![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
> It just makes me angry that they can just silently *change* stuff like
> this without warning me. Now when somebody's login script falls over, I
> have *no clue* what the problem is. Thanks, guys.
Can't you change the passwords used to get into the systems there? If not,
you need to put into writing that you can't be responsible for the systems
if you can't control them.
My fortune cookie said, "You will soon be
unable to read this, even at arm's length."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> I have *no clue* what the problem is. Thanks, guys.
No. They have all the master passwords; I don't even know what those
are. So they can lock me out, but not the reverse.
> If
> not, you need to put into writing that you can't be responsible for the
> systems if you can't control them.
Heh, yeah. Something like that...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you have the passwords for the routers, then you have the passwords. :-)
>> If not, you need to put into writing that you can't be responsible for
>> the systems if you can't control them.
Seriously. You should write up what's going on and send it to your boss, his
boss, and so on up the line. Explain they're crashing your systems and you
have no control over it, and ask them what the appropriate procedure should
be for violation of procedures.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I am so damned *angry* that they would **** around with my systems without
> even bothering to warn me. And the thing is, their fancy, whizzy
Why don't you try and do something about this rather than just writing on
here what's going on? If your boss isn't listening go higher up until
someone does listen. If nobody listens, document it and do your own thing
(ie block them from modifying your systems), then they will be forced to
listen to you.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But I *don't* have the passwords for the routers.
> his boss, and so on up the line. Explain they're crashing your systems
> and you have no control over it, and ask them what the appropriate
> procedure should be for violation of procedures.
Nobody will care. If I say "they did X, which caused a problem",
everybody will assume I don't know what I'm talking about.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> on here what's going on? If your boss isn't listening go higher up
> until someone does listen. If nobody listens, document it and do your
> own thing (ie block them from modifying your systems), then they will be
> forced to listen to you.
1. Nobody with any authority cares about my opinion. The general
assumption is that I know nothing about anything.
2. How did such technically unskilled people get into senior IT
positions? They did it by being good at company politics. If I try to
play that game, they will beat me.
3. I have no power to block anything.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 26 Feb 2009 22:37:20 +0100, Orchid XP v8 <voi### [at] dev null> wrote:
>> passwords. :-)
If you have physical access to the routers, then you make the passwords.
>> boss, his boss, and so on up the line. Explain they're crashing your
>> systems and you have no control over it, and ask them what the
>> appropriate procedure should be for violation of procedures.
It does not matter what they assume or even what they choose to do about
it. What matters is creating a paper trail to cover your own ass.
FE
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> be forced to listen to you.
As fredrik said, and he is the Nth to do so (N>5), you need a paper
trail. Part of your job is to look out for violations of the protocols.
If you don't report them you can be held responsible because you were
not doing your job. If you report and they choose to ignore that, it is
their problem.
It is not about politics, it is about whether your company is violating
the law or not.
You do, but you choose not to use them.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> passwords. :-)
Exactly what I was going to say.
Andy, write the damn paper trail already!
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's a fact that, when hired to do a job, you have the authority to
perform it (assuming the person hiring you had the authority to hire
you, of course).
If they get in the way, do your job anyway, and document it.
If they get mad at you for making necessary changes, even to the point
of firing you, keep the paper trail for future reference (other
employers will ask about what happened... having it documented is
absolutely vital).
...Chambers
www.pacificwebguy.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
