POV-Ray : Newsgroups : povray.off-topic : Ok, who didn't know, or at least guess this? Server Time
4 Jul 2026 12:42:34 EDT (-0400)
  Ok, who didn't know, or at least guess this? (Message 189 to 198 of 218)
Subject: Re: Ok, who didn't know, or at least guess this?
Date: 1 Feb 2009 10:40:00
Message: <4985c250$1@news.povray.org>
Darren New wrote:
> Or, in other words, "We're number one, why try harder?"
Yep. Which is why people get irritated.
>> instead of being asked in the first place,
> The sort of stuff you were talking about changing above, it *does* ask
> you in the first place, if you get the version of the installer that you
> use for things installed dozens of times instead of once. I.e., if
> you're actually working like you administer enough computers that
> changing them one at a time is problematic, you use the installer that
> asks you that stuff up front.
Uh.. Where would this installer be? Oh, right... probably on the
"corporate" multi-license version that most of us don't have access to... ;)
 > Errrr... \windows\prefetch is there? You didn't notice?  You never
 > looked at the add/remove programs window and noticed it told you how
 > often you used the program?
 > "I never noticed it" isn't the same as "it isn't there."
Still doesn't imply that the defragger is "aware" of that data and uses
it. It didn't for a "long" time, much as Paint was "stuck" in 256 mode
until XP, and not(e)pad was stuck with a 32k limit until the same. So,
maybe they made them better in XP and Vista. Good for them, its about
fracking time!! lol
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 1 Feb 2009 10:48:04
Message: <4985c434$1@news.povray.org>
Darren New wrote:
>> There is only *one* update site,
> And you'd rather have lots of update sites? I'm not sure why you think
> this is a bad thing.
You where implying that I was looking at the "wrong" one. I was a bit
confused what one you thought I would be looking at...
>> and the only thing ever "added" are new versions of the "malicious
>> software removal drone",
> Then I guess your stuff is pretty stable. I get all kinds of updates for
> both Windows and Office.
Ah, well. I don't use Office, so... Not a surprise there isn't a lot of
that coming down the pipe. lol
>> whose sole purpose seems to be to send my machine into frozen limbo
>> for several minutes, while it hunts hundreds of gigs of files for
>> "dangerous" stuff, which it never actually finds.
> I try not to be hard at work while installing updates to the operating
> system, myself.   Sounds like you don't have enough memory to me,
> because that runs in about 90 seconds once a month on my machines.
Uh.. I have... 2GB, and I am usually not running anything but Firefox
while this is going on, so unless Firefox is eating up more than half of
the memory... I just don't get it. It can take several minutes on mine,
though, it "did" run faster before I tacked on an external drive. Hmm.
Come to think of it, its probably hunting in the gigs of "backups" on
that drive that get patched every few days too, which would mean its
searching "two" copies of all the same data (well, mostly, since
OneTouch's backup is lame enough to only backup the stuff "it" wants,
not what you want. Need to find something to replace that with, one of
these days... They ever get Windows Backup to do compressed incremental
backups, or it still assuming you have an external removable that is at
least as big as the "entire" data space you are backing up, like they
did before? I haven't bothered to check, since it was nearly useless
back when all I had to backup to was CDs, and it wouldn't do CDs. lol)
void main () {
   else
Date: 1 Feb 2009 10:53:25
Message: <4985c575$1@news.povray.org>
Darren New wrote:
> Patrick Elliott wrote:
>> "You may need to reboot the machine after this install.",
> Note the word "may".   If you're using the file it needs to update while
> the update runs, you'll need to reboot.  Otherwise, the system stops the
> service, installs the patches, and starts up the service again, etc.
If its just "may", it wouldn't keep asking me to reboot, over and over
again. Now, when it "doesn't" need to do it, its very very nice. Just
wish that was more often, or it was, I don't know, nice enough to tell
me which applications might "conflict" with the install, so I can shut
them down *before*. I do keep some things running most of the time,
including MySQL database software, a Yahoo gadget toolbar and 1-2 other
things that "could" be causing it, and are.. not always trivial to
restart manually (or worse, won't restart automatically, in some cases,
if you "manually" shut them down before, due to how they save their
"active" state between boots.) But, yeah. Its a "little" better, but not
what everyone kept insisting, which was "almost never".
void main () {
   else
Date: 1 Feb 2009 12:03:36
Message: <4985d5e8$1@news.povray.org>
> to... ;)
Right. Because if you're only installing one or two machines, it's really
not a problem to move stuff after the fact.
> it.
Actually, it probably doesn't need to any more, since the system does demand
paging now. It really doesn't help to move directories on the disk relative
to other directories just based on what they contain. Given things like
superfetch, readyboost, and all that, the files don't get *read*
sequentially, so having them particularly defragmented in a particular order
probably doesn't make sense any more.
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Date: 1 Feb 2009 12:07:33
Message: <4985d6d5@news.povray.org>
Are you using "Windows Update" or are you using "Microsoft Update"? You're
using the wrong update program if you're not getting updates to your Office
software.
What do you expect them to update?
I wouldn't be surprised. I can do a full Defender scan of an entire drive
here (including all software I've ever owned or downloaded on a separate
partition) in about half an hour or so.
> They ever get Windows Backup to do compressed incremental backups,
Yes. Unfortunately, MS screwed the pooch on this and only backs up what they
think are important files. Otherwise, it would have been a really nice system.
They improved that. You can now ghost the drive (full or incremental), or
you can do incremental backups to compressed zip files, either onto an
external HD or CD/DVDs, with a very nice mechanism for doing full and
incremental restores as well.
   "Ouch ouch ouch!"
Date: 1 Feb 2009 12:10:23
Message: <4985d77f@news.povray.org>
> again.
Right. So you're using the file it updated. Not much you can do about that.
> them down *before*.
It often does. Sometimes it's hard to tell which application is using a
particular file.
And that's exactly why you get asked to reboot. :-)
It's almost never for me. Are you using XP or Vista?
IME, XP reboots far less than previous versions (which pretty much rebooted
for every update), and Vista reboots "almost never".  I've not had any
software install that asked for a reboot except .NET 3.5.
   "Ouch ouch ouch!"
Date: 2 Feb 2009 03:01:22
Message: <4986a852$1@news.povray.org>
> Its not aimed at companies though. Companies "generally" don't go around
> installing single machines, but buy "bulk" licenses, which gives them
> "discounts" on installs. Sometimes they can even talk MS into handing them
> the stuff for free (though not the upgrades).
OK small companies then.  I don't know many people at home who need Outlook,
Visio, Access etc, most just want Word.
Date: 3 Feb 2009 02:50:15
Message: <4987f737$1@news.povray.org>
> No, but, it shouldn't have been possible. And, I think it was "before"
> moving it. Like I said, I really have no idea what happened, just that
> Windows was complaining about running out of room, asked if I would let
> it remove some stuff, and it did. Since then, I clean things up myself,
> so I know what gets taken out. lol
Well true, but if you didn't check it out, it can also be a bug or nasty
habit of the game itself, not necessarily Windows.
-Aero
Date: 3 Feb 2009 23:49:51
Message: <49891e6f$1@news.povray.org>
>> to... ;)
> really not a problem to move stuff after the fact.
>> uses it.
> demand paging now. It really doesn't help to move directories on the
> disk relative to other directories just based on what they contain.
> Given things like superfetch, readyboost, and all that, the files don't
> get *read* sequentially, so having them particularly defragmented in a
> particular order probably doesn't make sense any more.
Hmm. Possibly.. In fact, I suppose, in some cases, you could actually
get "bad" results, like if a prefetch got file 50-56 on the disk, but
the one you need next is like.. '2'. lol
void main () {
   else
Date: 4 Feb 2009 00:04:01
Message: <498921c1$1@news.povray.org>
>> of that coming down the pipe. lol
My point was that "update" in their world means, "We maybe patched some
bugs, but this is damn unlikely, unless they where security bugs." You
are "not" going to get say, "Would you like to install Word 10.0, since
you currently only have 9.0. ;) Well, not unless its IE, and... I don't
use that unless I have to anyway. lol But, its not just "major" changes,
its incremental ones. Even virus scanners will "patch" until they hit
some version limit, then require you buy the next one. In the case of
something like Word, that may mean getting 9.2, 9.3, 9.4, etc., some
with "new" features, but requiring a major upgrade to get the "full"
10.0 version. Its just not in their business model to not screw you for
"huge" amounts of money, for "major" patches, without anything in
between, especially not even including the bug fixes that only make it
into the next major release.
In other words, you may be forced to "wait" for that high price update,
if you expect to see some things fixed at all, and that... just sucks,
and is yet another reason to be "somewhat" less than impressed by them.
That is, if a list of "patches" that are like 99% security, and don't
ever address "any" real problem you are having, isn't enough, by itself. lol
> they think are important files. Otherwise, it would have been a really
> nice system.
Ah, well.. I suppose that explains the One Touch 4 software... They
probably wanted to make it "work like" MS', never mind that the damn
thing now won't backup files it doesn't recognize, directories that
"contain" your My Documents (this one just fracking doesn't make sense
to me, somehow it "knows" that your user data is in a subdirectory of a
folder on the drive, so it refuses to even "allow" selecting the folder
to backup, since it would duplicate the one its already defaulted to
backup in the first place... Suppose I should fix that one of these
days...), and won't backup anything that looks like it contains
"settings", including ini, reg, etc. In other words, they took what, in
version 1-3, worked well, and hosed it, by making it do the same thing
Windows Backup does, from your description. <--- bangs head on desk.
>> or it still assuming you have an external removable that is at least
>> as big as the "entire" data space you are backing up, like they did
>> before? I haven't bothered to check, since it was nearly useless back
> or you can do incremental backups to compressed zip files, either onto
> an external HD or CD/DVDs, with a very nice mechanism for doing full and
void main () {
   else
