POV-Ray : Newsgroups : povray.off-topic : Damn! Server Time
6 Sep 2024 07:17:42 EDT (-0400)
  Damn! (Message 1 to 10 of 12)
Subject: Damn!
Date: 25 Jan 2009 16:52:53
Message: <497cdf35$1@news.povray.org>
http://thefutureofthings.com/news/6259/sdxc-memory-card-format-to-offer-2tb-of-storage.html?addComment
2 TB memory card running at 300 MB/s.
Now I have to wonder what exFAT is all about. Why not just stick NTFS on it,
since everyone can handle that now? Sheesh.
(Yes, I know it's not actually out yet.)
   "Ouch ouch ouch!"
   "What's wrong? Noodles too hot?"
   "No, I have Chopstick Tunnel Syndrome."
Subject: Re: Damn!
Date: 25 Jan 2009 17:14:25
Message: <497ce441@news.povray.org>
  Including things like cellphones, digital cameras, etc?
Subject: Re: Damn!
Date: 25 Jan 2009 18:01:23
Message: <497cef43$1@news.povray.org>
Probably more than exFAT, yah. At least the specs are published. :-)  I bet
an Android phone would work with NTFS better than exFAT.
Thinking on it, tho, NTFS has all kinds of features that something like a
camera wouldn't want, like ACLs, ownership of files, compression,
encryption, etc etc etc.  A good reason not to use it, I guess.
   "Ouch ouch ouch!"
Subject: Re: Damn!
Date: 25 Jan 2009 21:40:01
Message: <web.497d2270f0e84c4063cb5da50@news.povray.org>
There are more good reasons to use FAT:
- NTFS is optimized for fixed media; FAT was *designed* with removable media in
mind. (Note that a file system is more than the data structures on disk; it
also includes some protocol of how to update them.)
- Flash media internally typically use their own specialized file system anyway,
to perform load balancing and bad block management. FAT is easy enough to
implement a mapping to the flash file system in reasonably simple hardware.
Subject: Re: Damn!
Date: 25 Jan 2009 22:45:14
Message: <497d31ca$1@news.povray.org>
Right. While it's true that FAT was designed with removable media in mind,
it wasn't designed with removable media being randomly removed in mind. :-)
It's quite easy to corrupt FAT by turning off the power or unplugging the
media in the middle of an operation.
When's the last time you saw Windows run chkdsk on NTFS when you boot,
compared to running scandisk under Win98 when it crashes?
Besides that, what's your thought on why FAT would be better for removable
media?
I'll take your word on that one. :-)
   "Ouch ouch ouch!"
Subject: Re: Damn!
Date: 29 Jan 2009 12:44:51
Message: <4981eb13@news.povray.org>
> mind, it wasn't designed with removable media being randomly removed in
> mind. :-) It's quite easy to corrupt FAT by turning off the power or
> unplugging the media in the middle of an operation.
Nor over 1MB-sized media (speaking about original FAT).
Every time I boot my work-laptop (it doesn't turn the dirty bit off,
which is kind of annoying).
Umm... not THAT often (I don't reboot my laptop twice a day;).
Btw, that mentioned work-laptop still steals focus too often, even
though I did turn focus-stealing off from TweakUI.
-Aero
Subject: Re: Damn!
Date: 29 Jan 2009 13:01:48
Message: <4981ef0c$1@news.povray.org>
Well, yeah, but come on, FAT-16 is like what, 15 years old?
That's odd. Did you run it manually? I've never had NTFS tell me it's
corrupt, even when I've lost power during a defrag or something.
Yeah. I think Vista ignores that stuff to a large extent. The worst is when
you get modal dialog boxes that manage to come up behind the main window,
with nothing in the taskbar and the main window won't let you move it. I
haven't quite figured out how to fix that one.  (Except maybe locking and
unlocking the screen?)
   "Ouch ouch ouch!"
Subject: Re: Damn!
Date: 29 Jan 2009 13:44:42
Message: <4981f91a@news.povray.org>
Yep, so it's clear that todays gigabytes-sized medias weren't around
back then. But it still means that there are visible flaws when running
big medias with such filesystem - FAT32 fixed the problem with huge
clusters, but even FAT32 was pretty unstable when run with Win98 on over
20-gig partitions (dunno why, for some reason 20+GB seemed to crash more
easily than under 20GB partitions). Still today FAT - or at least it's
Windows implementations - suck at least on some level when you have
enough files.
FAT was designed for removable media. It wasn't designed especially for
flash drives nor for huge medias. It's being helped to breath for over
10 years now.
Nope.
That's a known bug, I've hit it some time earlier also - there's no
failure in filesystem, but Windows thinks it should be checked, like
after unclean poweroff. There's a simple fix somewhere, I've just been
too lazy to find it again :).
...except that I'm running XP on that particular laptop.
> The worst is
> when you get modal dialog boxes that manage to come up behind the main
> window, with nothing in the taskbar and the main window won't let you
> move it. I haven't quite figured out how to fix that one.  (Except maybe
> locking and unlocking the screen?)
I think I've been lucky, since I haven't got such thing. I think one of
the nastiest things are that when antivirus updates the engine, it might
ask for reboot - just finishing a line on some script and press enter...
And there you go.
-Aero
Subject: Re: Damn!
Date: 29 Jan 2009 17:00:01
Message: <498226e1$1@news.povray.org>
> enough files.
No, that's true. Big directories are searched linearly, and the free space
needs to get scanned to find blocks. So if your disk is big and close to
full, allocating a block can take a lot of I/O, or require you to hold the
entire map in memory.
Fat-64 (aka exFAT) seems to be designed to address just these problems.
> Nope.
I suggest maybe "chkdsk /f" at the command line, schedule a scan, and
reboot? :-)
Oh, I remember that. Some of the disk drives didn't actually flush the last
blocks written when you power them off. The patch just delays the actual
remove-power-from-drive for a second or two so the drive will flush out the
memory. But that's an ooooold bug.
Weird.
> And there you go.
Yeah. That's what the focus stealing prevention is supposed to prevent. :-)
   "Ouch ouch ouch!"
Subject: Re: Damn!
Date: 31 Jan 2009 02:36:31
Message: <4983ff7f$1@news.povray.org>
> space needs to get scanned to find blocks. So if your disk is big and
> close to full, allocating a block can take a lot of I/O, or require you
> to hold the entire map in memory.
Maybe FAT some day will be designed for huge medias then :). I hope and
think they don't end up with just pumping up the address space (which
AFAIK pretty much is what they did with FAT-32).
> reboot? :-)
That schedules the check for next reboot, and it was doing that already
;). Anyway, it crashed couple a days ago, which seems to have fixed the
problem :D.
-Aero
