POV-Ray : Newsgroups : povray.off-topic : Hints for drivers Server Time
7 Apr 2026 11:11:26 EDT (-0400)
  Hints for drivers (Message 59 to 68 of 68)
Subject: Re: Hints for drivers
Date: 17 Nov 2008 12:27:33
Message: <4921a985@news.povray.org>
scott wrote:
>> In most states in the USA, if your car hasn't gotten across the *far*
>> white line when the light goes red, technically you're in the
>> intersection on a red light.
> Is that illegal then, to be *in* the intersection when the light you
> passed on the way in is red?  What happens if you are wanting to turn
> left and have to wait until all the cars coming the opposite way have
> stopped on red - is that illegal if your light has switched back to
> red?  Or what if traffic is moving slowly and you set off into the
> intersection on green, but then it changes to red before you make it to
> the other side?
Technically, yes, you're in trouble. You're not supposed to enter the
intersection unless you can clear the other side legally.  Don't pull
into the middle of the intersection to turn - wait in the turn lane, for
example.
In New York City, where such leads to deadlock, the fine is something
like $500 to be in the intersection when the light changes.
In practice, no, you rarely get in trouble, unless you do something else
stupid too and it's something they add on top.
> Yeh I have that sometimes too, although usually it's just because I
> don't want to break hard to stop in time, then I decide to keep going,
> but then I realise it's going to be a bit risky and it might go red so I
> slam on the brakes anyway!
Yes, that's what my technique was invented to solve. I decide I'm going
to go, and if it turns red anyway, I go anyway. Of course, one has to be
somewhat concervative.
I've learned it helps if you're in a suit and tie, also.
Date: 17 Nov 2008 12:30:25
Message: <4921aa31$2@news.povray.org>
scott wrote:
 > ie you're not meant to stop in the middle of the intersection,
Well, yes, that's why it bugs me. :-)
>> I think in the USA you'd get even worse constitutional challenges if
>> the camera was hidden.
> Hehe, a hidden camera to catch people driving illegally?  Bah no we
> can't possibly have that - the people must know exactly which section of
> road they have to drive legally on!
Well, there were already constitutional challenges based on the fact
that the camera can't take the witness stand, for example. How are you
supposed to argue you weren't speeding if the police won't even tell you
where they caught you speeding?
>> I'd be more worried that in the case of an accident, there's no way
>> for the emergency vehicles to get to the problem area, myself.
> When there is no shoulder here you are meant to leave a gap between the
> two lanes (ie you stop over the left side of the left lane, and over to
> the right side of the right lane), that usually leaves plenty of gap for
> emergency services to come through.
I think that works well if everyone understands it. It works poorly if
half the people think you're supposed to squeeze right from the left lane.
Date: 17 Nov 2008 16:53:30
Message: <4921e7da@news.povray.org>
On Thu, 13 Nov 2008 13:57:42 -0500, Tom Austin wrote:
> Yes, but at least you were not involved in the accident - given they
> were far enough ahead.
> If you get in their way you may be the indirect cause of an accident.
True, but if I can keep 'em behind me, then I'm not going to be stuck in
traffic for hours. ;-)
Jim (mostly joking)
Date: 18 Nov 2008 03:34:51
Message: <49227e2b$1@news.povray.org>
That's sounds a bit silly, how are you meant to know if the light is going
to switch to red before you get to the other side?  Just this morning I
entered an intersection as it switched to amber (no way to stop in time),
and I'm pretty sure it was on red by the time I got out the other side
(around 20mph I guess, crossing 4 lanes of traffic and 2 tram lines).
> Don't pull into the middle of the intersection to turn - wait in the turn
> lane, for example.
You must have to wait for a huge gap in the oncoming traffic then - usually
here you move forward until you are exactly lined up with the exit, and as
soon as there is a gap in the oncoming traffic you make the turn.  Otherwise
you'd literally be there all day (and getting honked at from the cars
behind)!.
It will only lead to deadlock if you enter the intersection when your exit
is not clear - we have that rule too.
Ditto here, the police are not going to even do anything if they are right
behind you.  They're probably doing the same thing :-)
Date: 18 Nov 2008 03:38:44
Message: <49227f14$1@news.povray.org>
> Well, there were already constitutional challenges based on the fact that
> the camera can't take the witness stand, for example. How are you supposed
> to argue you weren't speeding if the police won't even tell you where they
Of course they should tell you where you were caught, but there's no reason
to keep the cameras in the same place.
Actually in the UK they had almost this method, because I think 80-90% of
the camera housings are actually empty inside.  A pretty good idea so long
as they put the camera housings near dangerous areas (and not just on a big
empty wide stretch with a ridiculously low limit).  Naturally they move
around the actual cameras, so you're never sure which ones are actually
working or not.
Date: 18 Nov 2008 12:14:21
Message: <4922f7ed$1@news.povray.org>
> going to switch to red before you get to the other side?
That's what the yellow is for.
> morning I entered an intersection as it switched to amber (no way to
> stop in time), and I'm pretty sure it was on red by the time I got out
> the other side (around 20mph I guess, crossing 4 lanes of traffic and 2
They need a longer yellow light there.  As I said, in practice it's
usually not a problem.
Or look ahead a bit. Or wait for the turn signal.
Of course it all falls apart if the lights aren't designed properly,
yes. If the yellow is too short to clear the intersection at a
reasonable speed, or you have no left turn arrow when there's usually
lots of oncoming traffic, you'll be in trouble.
Date: 19 Nov 2008 02:50:09
Message: <4923c531$1@news.povray.org>
So, you make the yellow phase last long enough to cross the entire junction
at the slowest speed you can imagine for that junction?  I guess that would
work, but then when the road is flowing normally, people would just continue
to drive through on yellow, knowing that it is going to last for 5 seconds
or whatever, when the whole point of yellow is for you to stop if it's safe
to do so.
In China I saw a few lights where they had a big 7-segment countdown timer
above the lights, looked like a pretty cool idea, well it would have been if
they paid any attention to the lights in the first place :-)
Date: 19 Nov 2008 12:15:47
Message: <492449c3$1@news.povray.org>
> junction at the slowest speed you can imagine for that junction?
No. If you're going *that* slow, it's easier to stop. You make it long
enough to get through going at the slowest speed where it would be
unsafe to try to stop. :-)
> timer above the lights, looked like a pretty cool idea, well it would
> have been if they paid any attention to the lights in the first place :-)
Yeah. I'm rather surprised there's any Chinese people left alive, with
the way they do traffic there. :-)
"That's our hotel on the left."
    "Then why did the taxi driver pull into the right-turn-only lane?"
"The line's shorter."
Date: 20 Nov 2008 02:47:51
Message: <49251627$1@news.povray.org>
But my whole point is, how do you know it's about to switch to amber?  If
you enter the junction on green going slow enough, you won't make it to the
other side before it gets to red.
> Yeah. I'm rather surprised there's any Chinese people left alive, with the
To be fair that isn't *that* bad, I've seen quite a few cars do that here,
using the turn-only lane and then going straight, getting in front of about
20-30 cars in the process.  What I found particularly weird in China was
that they started to queue up in the lanes for oncoming traffic when at a
red light!  Or that you can be going around a corner on a 2-lane road at
50mph and suddenly you're faced with an old woman on a tricycle coming
towards you!
Date: 20 Nov 2008 11:56:14
Message: <492596ae$1@news.povray.org>
scott wrote:
> If you enter the junction on green going slow enough, you won't make it
> to the other side before it gets to red.
Stop on the green. Wait till it's clear on the far side.
It was for me! That's not a story, that's an experience. :-)
> on a 2-lane road at 50mph and suddenly you're faced with an old woman on
> a tricycle coming towards you!
Yeah. And the people on bicycles weaving out in front of the oncoming
busses.
Like I said, I'm surprised there's any of them left alive.
