POV-Ray : Newsgroups : povray.newusers : Radiosity example Server Time
9 Aug 2025 11:28:51 EDT (-0400)
  Radiosity example (Message 1 to 10 of 15)
Subject: Radiosity example
Date: 6 Nov 2012 01:00:04
Message: <web.5098a702d2be5305aaeb765e0@news.povray.org>
Could somebody kindly post complete code for a very simple scene that uses
radiosity?  Maybe a white plane with a white box and nothing else.  No matter
what I try, I get either blackness or no effect.  Something's not clicking I
guess :(
Thank you!
Subject: Re: Radiosity example
Date: 6 Nov 2012 03:14:26
Message: <5098c6e2$1@news.povray.org>
> guess :(
> Thank you!
Take one of the basic scenes from the Insert Menu, and add the following
block (using version 3.7 btw):
global_settings {
   adc_bailout 0.003922
   assumed_gamma 1.0
   max_trace_level 10
   number_of_waves 10
   noise_generator 2
   radiosity {
     brightness       1.0
     count            100, 500
     error_bound      1.8
     gray_threshold   0.0
     low_error_factor 0.5
     minimum_reuse    0.015
     nearest_count    10, 5
     recursion_limit  2
     adc_bailout      0.01
     media            off
     normal           off
     always_sample    off
     pretrace_start   0.08
     pretrace_end     0.004
Date: 6 Nov 2012 06:30:33
Message: <5098f4d9$1@news.povray.org>
> guess :(
Try this:
#default {finish {ambient 0}}
#include "rad_def.inc"
global_settings
   assumed_gamma 1.0
   radiosity {Rad_Settings(Radiosity_Normal, off, off)}
camera
   location  <0.0, 1.0, -3.0>
   look_at   <0.0, 1.0,  0.0>
   angle 90
light_source {< -10,  10, -10> color White}
sphere
   0, 1000 pigment {color SkyBlue} hollow
plane {y, 0 pigment{checker color White color Black}}
sphere {y,1 pigment {color White}}
Date: 7 Nov 2012 22:10:00
Message: <web.509b2221108ff70baaeb765e0@news.povray.org>
> > guess :(
> Try this:
> global_settings
>    assumed_gamma 1.0
> camera
>    angle 90
> sphere
Thank you- that did work, but apparently I'm still not understanding something
because when I remove the light source I see blackness.  I thought the point of
radiosity was that there was some "general" light without needing a specific
light source.
So I was expecting that even without an explicitly defined light source there
would still be some light.
Kind of like this:
http://www.povray.org/documentation/images/tutorial/radB_01.jpg
I also tried making the SkyBlue sphere glow by adding finish{ambient 1} to it's
definition, but still got blackness.  What am I missing?
Date: 8 Nov 2012 07:11:59
Message: <509ba18f$1@news.povray.org>
>>> guess :(
>> Try this:
>> global_settings
>>     assumed_gamma 1.0
>> camera
>>     angle 90
>> sphere
> light source.
> Kind of like this:
Because if using radiosity is used any ambient term are effectively zero
... try emission instead
http://wiki.povray.org/content/Reference:Finish#Emission
Date: 8 Nov 2012 08:20:57
Message: <509bb1b9$1@news.povray.org>
Am 08.11.2012 04:08, schrieb taftj:
> light source.
No, the main point of radiosity is that shadows are illuminated by
diffuse light from other objects.
A side effect of radiosity is that you /can/ also get illumination from
a sky sphere or background (this is automatic), and even objects (this
requires a suitable finish setting; previously this could be done by
using a non-zero "ambient" finish term, but this was originally just a
hack and has always been troublesome, so as of POV-Ray 3.7 the new
"emission" term needs to be used instead).
Date: 19 Jun 2013 10:48:59
Message: <51c1c4db@news.povray.org>
>> uses
>> matter
>> clicking I
>> guess :(
>> Thank you!
> global_settings {
>   assumed_gamma 1.0
>   max_trace_level 10
>   number_of_waves 10
>   noise_generator 2
>   radiosity {
>     brightness       1.0
>     count            100, 500
>     error_bound      1.8
>     gray_threshold   0.0
>     minimum_reuse    0.015
>     nearest_count    10, 5
>     recursion_limit  2
>     adc_bailout      0.01
>     media            off
>     normal           off
>     always_sample    off
>     pretrace_start   0.08
>     pretrace_end     0.004
> Thomas
Hi Thomas,
I know this is kind of an old message, but I'm hoping you are still out
there...
I tried your suggestion with several of the canned examples from the
insert menu and have found an unexpected (by me) result.
On scenes such as Basic_Scene_05: Grass with small clouds in sky, your
settings cause the sky to go from a bright sunny blue sky in the
original scene, to a dark, grey, stormy-looking sky.
I was wondering if you, or anyone else, could explain what is going on.
I'm using POVray 3.7 RC7.
Todd
Date: 19 Jun 2013 10:59:35
Message: <51c1c757$1@news.povray.org>
On 19-6-2013 16:48, Todd Carnes wrote:
> Hi Thomas,
> there...
Elementary, my dear Watson ;-)
The basic scene comes from an older version of POV. In version 3.7, the
ambient parameter in finish does not work as before. You have to replace
it by emission and the scene renders correctly.
Date: 19 Jun 2013 11:22:14
Message: <51c1cca6$1@news.povray.org>
> Thomas
Thank you for the prompt answer. :)
Date: 20 Jun 2013 03:06:18
Message: <51c2a9ea$1@news.povray.org>
Musing...
It is not a /bug/ strictly speaking, as the scene renders correctly in
its original state, without the radiosity block. The reason is
adequately described in the wiki Docs (section 1.3.5.3.2).
However, it is something to remain aware of when building scenes from
pre-defined ones.
