On 18-10-2012 20:42, Christian Froeschlin wrote:
> Vincent wrote:
>> and I don't think that there would be something wrong with triangles
>> (though I
>> prefer this one)becuase the STL file is generated by a 3D modeller
>> software.
> Looking a bit closer I think something is *seriously* wrong with
> your triangles
> <1.35632e-019, 1.35632e-019, 1.35632e-019>,
> <0.0147179, 0.999892, 0.000199087>,
> <0.000173748, 1.35632e-019, 3.35076e+012>,
> You don't want vertexs anywhere near z= e+012 ... ;)
> And the e-019 is also suspicious although it might just
> be a 0 with numerical errors.
What 3D modeller did you use, and what kind of model did you export to
POV-Ray? Those answers might help a lot.
Try to model a simple object in your modeller and export it the same way
to POV-Ray, for example a sphere or a torus. Does it show correctly in
POV-Ray?
> POV-Ray?
> Thomas
The original model has been created using Finite Element method in ANSYS. It's
a relatively complicated model. I have been given a file of it in STL format,
which by using stl2pov I converted it to inc format. It's a huge file (312 Mb)
including over 14E6 triangles!!I exported this inc file in povray. I need to
simulate the light reflection properties of the model has been given to me.
Really need help!!
Vincent
> Really need help!!
I am not familiar with ANSYS but maybe others here are. My guess is that
something went wrong at the conversion level or that the original object
got corrupted. Would it be possible to convert STL to OBJ (or any other
format supported by Poseray)? Then you could convert to POV-Ray using
Poseray, with as bonus a mesh2 object.
> ANSYS. It's a relatively complicated model. I have been given a file
> of it in STL format, which by using stl2pov I converted it to inc
> format. It's a huge file (312 Mb) including over 14E6 triangles!!I
> exported this inc file in povray. I need to simulate the light
> reflection properties of the model has been given to me. Really need
> help!!
Perhaps something went wrong with stl2pov and such huge mesh... you
may want to try other paths. For example, load the STL into Blender,
export it as 3DS or OBJ and then use Poseray to convert it to POV mesh2.
Jaime
If all of this doesn't help, why don't you try Poseray to convert your scene to
POV format? I presume your mesh was originally an .obj
My guess is that something went wrong at the conversion level or that the
original object got corrupted. Would it be possible to convert STL to OBJ (or
any other format supported by Poseray)? Then you could convert to POV-Ray using
Perhaps something went wrong with stl2pov and such huge mesh... you may want to
try other paths. For example, load the STL into Blender, export it as 3DS or OBJ
Jaime
number of triangles is correct, also at the end of .inc file I can see the
statement : }//end of mesh.
And my mesh originally was in .nas format. But have been told that it is just a
sort of STL format.
But as you, Jaime and Thomas are suggesting I have to try other paths, for
preview.
Vincent
> sort of STL format.
> preview.
I don't want to nitpick but I have the feeling that your object is
corrupt, despite the correct number of triangles. The fact alone, as
Alain also mentioned, that [quote] Your range of values going from 1e-19
to 1e12 is extreme with a variation of 31 orders of magnitude [/quote]
makes me think that all is not well.
>> because the
>> the
>> is just a
>> sort of STL format.
>> for
>> give me a
>> preview.
> Thomas
Yeah. Its possible for things to go very odd sometimes in a design. Last
one I had to redo from scratch (not just due to the glitch, but because
I didn't think the design through very well). It seems, some place in
the process I deleted, or connected, something wrong and got what I call
"ghosts". Sides, or faces, which don't connect how they are supposed to,
and produce non-solid surfaces. The result exported to cae, which I was
trying to use to import to Second Life, but nothing, not SL, or Blender,
or even the program that exported it in the first place, would load the
thing. Most just failed without an error. Second Life said something
about a value being wrong, or something, when it failed.
Unfortunately, finding these problems, never mind fixing them, in the
programs that create the meshes, is usually totally impossible. :(
Maybe, something that let you handle "discrete" points, like Rhinoceros,
could do it, but most can't handle those, let alone say, curved, without
at least a single "face". Some won't even allow single faces, and
instead require solids. So, when you accidentally mangle one of those
solids, its impossible to correct the problem. Sometimes those things
will also mess with the exporter, or even, as in my case, create a
seemingly valid export, which just flat won't import into anything at all.
Guys, many thanks for catching my error. The problem is not solved yet but now I
am more confident that the converted file is corrupt. Working on it!
Best regards,
Behrooz
"Vincent" <nomail@nomail> wrote:
And here is the solution:
As you mentioned there was an error in file converting. Actually, my file with
..nas extension was not a kind of STL format! It was generated by NASTRAN. So, at
first I converted it to the STL using Gmsh. Then using MeshLab i converted it to
OBJ. And now it could be opened (beautifully) using Poseray. without any error.
Thanks to all again.
