![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm setting up an animation, where every frame is very different. I only want
povray to go to the trouble of creating an image if condition #if() is met.
Are there certain kinds of errors for which povray will give an error so
serious it refuses to create an image, but go on to the next frame? Something
like 1/0? And in these cases, does it always create an all-black bitmap?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"gregjohn" <pte### [at] yahoo com> wrote in message
news:web.48aea49b13c48d0e34d207310@news.povray.org...
> want
> met.
> Something
I believe that any error serious enough to actually prevent POV-Ray from
creating one image in an animation sequence will halt the render and prevent
it from generating subsequent images in the sequence.
There are certain things that will produce an all-black image, such as not
having anything in the scene (which can render very quickly).
I'm not sure about exactly the problem you're trying to solve, but if you
have a big list of images and you want to suppress certain ones based on
something that's evaluated only when you generate the sequence, you could
always use the POV-Ray write command to generate a list of the ones you need
to delete in a format that you can run as a script once the renderer has
finished.
Chris B
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ironically, this sentence gives me the advice I needed. The problem is that the
set of images which I wished to ignore were also the ones that rendered
extremely slowly. And my #if() predicts the render speed. I could simply put a
black object in front of the camera when #if() is meet, and meet at least half
of my objectives.
thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> of my objectives.
Wouldn't it be much easier to do this:
#if(condition)
#include "TheActualSceneFile.pov"
Then render this scene instead of TheActualSceneFile.pov.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
if every frame is very different, why not use a case/switch based on the
frame_number? That or set your clock variable in such a way that every frame
can be used - depending on the length of the animation, processing frames that
aren't needed may add an unnecessarily large amount of time.
Something like:
#switch( frame_number )
#case( 4 ) // object for frame four:
box{ <-1,-1,-1>, <1,1,1> }
#break
#range( 1, 5 ) // objects for frames 1 through 5
// note that all clauses that are true will be processed
sphere{ }
#break
Either that, or use the file queue and set up several files in advance, perhaps
in conjunction with the above techniques
-Reactor
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> #if(condition)
> #end
I'm randomly exploring fractal space, and only want images if they are
interesting based on the condition in #if(). But maybe the best way in all of
this is a while loop that goes back to find another random location in the
pattern if the chosen location isn't interesting enough.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
gregjohn nous illumina en ce 2008-08-22 23:11 -->
>> #if(condition)
>> #end
When randomly exploring a fractal, it's very hard to detect if a given
"location" is interesting before you actualy render that location. Your test may
flag a marvalous location as uninteresting and skip it, and then render 100 of
extremely boring ones accidentaly flaged as "interesting"...
You know you've been raytracing too long when you tell stories to your kids that
include stuff like "Once there was a polygon mesh who was very sad because he
was only Gourard shaded."
-- Taps a.k.a. Tapio Vocadlo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> if a given "location" is interesting before you actualy
> render that location. Your test may flag a marvalous
No, with eval_pigment, one may compare the colors of two close-by points in
fractal space. If they are identical, then there's a good chance you're out in
a field of blanket color. I had a pretty good run of looking at fields where
the colors were dissimilar. Not all worthy of uploading to zazzle, but
certainly interesting. I think the most interesting test (but biggest
longshot as far as remote odds) would be to look for a black spot and a
non-black spot in the same field.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
gregjohn nous illumina en ce 2008-08-25 22:28 -->
You'll need to sample 100's of pairs to be sure. If you sample only 2 locations,
you may well miss a very interesting image. Two close-by points can be
identical, and be just next to some very busy area, or just apen to lie
parallel, or almost, to the local gradient.
You need a bare minimum of 3 points in a triangle.
You know you've been raytracing too long when you look at real clouds and
criticise their media and radiosity settings.
Tom Melly
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> only 2 locations, you may well miss a very interesting image.
> Two close-by points can be identical, and be just next to some
> very busy area, or just apen to lie parallel, or almost, to
> the local gradient.
How about a #while loop set to kick out when it reaches 9999? It's just a
computer doing the heavy lifting, it doesn't get bored! ;-)
I tried a three-pointer for a while but wasn't sure I liked the results better.
I'm still learning the geography of the Mandelbrot set, but I ended up in too
many places where it was uber-busy, unartistically so.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
