POV-Ray : Newsgroups : povray.newusers : stbenge Fastprox fast SSS Server Time
26 Mar 2026 14:47:55 EDT (-0400)
  stbenge Fastprox fast SSS (Message 21 to 27 of 27)
Subject: Re: stbenge Fastprox fast SSS
Date: 3 Sep 2009 05:05:01
Message: <web.4a9f85d96629da5eac55fca00@news.povray.org>
What I meant, I see much less of a flicker now:
maurice.raybaud.eu/images/stories/FASTSSS.avi
though it doesn't mean there is none...
Here are my new settings for radiosity:
      pretrace_start 0.08
      pretrace_end   0.08
      count 70
      nearest_count 7
      error_bound 1.75
      recursion_limit 1
      low_error_factor 0.2
      gray_threshold 0
      minimum_reuse 0.025
      brightness 1.0
      adc_bailout 0.01/2
 always_sample off
For now I should focus on something else.
The color for instance is not satifying at all, mainly because of the use of
Ambient values > 0, I suppose. I also need to work on the mesh
Again, BSP is great!
Date: 3 Sep 2009 09:57:07
Message: <4a9fcb33$1@news.povray.org>
You should change that indeed. Radiosity and ambient don't mix very well.
If you're not using ambient to model glowing objects, you can just set
"ambient_light" to zero.
Date: 3 Sep 2009 10:45:01
Message: <web.4a9fd5eb6629da5e6ce87ead0@news.povray.org>
 thanks, in the global settings? but If I do decide to use some mesh light or
the ambient of an hdri will it make an "exception for it"? or there is another
way to change the default ambient to 0 instead and just specify a value for
glowing objects? I want to make things as flexible as I can since this is only
the character and the set should be able to change.
Date: 3 Sep 2009 15:57:47
Message: <4aa01fbb$1@news.povray.org>
web.4a9fd5eb6629da5e6ce87ead0@news.povray.org...
>> > use of
> or
> another
> for
> only
Put at the beginning of the script :
#default {
                finish { ambient 0 }
 Every texture with no ambient statement will take  0 as ambient value
Marc
Date: 8 Sep 2009 08:50:01
Message: <web.4aa652bb6629da5e7bb925340@news.povray.org>
> >> > use of
> > or
> > another
> > for
> > only
> #default {
> Marc
Wow! great, thank you Marc.
A question about the beta related to Fastprox:
Does the min extent and max extent thing still require some margin? Comments in
the macro say this is because Pov has difficulties adjusting tight bounding
boxes, so I wondered if that hadn't been solved already in the current beta
with all the work that has been done...?
Date: 8 Sep 2009 10:00:54
Message: <4aa66396$1@news.povray.org>
Not sure what you mean, but if your question is "do min_extent and
max_extent still return a box larger than absolutely necessary in
certain circumstances (e.g. cylinders not aligned with either of the
three axes)", then yes: This is still the case, has been the case with
3.6 already, and I assume it will remain so.
POV-Ray will /never/ be able to guarantee that for all object types the
min_extent / max_extent values are as "tight" as theoretically possible.
With this being an unsurmountable fact, I don't expect anyone to invest
any significant effort into addressing this for /some/ object types.
Date: 12 Sep 2009 06:05:00
Message: <web.4aab71db6629da5e8e8f19690@news.povray.org>
No problem, I just wanted to make sure I optimized my sample count.
I'm starting to get decent results with fastprox:
http://maurice.raybaud.eu/images/stories/FASTSSSskin.avi
