POV-Ray : Newsgroups : povray.newusers : problem with light source Server Time
28 Sep 2024 18:56:42 EDT (-0400)
  problem with light source (Message 1 to 8 of 8)
Subject: problem with light source
Date: 25 May 2012 06:30:01
Message: <web.4fbf5e4e730a93abf14493220@news.povray.org>
Can somebody tell why is sphere in light_source, looks_like black?
#include "shapes.inc"
#include "textures.inc"
#global_settings {ambient_light Yellow}
#declare FRONT_TEXTURE = texture {
 color red 0.439215 green 0.847058 blue  0.407843
 finish {
 ambient 0.5
 diffuse 0.4}
 #declare BACK_TEXTURE = texture {
 color red 0.980392 green  0.862745 blue  0.415686
 finish {
 ambient 0.8
 diffuse 0.6
 phong 0.5
 phong_size 1
#include "Mesh.inc"
//Plane
 plane { y,-2800
        checker color red 0.99 green 0.1 blue 0.070588 color red 0.121568 green
0.558823 blue 0.19607
        scale 1600
     finish {
        ambient 0.2
        diffuse 0.9
        phong 0.9
        phong_size 100
plane { -z, 12500
        scale 1600
    finish { ambient 0.1 diffuse 0.6 }
//camera
 angle 59
 location  <-200.0, 300.0, 590.0>
 right     <1, 0.0,  0.0>
 up        <0., 1, -0.5>
 rotate    <-4,-11,0>
 direction <0.35, -0.5,  -1.0>
#declare svjetlo = sphere {
        <10.5, 10, 0>, 80
        color White
        translate <1.5, 0, 0>
 // Light source
 light_source {
                <-280,180,-400>
                color White
                looks_like {
                          sphere
                                { <-0,0,-0>,20
                                  //color White
                                  finish {
                                        ambient -0.9
                                        diffuse 0.9
                                        phong 1
  translate <-10,150,700>
Subject: Re: problem with light source
Date: 25 May 2012 06:44:47
Message: <4fbf629f@news.povray.org>
  Because nothing is illuminating it and its ambient is negative. (Well,
technically speaking something *is* illuminating: The light source in
question. The problem is that it's illuminating it from the inside, not
the outside.)
  The easiest way to make it fully white is to specify "ambient 1" in
the sphere's finish.
Date: 25 May 2012 07:05:01
Message: <web.4fbf667e89971957f14493220@news.povray.org>
Yeah, that helped. And could You tell me, how can I make it blurry, so that I
have more realistic source of light?
> the outside.)
Date: 25 May 2012 07:25:01
Message: <web.4fbf6ade89971957f14493220@news.povray.org>
I want it to look something like this:
http://imageshack.us/photo/my-images/856/povrayslika1.jpg/
Date: 25 May 2012 07:51:39
Message: <4fbf724b@news.povray.org>
  You have two options, one "proper", and another using a trick.
1) The "proper" way to do that is to make the sphere completely transparent
(by making its pigment be "transmit 1") and then add a spherical emitting
media inside it. (Remember to use the keyword 'hollow' in the sphere or
else the media won't show up.)
2) The easier and faster way is to use a trick: Make the sphere completely
transparent (with "transmit 1") like above, but instead of adding a media
to it, add "specular 1" to its finish. (You can fine-tune the brightness
and size of the apparent "halo" produced this way by changing that 1 to
something else as well as specifying different values of "roughness".
Start with "roughness 0.01".)
  I recommend trying the second method first, as it will probably suit
your needs.
Date: 25 May 2012 07:55:36
Message: <4fbf7338@news.povray.org>
  Btw, this has the downside that now other lights will shine on this
transparent sphere as well. You can fix that problem by using light groups
(http://wiki.povray.org/content/Reference:Light_Group)
Date: 25 May 2012 20:49:14
Message: <4fc0288a$1@news.povray.org>
Am 25.05.2012 13:51, schrieb Warp:
With this approach, make sure to explicitly specify "specular 0".
or, 3) If you're using POV-Ray 3.7, you can make use of the "aoi"
pattern to blend between rgbt <1,1,1,1> and rgbt <1,1,1,0>.
Date: 26 May 2012 22:28:03
Message: <4fc19133$1@news.povray.org>
In that image, you don't see the light_source at all, but the highlight
they cause.
The sources are well out of view of the camera and there are no
reflective surface.
In POV_Ray, there are 2 models of highlight: specular and phong
To turn it on, you simply add in the finish of the objects that are to
show them:
(this renders fast)
phong [value] phong_size [value]
(use large phong_size to make smaller highlight)
or
specular [value] roughness [value]
(use small roughness to make the highlight smaller)
(this can be quite slow)
Another option is to use blured reflection, but it can greatly increase
the render time, especialy if you have inter-reflections of surfaces
using blured reflection...
Can be aleviated using 2 instances of the objects, one been
no_reflection having the blured reflection and one with no_image having
only regular reflection.
If you do see the light_source, then the propositions from Warp are good
ones.
(this can be VERY slow)
You can also put some scattering media filling your scene, the best one
been probably scattering type 3.
This will greatly affect your rendering time.
