![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
- It appears that "solid state harddrives" are now reaching useful sizes
and sane pricing levels. (E.g., when I first looked at this it was
- nVidia's latest and greatest is the GeForce 200 series. The 260 is
expensive, but not extortionate. The 280 is several times the price.
However, every benchmark I've seen shows the 280 as about 20% at best.
Given that it's far more than 20% more expensive, that doesn't seem like
great value for money. I'm considering buying a 260. (My GeForce 7900GT
is slowly dying...)
- It seems that AMD's CPU designs still trail Intel by a wide margin in
terms of performance. I think AMD might give you more performance for
your money, but if you want the fastest CPU it's not going to be an AMD
product. And Intel's offerings mostly seem to be a reasonable price.
(Obviously anything that says "Extreme" on it is 400% more expensive but
only about 6% faster.)
- For ages every Intel CPU going has used the same socket. It seems
there's a new one just come out, and currently motherboards for it are
absurdly expensive. (Like, the motherboard costs more than the CPU!) I
think I might wait for the prices to return to sanity - as inevitably
they will - and then make a purchase. (Curiosly, the CPUs themselves
aren't *that* expensive, considering they're brand new.)
- I've been looking at watercooling. Just to find out how expensive it
waterblocks seem to be the expensive part - especially for GPUs.)
even more amazing is that you can spend *hundreds* of pounds on
31337-gamer PSUs if you wish.
hundred pounds if you want something ridiculously over-styled. Of
course, all the expensive cases are aluminium rather than steel. (I was
recently very surprised to learn that hyper-expensive aluminium is
actually *less* thermally conductive than plain ordinary copper. So...
why don't they just make cases out of copper??)
Every time I turn out to a clan meeting, everybody brings along their
uber-gaming rig. You know the kind of thing - insanely over-styled
casing with big transparent windows, fans that light up, internal case
lighting, elaborate watercooling systems with polished chrome fans,
multiple graphics cards the size of a car, high-capacity HDs in
front-loading hot-swap drive bays, etc etc. And then there's my PC...
which is just a PC.
I could almost go for the insane look... :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> which is just a PC.
Paint it black and put yellow racing stripes on it. Black paint is 10%
faster, and yellow racing stripes give it a 50% speed boost. You could
get another 20% buy cramming the case full of high-intensity blue LEDs.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
LOL!
Hey, do you remember the old PCs that used to have a "turbo button" on
the front? Why the **** would you ever turn that off?! o_O
> You could
No need; the case fans already have two blue LEDs that light up the room
sufficiently for photopic vision. :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> LOL!
Old Games. Programmers used to rely on the fact that the processor ran
at a brisk 4mhz, 12+mhz caused the game to run too fast to be playable.
>> You could get another 20% buy cramming the case full of high-intensity
>> blue LEDs.
No, you must cram it full of LEDs! Not only does it need to be bright to
get the speed gain, but it has to be blindingly bright. Because
Blindingly bright = Blindingly fast, you see.
for an extra 15% add a few fans with a flashing multi-color light
show. You know the kind ...
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
WTF? Why would they - oh, wait... CSS malfunctions if you play it on a
dual-core CPU. (Something to do with directly accessing the CPU's
realtime timer - which, obviously, is different on each core!)
But of course, for Ultimate Speed you must use ultraviolet, together
with components containing inks that will respond to it...
(Seriously, you can buy cooling fluid that costs extra because it
floureses under UV. WTF?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> on the front? Why the **** would you ever turn that off?! o_O
Well, way back in the dark ages, they didn't really expect the CPU clock
speed to change, so their timings were based on how fast the processor
executes instructions. Of course, when faster systems started coming
out, they had to change their timing strategy.
CSS failing on a dual-core is probably due more to race conditions, or
other synchronization issues.
You could use your computer to light up your 1960s vintage velvet posters
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Heh. Delay loops FTW! :-/
Well, it doesn't actually "fail", it just runs irregularly. As in, you
get an even higher framerate than normal, but it looks visually jerky.
(Or it did. They've fixed it now.) You used to have to manually set the
processor affinity to fix it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Woo! I just found a Sun server that costs more than my house! :-D
(OTOH, it *does* have 64 quad-core SPARC-64 VII processors in it...)
Looks like it's bigger than my entire server rack too. Cute.
At the other end of the scale, it appears that Sun now sell ordinary
desktop systems capable of running normal desktop software. They look
pretty, and they're not *especially* expensive either. (Like, a few
hundred pounds for an Intel Core 2 Quad system.)
Also... Somebody pointed out a website where you can select and
configure your own PC. It's not a very *good* site (e.g., you can't see
the prices for individual components, only the final unit, you can't
select all that many options, many things aren't documented very much,
etc.) But it's strangely addictive trying out various combinations of
components.
Sometimes you just want to see how much stuff you can cram into the box
without going over budget. And other times you just have to select the
biggest, baddest mutha you can, just to see what the hell the price tag
comes out at.
FREAKING NICE PC. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't understand the appeal of churning out lots of money to turn a
hammer into a kitsch object.
But then again, computer to a layman is nothing but a gateway to games,
music and video -- with some office software used to spellcheck emails
to justify the price as opposed to a mere games console. Beautiful
keyboard, mouse, monitor and casing are far more important than whatever
is on the inside -- the computer itself...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible escreveu:
>> blue LEDs.
I thought the blue leds were for cooling. ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
