POV-Ray : Newsgroups : povray.off-topic : Adventures with digital painting Server Time
17 May 2026 12:06:53 EDT (-0400)
  Adventures with digital painting (Message 108 to 117 of 197)
Subject: Re: Adventures with digital painting
Date: 10 Mar 2008 14:22:46
Message: <47d58a86$1@news.povray.org>
Jim Henderson wrote:
> You say "tomayto", I say "tomahto".
Difference is, all the little bits and pieces that make up Windoze all
come from one manufacturer, there's only one version of them, and
they're all extensively tested together.
Linux, OTOH... You don't often find two machines set up exactly the same
way. And all the individual parts are from different people, and there
are a myriad of possible versions and implementations.
http://blog.orphi.me.uk/
Date: 10 Mar 2008 14:47:58
Message: <47d5906e$1@news.povray.org>
You need to look at how the software checkins and testing are handled for
the kernel.
And you need to look up again the definition of "DLL Hell".
Not so different as you might think.
Jim
Date: 11 Mar 2008 04:24:30
Message: <47d64fce@news.povray.org>
> the kernel.
Who said anything about the kernel? I'm talking about the entire Linux
OS. (Most of which is actually GNU, if you want to be technical about it...)
I have yet to experience "DLL Hell". I'm told it exists, and it's not
fun, but I haven't seen it personally. (Don't ask me why...)
Date: 11 Mar 2008 10:12:56
Message: <47d6a178$1@news.povray.org>
>>> same way. And all the individual parts are from different people, and
>>> there are a myriad of possible versions and implementations.
>> for the kernel.
> it...)
So yes, be technical about it, then - I don't know of any Linux distro
that uses "standard" tools that aren't GNU, be it awk, sed, perl, bash,
etc.
You've been lucky.  Last company I worked for had many applications with
DLLs in common but requiring different versions.  We had a team of
software deployment engineers who did testing to ensure the software
would all work together and work around the issues of needing multiple
versions of the same DLL.
Jim
Date: 11 Mar 2008 10:34:29
Message: <47d6a685$1@news.povray.org>
>> it...)
> etc.
Except that Unix /= Linux. There's also BSD and Solaris and random stuff
like that... and autoconf works with all of them.
"Windoze" is more or less one product line. Binaries work unmodified on
most versions of it. (Assuming the features they use are there.) "Unix"
is not one product. It's not even close to being one product. It's a
vast stew of different products all bolted together in a giant mess.
> You've been lucky.
Let's hope it stays that way...
Date: 11 Mar 2008 10:42:34
Message: <47d6a86a$1@news.povray.org>
>>> it...)
>> bash, etc.
I'm not sure if it's possible to put a non-GNU userland (like BSD) along
with a Linux kernel, but it's definitely possible to have GNU userland
on many kernels, like BSD.
Heck, the "BSD Subsystem" package for my iPod was based in BSD (duh), I
removed it and installed Telesphoreo (much better package of unix tools)
and it's based on GNU tools. Kernel is Mach for ARM processor. I have
yet to try autoconf stuff there :) (somebody is struggling to get a
native compiler working)
Date: 11 Mar 2008 13:08:24
Message: <47d6ca98@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> In other words, if you completely bypass the shell, it can be made easy
>> to work. Otherwise you get things like "no such user John.tmp" when you
>> try to delete "~John.tmp".
>   Only if you write "~John.tmp" by hand instead of letting the shell do
> the proper expansion.
Or if you pass it through another program that also tries to do the
expansion. I.e., if it goes thru the shell more than once.
>   Well, if "rm *" works (ie. there aren't too many files), you don't.
> If there are too many files, I suppose you'll have to use the 'find'
> trick.
Yep. Then it gets very slow, or very complicated.
>   If you do a "scp *" it won't ask the password for each one.
Again, I tend to work with tens of thousands of files at once.
>> , so you either have to use xargs (with the -0
>> switch, which is why that's there!) or manage to tar them up somehow,
>> which has the same problems.
>   What's the problem with tarring them? "tar -cvf . files.tar"
If you want to select a subset of files to tar up, then it becomes very
difficult.
> However, I haven't seen any problems with special characters so far.
Well, clearly we work on different kinds of things. And yes, shells have
gotten way better lately, but if you wind up doing multiple passes
through a shell (i.e., a shell script looping and calling another shell
script) it gets messy.
>   The only valid point you have presented is the too-many-files argument,
See above. If you have a shell script to process something, it takes
magic escaping.
Explain the "-0" argument to find and xargs if it isn't otherwise a problem?
>> Having the shell doing your expansion has caught me other times, too...
>> % cat a b c >d
>> Can't create d: permission denied
>> % sudo !!
>> Of course, the real line was much longer, so a simple "su" meant
>> retyping the line (or using copy-and-paste to retype it for you) instead
>> of just !! or up-arrow. :-)
>   What's wrong with getting the command from the command history with
> the up cursor, going to the beginning of the line with ctrl-a and then
> adding the "sudo" there?
Because it still doesn't work. SUDO doesn't kick in until after the
output redirection is done, so "sudo echo xyz >pdq" doesn't overwrite pdq.
>   Still many shell scripts fail to use the basic "$@" for the correct
> expansion of all the parameters (and instead use $*, which is wrong).
That too. And it still doesn't work when there are too many files.  I'm
not really sure why it's even limited, given I've got 16 gig of real
memory and twice that of virtual memory. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 11 Mar 2008 13:11:19
Message: <47d6cb47@news.povray.org>
>> (I work with big directories, and big files. Often I'll have a program
>> that runs 3 hours, then takes half an hour to delete its input files. Or
>> individual files that take 2 minutes of disk I/O to delete. Or empty
>> directories that take several minutes to delete because they used to
>> have six or seven million files in em.  And of course, the machine
>> becomes completely unusable during any sort of operation like that.)
>   Isn't that a clear sign that a re-design of your programs is in place?-)
Probably not. I don't know any other way of storing several weeks worth
of CD-quality audio in a way that is easy to extract portions, then
delete the beginning without affecting the end.
Now, if Linux supported the thing that NTFS supports where you can
delete the beginning of a file, maybe I'd use that. But as it is, I have
to chop the file up so I can delete parts of it.
Plus, of course, the device buffers on the audio device get upset if you
tell it to try to accumulate a gig of audio data before handing it over
to your software. :-)
Date: 11 Mar 2008 13:11:59
Message: <47d6cb6f$1@news.povray.org>
> But if I wanted it to work all the time, I'd write it in C and be done
> with it - then the shell doesn't come into play. :-)
Yah, as I said, when it gets messy, I use Tcl. :-)
Date: 11 Mar 2008 13:12:30
Message: <47d6cb8e$1@news.povray.org>
> Can filenames have null characters on them? :)
No. The only thing Linux (and most other unix) filesystems disallows is
slash and NUL.
