POV-Ray : Newsgroups : povray.newusers : Sky_sphere is not smooth Server Time
18 Nov 2025 20:04:54 EST (-0500)
  Sky_sphere is not smooth (Message 1 to 8 of 8)
Subject: Sky_sphere is not smooth
Date: 16 Aug 2011 15:05:01
Message: <web.4e4abe43ddb4bd33762883f20@news.povray.org>
I have a problem: I want to use sky_sphere to make a sky, but for some reason it
does not change color smoothly, you can cleary see lines that separate different
"regions". I played with Antialias_Threshold, thinking that is the key, but
whatever I do I keep having this ploblem.
Here is my code.
#version 3.5;
// ************************   Camera   ***********************
#local Cam = <-5, 6, 12>;
        #local to = <2, 0.9, 6>;
        #local rat = 1;
        location rat*Cam + (1-rat)*to
        look_at to
        angle 38
// ************************   Lights   ***********************
light_source {
    Cam
    color 0.4*<1,1,1>
    shadowless
sky_sphere {
      gradient y
      color_map {
        [ 0.0 color rgb <0.8,0.2,0.2> ]
        [ 0.4 color rgb <0.8,0.8,0.4> ]
        [ 0.8 color rgb <0.3,0.0,0.5> ]
        [ 1.0 color rgb <0.0,0.0,0.0> ]
      scale 2
      translate -1
      rotate 70.2763614*z
      rotate -105.46554492*y
The resulting image: http://dl.dropbox.com/u/1655276/esfera.png
Can anyone give me a clue?
Subject: Re: Sky_sphere is not smooth
Date: 16 Aug 2011 16:36:01
Message: <4e4ad4b1@news.povray.org>
> "regions".
  It looks quite smooth to me.
  If you are talking the region where the purple-blue transition changes
to blue-black, where the exact point of change which has the purest blue
stands out from the rest, that's not really a problem with povray. If you
create the same kind of gradient in any program it will look like that.
(The reason is, very technically speaking, that there's an abrupt change
in the slope of the color transition curve.)
  Getting rid of it can be a bit tricky. (Basically it would need for the
color change slope to itself be smooth.)
Date: 16 Aug 2011 16:55:01
Message: <web.4e4ad8f34f03222d762883f20@news.povray.org>
> > "regions".
Thanks a lot, warp.
I think I understand what you mean, the color function is not derivable
too many times.
Anyway I see all over the image lines that are like "height lines" in a map. I
just thought maybe it is a problem with my colour configuration. I will try
tomorrow to see the same image in another computer.
Thanks again,
Date: 16 Aug 2011 18:10:09
Message: <4e4aeac1$1@news.povray.org>
You will see this if your display is set up for 16-bit color. It looks smooth to me at
24-bit or 32-bit color.
Date: 16 Aug 2011 18:42:51
Message: <4e4af26b@news.povray.org>
I can also see these ... but the actual RGB value look reasonable
in GIMP. I think the main reason is that I never managed to calibrate
my monitor properly (it's an old flat screen from 2004).
But I also wonder if there may be a general problem with
interpolating in RGB color space as opposed to something like
CIELAB that better matches human perception of color differences
(BTW, it's not related to linear RGB vs. gamma RGB, I see lines
both with assumed_gamma 1.0 and with 2.2)
I also tried dithering (new in 3.7) but it didn't change much. Doing
the same gradient in GIMP with dithering looks smoother but that is only
because gradients use extremely strong dithering.
Date: 17 Aug 2011 04:25:01
Message: <web.4e4b7a474f03222d3b03be610@news.povray.org>
It's very interesting, I am in another computer and now I really cannot see
those sharp lines, it is definitely a screen issue.
I was using 24bits, but there must be some other factor.
Thank you very much for your expert comments!
Date: 17 Aug 2011 08:34:15
Message: <4e4bb547$1@news.povray.org>
are you using a VGA-cable? if so, it's probably a sharpness-setting on
your monitor.
Try http://www.lagom.nl/lcd-test/ for some manual LCD calibration, but
be aware that if you're using a TN-panel (i.e. any cheap LCD), any real
color-calibration is rather useless, because of the very low viewing angles.
Date: 18 Aug 2011 02:35:26
Message: <4e4cb2ae$1@news.povray.org>
Am 16.08.2011 21:00, schrieb Zeycus:
That's your graphics hardware and/or image file format limitations you see.
If by "clearly" you mean "when zooming into the picture" or "when having
an exceptionally close look", then that's perfectly normal for the
traditional 8 bit per channel (24 or 32 bit per pixel) file formats and
graphics cards. Yes, depending on the sky sphere gradient they can be
quite prominent, even to the point where "clearly" would be a fitting term.
In that case...
(A) If you're using POV-Ray 3.6, output the image to a 16 bits per
channel file format (e.g. "+fn16" for PNG with 16 bpc), then downsample
to 8 bits per channel using some external piece of software that
supports dithering (e.g. LILYsoft's IC,
http://www.lilysoft.org/IC/ic_index.htm).
(B) If you're already using version 3.7(RC3) of POV-Ray, use "+th" or
"Dither=yes"; this activates POV-Ray 3.7's inbuilt dithering for the
output file.
"Dithering" is a mechanism that hides color banding artifacts by adding
noise-like artifacts, which are less obvious to the human eye.
If by "clearly" you mean "at first glance", then you may indeed have set
your display to 15 or 16 bits per pixel (i.e. 5 to 6 bits per color
channel); in that case I suggest you simply change that.
