POV-Ray : Newsgroups : povray.off-topic : Portal Server Time
9 Jun 2026 17:05:09 EDT (-0400)
  Portal (Message 26 to 35 of 35)
Subject: Re: Portal
Date: 20 Oct 2007 04:24:21
Message: <4719bb35$1@news.povray.org>
Slime wrote:
>> PS. Do you have HL2:EP2? I can't complete [what is probably] the final
>> battle. It's just too hard.
> I found it very difficult also. The trick seems to be taking out as many
> hunters as you can before working on the striders, since the hunters destroy
> the magnessons.
This is a problem. The Hunters can't die. (Or rather, they can't die
unless you unload your entire ammo supply at them for about 5 minutes.
Then *one* of them dies. But there's still 7 others waiting to be
killed. Oh, assuming they don't surround you and kill you first...)
> You definitely have more than 20 seconds though if you
> handle them one at a time.
Yeah, but... in spite of the radar, I can't *find* them until they're
practically on top of the base. I then have about 20 seconds to take 'em
out. (And they all arrive at once...)
> Taking down the hunters is the hardest part; you
> can accumulate explosives ahead of time (bring them to the beginning of the
> area, the choke point that all striders will have to pass through). You can
> also take any hunter out with the alternate fire of the combine pulse rifle
> (don't miss! quicksave ahead of time) or a couple rockets. When you run out
> of those and explosives, try running them over with your car. When all else
> fails use the shotgun.
I can't find any damn ammo anywhere. I keep ending up with almost none left.
The car seems to be the only fast way to kill a hunter. But the car is
so utterly uncontrolable, and the hunters are so nimble... well, you
don't stand much of a chance. (The only other way is the orb fire from
the pulse rifle. But then we're talking 100% pure luck as to whether you
hit or not. And you only get 3 shots in the entire game.)
> If you drive around, and you should at first to make use of the items in the
> more distant buildings, use the magnesson holder on the back of your car.
Damn right. All the other supply dealies have already been blown up, so
every time I miss with a magnesson, I have to drive 20 minutes back to
the base to get another one... :-(
> If at any point a strider is getting too close, start using magnessons on it
> even if there are still hunters around. If you've taken out enough of the
> hunters you can sometimes get the strider anyway.
This is basically what I'm reduced to doing. Hoping I can take out all
five striders by pure pot luck. So far I've replayed the same 90 seconds
of game endlessly for about half an hour, and I just can't take 'em all
out fast enough. :-{
Subject: Re: Portal
Date: 20 Oct 2007 06:37:57
Message: <4719da84@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
> The main problem is walking through one portal, falling out of the
> other, rotating cat-style while in free fall, trying to figure out where
> the hell you are and which way you're facing, and... oh wait, I'm on the
> ground again. :-S
  I don't see what's the problem with that. If both portals are on vertical
surfaces, you just walk through, like through a regular door, and "down"
will be "down" and nothing else. Just turn down and shoot before hitting
the floor.
  Even if one of the portals is not on a vertical surface, visualizing
the situation is helped by being able to visualize 3D space, like when
designing POV-Ray scenes in your head. :P
Subject: HL2:Ep2 (was: Portal)
Date: 20 Oct 2007 06:56:35
Message: <4719dee3@news.povray.org>
  Yes, but I haven't played it through yet.
  Once again Valve failed to disappoint with this game. It's very immersive
and addictive from the very start. I'm also impressed about the amount of
graphics and special effects they have succeeded in putting in the levels
and still maintain a very good framerate. (It barely doesn't reach the
level of detail of Oblivion, but OTOH it has a much better framerate.)
  I like the strong storylines of the HL2 series.
  Most FPS games have very weak, almost inexistent storylines, where the
makers clearly haven't put too many resources in them. You get an intro,
a few short plot details here and there, and an outro. Usually it's all
rather simple and not very worked. Usually even the little plot there is
doesn't seem to matter too much. It's more like "yeah, yeah, blah blah,
let me play already". Also the backstory often is very detached from the
game itself.
  Not so with the HL2 series. The stories are believable and interesting,
and they have clearly put a lot of effort in merging the plot and the
gameplay, to make it more interesting.
  In the past some FPS games have tried the concept of NPC sidekicks, and
usually failed miserably. Usually these sidekicks are completely useless,
annoying and more a burden than anything else (especially if them dying
means game over).
  In some games mandatory sidekicks are extremely stupid. A very prominent
example is Oblivion, where it feels like your allies are constantly moving
to your line of fire, so that you will hit them instead of the enemy. It
gets really irritating very soon, especially when there's a bad consequence
of hitting an ally (such as being expelled from a guild).
  Again, not so in the HL2 series, especially episodes 1 and 2. The
sidekicks are actually helpful and not annoying at all. They really are
very strong allies in fighting, and they mostly know how to keep out
of your way (even though I think you couldn't even hurt them even if
you shoot at them, but it's good that they keep out of your line of fire
just for visibility reasons if nothing else). Also if they are blocking
your way in a narrow passage, they usually move away quite promptly when
needed.
  Also, the allies (especially Alyx) are not just dumb gameplay elements,
but add to the plot. They act, they tell you things, and they direct your
attention to events (one good example being the beginning of Episode 2,
where Alyx tells you to look at the railway bridge).
<nerd mode>
  It's also cool to drive with Alyx at your side. It almost feels like
in a date.
</nerd mode>
Subject: Re: HL2:Ep2
Date: 20 Oct 2007 07:46:00
Message: <4719ea78$1@news.povray.org>
As I have written previously, I have been quite dissapointed with HL2
and HL2:EP1.
*This* game, however, is FUN. (Remember fun? Fun is good...)
...as in, "you are the last survivor, trapped alone on the alien
homeworld. Try to stay alive!"
HL1 kind of had more of a concept of a story than most. (In particular,
you play through the beginning of the "story" - which was novel at the
time.) HL2 takes it slightly further. But it's really EP1 and EP2 where
the story element becomes quite strong.
Yeah, this is a rather tough game design challenge.
Real humans possess a level of intelligence that AI designers can
currently only dream about. So you have to somehow make an NPC who won't
die too easily, but isn't too invincible either. They have to be able to
help you in a battle, but not win the whole thing for you. And -
possibly hardest of all - they have to act believably whatever the
player decides to do. (How the heck are the designers supposed to
anticipate that one? Well, they can't really...)
> of your way. Also if they are blocking
> needed.
Especially in HL2, allies getting in your way seemed to be a constant
problem. They seem to have fixed this in EP1 and EP2.
Some *real* plot twists in EP2... heh. (What the heck is that G-Man
actually up to, anyway?)
> <nerd mode>
> in a date.
> </nerd mode>
<ubernerd mode>
   I'll have to take your word for that one...
</ubernerd mode>
(BTW, is there a *reason* why she always has to climb into the car
starting from your side? What's wrong with the *door* on her side?? Is
it just so you get to have a look at her cute high-polygon butt?)
Date: 20 Oct 2007 09:53:56
Message: <471a0874@news.povray.org>
  I suppose that the AI can't know if you are going to enter the car or
not, so it just follows you as usual. If you do enter the car, then a
pre-determined animation is played when she enters the car too. I suppose
that they noticed that if she just walked around the car you could just
drive away and let her behind, so with this pre-determined animation they
made it impossible to do so, while still looking at least somewhat convincing.
Subject: Re: Portal
Date: 20 Oct 2007 14:18:19
Message: <471a466b@news.povray.org>
> The Hunters are virtually indescructible, and you only have about 20
> seconds to kill 7 of them
  You have to go where the striders are, not wait until they come to you.
First kill the hunters. The car is a good weapon for this, but you can also
use the rocket launcher, etc. Once they are out, killing the strider is
relatively simple.
  The end is rather... disturbing.
Subject: Re: Portal
Date: 20 Oct 2007 14:24:00
Message: <471a47c0$1@news.povray.org>
Even with the radar, it's extremely hard to find them.
And, assuming you find them, you're now in a place with no ammo or
supplies...
> relatively simple.
The car *is* good for killing them, but it's extremely hard to steer.
(Let's face it, try driving a *real* car at more than 5 MPH while
snapping the steering onto hard lock...) And the hunters easily step out
of your way.
I tried the rocket launcher and the orb from the pulse rifle, but
rapidly ran out of ammo. The machine gun takes forever to take 'em
out... :-(
Yeah, well, if I ever get that far... :-}
(Don't you just love games where the final climactic battle is *so*
climactic that it takes 5 times longer than the rest of the game put
together?)
Subject: Re: Portal
Date: 20 Oct 2007 15:17:44
Message: <slrnfhkl2o.cm7.bisqwit@bisqwit.iki.fi>
> ground again. :-S
Precisely the same problem here. It looks so easy when the people
who post at youtube do it, but when I do it, I'm almost never facing
the correct direction when raising up from a portal placed in floor
after falling through another also in the floor (yes, talking about
level 18).
Also regarding the puzzles, I'm impressed at Warp's acute sense of
solutions. I was stuck somewhere for a long time, and ended up inventing
"wrong" solutions at a couple of places instead of much simpler ones.
But I'm no gamer, this is the first video game _ever_ that I have bought.
Joel Yliluoma - http://bisqwit.iki.fi/
: comprehension = 1 / (2 ^ precision)
Subject: Re: Portal
Date: 20 Oct 2007 15:38:57
Message: <471a5950@news.povray.org>
> out... :-(
  One thing you can try is to catch one of the hunter's explosives with
the gravity gun and throw it back. Easier said than done, but they are
pretty effective when you succeed...
Subject: Re: Portal
Date: 20 Oct 2007 15:42:36
Message: <471a5a2c$1@news.povray.org>
>> out... :-(
Interesting concept...
I've never been really good with the gravity gun. I mean, you point it
at some huge metal barrel, press the button, and it picks up a tiny
pebble 6 feet to the left of what you're pointing at. WTH?
