: Tell me it isn't so!:Apparently it is!
Date: 24 Jul 2009 10:10:00
Message: <web.4a69c00b28322c16e32850e0@news.povray.org>
Chambers <Ben### [at] gmailcom_no_underscores> wrote:
> >> Shouldn't that be "the Buck"? ;)
> As in, David K Buck :)
Ah - now here comes light ;)
But no: Leader of the dev team is currently Chris Cason :P
Date: 24 Jul 2009 10:30:01
Message: <web.4a69c4eeac52dfd46e32850e0@news.povray.org>
"David H. Burns" <dhb### [at] cherokeetelnet> wrote:
> I'm sorry to seem unclear, but to me it seems that the "No" and the rest
> of my
> statement clearly refer to the assertion that I think in OOP all the
> time when using
> Pov-Ray. It seems to me that I don't, though perhaps others may know my
> mind better that I do. In fact. since OOP means Object Oriented
> Programming, it seems
> absurd to say that I think in it (or in any other kind of programming).
> On the other hand,
> I am repeated told that I don't know what OOP means; maybe it *doesn't* mean
> "Object Oriented Programming"(acronyms are always obstacles to
> communication),
> but some philosophy or mystery into which I have not been initiated. In
> any case, it seems
> an overstatement at least for someone else to say I thing in it. :)
I'd guess you *do* some "OOP (= Object Oriented Programming) thinking" when
working with POV-Ray; it's just that you don't notice, because you admittedly
don't know what Object Oriented Programming actually is - you only know how
typical end results from such thought processes look like, when formulated in a
general-purpose language retrofitted to better support such formulations
("better" as in "better than nothing") - a language which, by the way, would
surely happen to be unsuited for a POV-Ray SDL.
Date: 24 Jul 2009 10:33:28
Message: <4a69c638$1@news.povray.org>
On 07/24/09 08:49, Invisible wrote:
>> It would make things like doing complex simulations much easier,
>> because you could use eg C++ to get good speed, and have POV render
>> the result quickly each frame. Also if you wanted to use Haskell, or
>> anything else, you could.
> That's an interesting idea. However, I have a vague recollection that
> this would be incompatible with the terms of the POV-Ray license.
	The POV-Ray license will either disappear in 4.0, or will be made
compatible with one of those alleged "free" licenses.
AD&D Famous last words: Me first.  Me first!
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 24 Jul 2009 10:50:01
Message: <web.4a69c952ac52dfd46e32850e0@news.povray.org>
>   I don't want to have to write something like those programs, I have
> seen to produce a Pov-Ray
> script!
Um... wait a second here: You've looked at code written to create POV-Ray code?
Now that's metaprogramming, which tends to look sick in *any* language that's
not designed for it, whether it be OOP or not.
> But, apparently, that is a worry for only the remote future.
Hmm... I don't really think so. Not if you talk about decares here. 3.7 did
indeed take a while to come out (still not released), but after all it was a
major rewrite of virtually the whole code, with some serious design changes to
get it to support SMP. Compared to that, I guess development of POV-Ray 4 will
be a piece of cake - the main objectives (um... no pun intended here, really)
being that major overhaul of the SDL (but that will just mean a rewrite of the
parser, leaving the remaining code untouched), and a change in licensing to go
for GPL (not much left to do there; AFAIK virtually all previous contributors
have given their OK by now, and the remaining pieces of code have been
completely re-written).
Date: 24 Jul 2009 10:51:24
Message: <4a69ca6c$1@news.povray.org>
We may all be engaging in muddy thinking and language here. I do kind of
think
in terms of "objects" when using Pov-Ray, but I wouldn't call that "OOP
(= Object
Oriented Programming) thinking", even if that phrase means
anything--which I doubt.
It might be more accurate to say that I am writing code which conforms
to the syntax dictated by
the SDL -- regardless of what kind of thinking leads to it. As I have
said several times before:
I think the concept of "object" is a real advance in programming but
"OOP" seems
a lot more than simpling making use of "objects" which "contain" both
data members
and functions ("methods")
>you only know how
This seems to be true, where would I find some *real* OOP to look at?
David
Date: 24 Jul 2009 10:54:06
Message: <4a69cb0e$1@news.povray.org>
scott wrote:
>>> Check the povray.pov4.discussion.general group, particularly the
>>> threads "Next Generation SDL Brainstorming" and "Next Generation SDL:
>>> What's wrong with Lua, JavaScript, ...".
>> Thanks, Scott,
>> I see only 4 threads and neither of these. Thunderbird is giving me
>> problem?
> I don't use Thunderbird, but maybe someone else might be able to help
> you. In Windows Live Mail you can choose "Tools -> Get Next <X> Headers"
> where X is the value you set for how many to download at a time - maybe
> there is something similar?
> If not then you can always use the web view here:
> http://news.povray.org/povray.pov4.discussion.general/
Thanks. I haven't had this problem with the other Newgroups. I'll look
at it via
the web.
Date: 24 Jul 2009 11:02:54
Message: <4a69cd1e$1@news.povray.org>
Neeum Zawan wrote:
> On 07/24/09 07:38, David H. Burns wrote:
>>> Now you guys know how *I* feel when I try to tell people that
>>> functional programming is a good idea. ;-) Nobody ever seems to
>>> believe me...
>> You encourage me. But we seem to be out of fad. ;-) :) (An attachment
>     Hardly, What you like is procedural. Functional programming is a
> whole other beast altogether, where you normally don't do explicit loops
> but use constructs like map, filter, etc. Lots of lambdas thrown in as
> well.
So your not out of fad. My ignorance is showing. I'm not a professional
programmer
and have done little except for my own amusement. That being so much of
your
terminology is unfamiliar to me. I think that this thread is the only
time I have
actually talked to anyone specifically about programming theory --
although I did
a lot of reading a number of years ago.
You encourage me anyway.
David
Date: 24 Jul 2009 11:11:41
Message: <4a69cf2d$1@news.povray.org>
Heh. I'll keep that in mind.
   "We'd like you to back-port all the changes in 2.0
    back to version 1.0."
   "We've done that already. We call it 2.0."
