![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Because when everyone had only 256 MB of RAM, there weren't cameras that
>> could generate 10 mega-pixel images, video cameras capable of creating
>> 1920x1080x30fps resolution video, DVDs that could store 8GB worth of game
>> data, graphics cards that were capable of rendering billions of
>> multiply-textured triangles per second etc etc.
> Only the last two there actually require any more RAM. The others just eat
> your harddrive faster.
Have you tried editing a 10MP photo? 10e6*3bytes = 30 MB, times several
layers and undo levels easily exceeds 256 MB.
Have you tried editing a full-HD video clip using your PC? Believe me, it
eats RAM, which is traditionally why the "video editing" PCs have been high
spec with lots of RAM.
> (As an aside... Are you serious? Are there really 10 megapixel cameras
> now? Last time I looked, 7 was about the biggest you could get. I mean,
> unless you pay silly money, obviously.)
Yawn! Check amazon! Loads priced between 100 and 200 pounds with 10MP.
> basically the cheapest thing in the shop.
While that may be true, I highly doubt that a PC would not have been
available at the time for under 1000 pounds. WHen was it and what spec? We
bought a P166 32MB in 1996 (IIRC), it cost something like 800 pounds and
certainly wasn't the cheapest one available.
> I just checked online. A copy of Vista that doesn't say "upgrade" on it is
Where the hell are you looking? On amazon they have the
all-singing-all-dancing full Ultimate edition for 217.98. The home-premium
edition is 147.48. If you want to upgrade, it's 68.98 for the home version,
and if you want the OEM version (basically tied to that PC) then you can
half those prices.
Of course, a company like Dell who buys in bulk will get it a lot cheaper,
assume they pay around half price, so that's 30 quid instead of 60 for home
premium.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nope. And neither has anybody else I've ever met. Generally it's a case
of "here's a photo, can you clip the edges to center his head? OK, now
print that 3 times." Requires almost no RAM at all.
1. Where in the name of God are you going to get HD video data from?
2. Assuming you edit something, where are you going to play it? Nothing
supports it yet.
3. Why would you need lots of RAM? Surely you just need a huge harddrive?
> spec? We bought a P166 32MB in 1996 (IIRC), it cost something like 800
> pounds and certainly wasn't the cheapest one available.
IIRC, it was about 1994. Back in those days, having a "home computer"
was considered somewhat unusual. I don't recall what spec; I think it
had 8 MB RAM and a 66 MHz CPU of some kind. Short of going back in time,
that's all I can tell you.
http://www.ebuyer.com/product/119995
Found it on their front page.
> cheaper.
Probably.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Nope. And neither has anybody else I've ever met. Generally it's a case of
> "here's a photo, can you clip the edges to center his head? OK, now print
Agreed. But if you only have "almost no RAM at all", eg 256MB, then it can
quickly become a problem. A few levels of undo and your harddrive is
thrashing.
A camcorder? People often take them on holiday and stuff, I'm sure you've
seen them. Again, look on Amazon under High Definition camcorders, prices
range from 150 pounds upwards. Or for geeks, maybe we create animations
using POV :-)
> supports it yet.
Ermm, you looked in a shop that sells TVs recently? Almost all support
HDTV, when you need to replace your TV you're not going to have a choice. A
quick Google revealed that in 2006 8% of homes had an HD-capable TV, that is
predicted to reach 70% by 2012 (guess it's at about 30% now then), so it
looks to me like lots of people have support for it already.
Editing programs use up as much of your RAM as they can to make everything
faster while you are working. Of course you can get away with less, but
things go really slowly with your drive thrashing away.
http://www.adobe.com/products/premiere/systemreqs/
They recommend you get the extra GB if you're planning to do HD editing.
Hmm, on amazon it seems to be half the price:
http://www.amazon.co.uk/Windows-Vista-Ultimate-Service-Pack/dp/B0013O77GM
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> OS+applications requires 1 Gb of RAM
> new OS+same applications requires 2 GB of RAM
> It's not the point that RAM is cheap the question is why do you need to
> double your RAM size in order to get similar results as with your previous
> OS?
Because Vista was designed for new computers? I guess MS saw it as a waste
of money optimising it for older machines.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> case of "here's a photo, can you clip the edges to center his head?
>> OK, now print that 3 times." Requires almost no RAM at all.
> can quickly become a problem. A few levels of undo and your harddrive
> is thrashing.
Maybe I've missed something, but what image editing software gives you
more than 1 level of undo?
I mean, I'm sure if you're a professional digital artist, you've going
to have some serious high-end software, and some spine-tinglingly
expensive hardware to go with it. But normal people? They're just going
to use the free Hyper Painter XL that comes with your camera...
> you've seen them. Again, look on Amazon under High Definition
> camcorders, prices range from 150 pounds upwards.
I own a camcorder. It bearly produces SD quality, never mind HD! And it
was not cheap by any stretch of the imagination. (So I'm told anyway. It
was a gift, so I didn't actually pay for it.) The idea that you could
seems really far-fetched to me.
> Or for geeks, maybe we create animations using POV :-)
And why do you think I own a DVD burner? ;-)
BTW, any ideas about *good* DVD authoring software? My drive came with
some freebie that works, but it doesn't work fantastically well...
>> Nothing supports it yet.
> choice.
Seriously, you're not going to throw away a perfectly good TV just so
that you can get a marginally-sharper picture, are you.
> A quick Google revealed that in 2006 8% of homes had an
> HD-capable TV.
That's a really tiny percentage.
And let's not forget, you still need an HD source. Those are still
prohibitively expensive too. (Last I heard, a BluRay player is abour
> everything faster while you are working. Of course you can get away
> with less, but things go really slowly with your drive thrashing away.
This suggests to me that you only need large stacks of RAM if you're
doing professional video editing work. I mean seriously, I don't even
*know* anybody else rich enough to afford a video camera, much less
technically expert enough to attempt to *edit* video beyond what you can
do with a DVD recorder...
OK, well that's a little less extortionate, but it's still pretty damned
expensive IMHO.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
48732ac7$1@news.povray.org...
I just bought from Dell a laptop (dual-core) and a desktop (quad) for 700
laptop has a 250 Gb HD and the desktop a 750 Mb HD and a 20 inch screen.
The trick with Dell is that there's always some "special deals" available
and if you're already a client they bombard you with discount vouchers and
such. Also, it's sometimes possible to buy at discount or even bulk prices
(down to 40% off), when one belongs to an organisation that is in
partnership with Dell.
> 4. Why in the name of God would you even *need* that much RAM anyway?
Unless one works exclusively with text-based applications, there's *** never
*** enough RAM. Others have mentioned it already, but even cheap cameras and
camcorder can now generate massive amounts of data and one needs a lot of
RAM to handle this smoothly. Particularly, non-geek family members can be
extremely Gigabytes-hungry once they figured out that one can take
great-looking movies of everything that moves ("no, you can't attach 15 Gb =
90 min of high-def wailing baby movie to your email and send it to all your
friends")...
But even for non-graphic, professional applications, there's never enough
RAM anyway: the more you have, the more you will be tempted to use and will
end up using: Law of the Constantly Maxed Out Resources.
G.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> to double your RAM size in order to get similar results as with your
>> previous OS?
> waste of money optimising it for older machines.
Getting an OS to work with less than a small star system's worth of RAM
doesn't requite "optimising", it requires basic design principles.
But then, Vista isn't really an OS, is it? It's an OS plus a huge stack
of other bits and pieces. I understand that out of the box you get DVD
authoring, a web server (!!), various online collaboration software, and
so forth. Not to mention layer upon layer of unecessary eye candy [which
may or may not be pretty, I don't know].
I think we can safely say that the *real* reason it demands so much
hardware is to keep the hardware vendors (M$'s real customers) happy.
(They say this is why Windows NT displaced Netware. What sane hardware
vendor is going to recommend a product that works on cheap hardware?)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Damn. My company *is* in a partnership with Dell. We bought 12 new PCs -
OptiPlex 755 with Intel Core 2 Duo 2.0 GHz CPU, 2 GB RAM and some
unit. What the heck do you know that I don't???
(As an aside... is there a reason why Dell is always 3x more expensive
than, say, HP, IBM, Acer, any other company on Earth?)
> *** enough RAM.
Really? I seem to have way more than I need. It's almost never fully
utilised, except when trying to build huge histograms. (Not a common
activity, obviously.)
Well, I was editing CDs on a machine with 2 MB of RAM about 10 years
ago... For complex video effects I guess you do need to hold quite a bit
of data in RAM at once though.
> friends")...
That's not even funny.
Sure, I can see needing huge amounts of HD space. I'm just not seeing
much need for huge RAM. And besides, I was talking about the bare
minimum amount of RAM required for Vista to even consider operating.
Presumably if Vista needs 2 GB to run, if you want to edit video *as
well* you'd need even more RAM...
(BTW... I did wonder why the hell WeV has 4x 360 GB drives. Until I
discovered that every single one of them is full to busting with illegal
DVDs he's downloaded. *shivers*)
Other than audio and video data (which is inherantly large), I can't
think of anything you can do with a computer that actually uses much
memory. Playing games involves audio and video data, but I'm
hard-pressed to think of anything else...
(Unless you're running some kind of server. Don't do that unless you
have stacks of... well, everything really!)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I mean, I'm sure if you're a professional digital artist, you've going to
> have some serious high-end software, and some spine-tinglingly expensive
> hardware to go with it. But normal people? They're just going to use the
Even MS Paint has 10 levels of undo. I got PSP free with some camera ages
ago (or it's like 50 quid I think), it has configurable levels of undo, the
default seems to be "500MB of space per open image" (I just checked, never
changed it before). You can configure it to a certain number of levels if
you want to.
Yawn! How old is it? For 800 pounds today you can buy a really decent HD
camcorder.
I think I used ULead DVD Movie Factory before, it worked pretty seemlessly,
but I didn't exactly tax it, I just wanted to put a few .avis onto a proper
DVD with a menu so a friend could watch them. Was really quick to use, had
some nice pre-set menu graphics to chose from, and burnt fine first time.
Yawn! You really should do a few clicks on amazon before making statements
like that. You do realise that for 900 pounds you can get a good quality 46
inch full-HD TV! Smaller ones are *considerably* cheaper (like less than
half that price).
> or so. Only rich geeks need apply...)
Yawn! Under 200 pounds now.
> much less technically expert enough to attempt to *edit* video beyond what
> you can do with a DVD recorder...
Programs like Windows Movie Maker make it pretty easy. Judging by the
number of videos on YouTube made with it, I guess a fair number of people
worked out how to use it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I got PSP free with some camera ages ago (or it's like 50 quid I think).
Really? Every camera I've ever seen comes with some random paint package
that nobody ever heard of... [And which does almost nothing beyond
colour adjustments and automatic red-eye removal. Ooo, and maybe a few
warps.]
>> it was not cheap by any stretch of the imagination.
About 1 year?
> For 800 pounds today you can buy a really decent HD camcorder.
I didn't think you could buy a *still* camera for that kind of money.
> seemlessly, but I didn't exactly tax it, I just wanted to put a few
> .avis onto a proper DVD with a menu so a friend could watch them. Was
> really quick to use, had some nice pre-set menu graphics to chose from,
That's more or less the level of what I'm trying to do too. I make
POV-Ray render some insane stuff, build AVIs out of it, and then put it
onto a real DVD so it can be played anywhere. (Plus playing uncompressed
video seems to stress my HD.)
The thing I've got seems to crash a lot. It allows you to do some
limited video editing, but stubbornly refuses to allow you to do things
like insert pauses or writing and so on.
> statements like that. You do realise that for 900 pounds you can get a
> good quality 46 inch full-HD TV! Smaller ones are *considerably*
> cheaper (like less than half that price).
You do realise that I was *in* Curries looking at new TVs only a few
days ago, right?
Really? That's a rather sudden price drop, don't you think? I mean, the
format is still brand-spanking-new. Are there even any BluRay titles to
play yet?
>> what you can do with a DVD recorder...
> people worked out how to use it.
Now that's just puzzling. I tried to use Windows Movie Maker once, and
it wouldn't do *anything* I wanted it to do. Sure, I could take a bunch
of videos and join them together to make one video. But that seemed to
be the sum total of its abilities.
OTOH, most videos on YouTube seem to be unedited mobile phone videos... :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
