POV-Ray : Newsgroups : povray.newusers : Sponge Server Time
14 Mar 2026 00:13:47 EDT (-0400)
  Sponge (Message 1 to 10 of 12)
Subject: Sponge
Date: 14 Dec 2007 21:10:01
Message: <web.4763370af46252fd9c37dbc40@news.povray.org>
I need to make a sponge. The kitchen kind, not the cool mathematical surface.
I've tried making it using an isosurface with f_noise3d. It looked almost, but
not quite, entirely unlike a sponge. The second thing I tried was making a
script to show a huge number of spheres clipped by each other and the rectangle
that contained them. That one was recognizable as a sponge, but barely. It's
going to be the main part of the picture, so I can't just use a spongy texture.
All I can think of is essentially using an actual picture of one. Any ideas?
Subject: Re: Sponge
Date: 15 Dec 2007 00:07:17
Message: <476360A8.9080805@joplin.com>
Have you tried a pigment function for your isosurface?
I'm thinking granite might look good.
Subject: Re: Sponge
Date: 15 Dec 2007 11:00:00
Message: <web.4763f9f0d68f7f9f2ae8612c0@news.povray.org>
If you are looking for a sponge-like pattern for an isosurface, you essentially
need little spheres subtracted from another shape.  For the little spheres, try
the crackle pattern with "form <1,0,0>" and combine it with your main sponge
shape.  You will likely need to play with the threshold value and scaling.  I
haven't tried this yet, but I have used it for other things which need random
circular shapes like raindrop ripples such as in
[http://barberofcivil.deviantart.com/art/BuoyOBuoy-v2-CGSphere-49226103]
-tgq
Subject: Re: Sponge
Date: 15 Dec 2007 19:24:24
Message: <47647038@news.povray.org>
I'm thinking that, if the isosurface looked *almost* like a sponge, it
might just be a matter of "tweaking" the texture or the function
parameters.  Could you post a bit of sample code for us to play with?
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Subject: Re: Sponge
Date: 16 Dec 2007 21:15:00
Message: <web.4765db3ad68f7f9f9c37dbc40@news.povray.org>
I said almost, but not quite, entirely *un*like a sponge. That is to say, it
looked nothing like one. I was referencing the Nutrimatic Drink Dispenser from
The Hitch Hiker's Guide to the Galaxy, which is described as producing a
substance almost, but not quite, entirely unlike tea.
Subject: Re: Sponge
Date: 17 Dec 2007 23:59:15
Message: <476753a3@news.povray.org>
Ah, I see.
Might I ask whether you're going for an actual, natural sponge or a foam
rubber spongelike object?  (Which would probably make the difference
between (a) an isosurface modeling a rather crinkly thingy and (b) a
block of utterly unnatural stuff with holes in it, and possibly a layer
of Brillo-like stuff attached to the bottom...)
Either one will, of course, get your dishes clean, but with a totally
different esthetic.
Bear in mind that, whichever you choose, a good granite normal will hide
a multitude of sins...  ;)
--Sherry Shaw
Subject: Re: Sponge
Date: 22 Dec 2007 16:20:00
Message: <web.476d7f72d68f7f9f9c37dbc40@news.povray.org>
I'm going for b. the unnatural stuff. I'm modeling it somewhat after the sponge
at
http://www.nortonprocleaning.com/Media/Documents/S0000000000000001051/Sponge%20Pads%20-%20Cellulose%20Sponge.jpg
I tried using a granite normal. It doesn't seem to work. What I'm considering
doing is using an isosurface for the bigger holes, and surface normals (or
another isosurface, if possible) for the smaller ones. The problem is, I can't
find a pattern that works. I might be able to make a function to do it, but it
wont seem to let me use rand() in them. Specifically, I'd use
rand(seed(floor(x)), or something to that extent.
Subject: Re: Sponge
Date: 22 Dec 2007 21:03:04
Message: <476dc1d8$2@news.povray.org>
Archpawn nous apporta ses lumieres en ce 2007/12/22 16:19:
> at
You could also try to use a pattern with holes in it. It could be s granite
pattern scaled small with a color_map that have some transparency.
pigment{granite scale 0.02 color_map{[0.03 rgbt 1][0.03 rgb 1]}}
If you use surface normals, you need to scale it small relative to your holes
and give it a strong value.
normal granite 3 scale 0.01
Disc space -- the final frontier!
Subject: Re: Sponge
Date: 23 Dec 2007 05:35:25
Message: <476e39ed$1@news.povray.org>
"Archpawn" <nomail@nomail> wrote in message
news:web.476d7f72d68f7f9f9c37dbc40@news.povray.org...
> sponge
> at
> considering
> can't
> but it
Hi Arch.,
I think you'll find it difficult to achieve this with a single isosurface.
You can combine isosurfaces, but you end up with little holes in the
surfaces of your larger holes, whereas the photo you linked to seems to have
relatively cleanly formed larger holes.
To get around that, the following example uses a rounded crackle function to
create an isosurface with large round holes (as suggested by Trevor), then
it cuts thin layers of smaller holes out of the surface. The hole cutting
objects (SpongePress2 and SpongePress3) are kept thin by slicing a slightly
scaled down version of the object out of them so that the smaller holes
don't penetrate too deeply into the sponge surface. This leaves the larger
holes looking fairly clean.
This renders reasonably quickly on my machine (a couple of minutes on a dual
2GHz machine).
Unfortunately, most of the crackly surface effect is attributable to errors
due to the small scale, with bits of the isosurface missing. Scaling up
produces a less broken (and IMO less convincing) effect and increases render
times horendously. Maybe someone who's good at isosurfaces could improve on
this.
I've also been playing with a macro to distribute different sized holes
across a surface (using CSG and rand() rather than isosurfaces). Some
results are looking ok, but I've also got some pretty bad render times with
that. The main advantage is that it can do different shapes (virtually any
shape you want) and you get a finer control over the proportion of
differently sized holes. I'll let you know if that throws up anything good.
Chris B.
camera {location <-0.28, 0.44, -0.58> look_at <0.1,0.15,0> angle 40}
light_source {<-5,0.1,-4> color rgb 1}
light_source {<0.4,1,0>    color rgb 0.5}
light_source {<0.5,1,0.1>  color rgb 0.5}
light_source {<0,1,-0.005> color rgb 1}
#declare F=function{pigment{
  crackle
  form <1.5,0,0>
  turbulence 0
  color_map { [0 rgb 1]  [0.9 rgb 0] [1 rgb 0] }
  scale 0.035
  scale 1+x*0.2
#declare F1=function{pigment{
  crackle
  form <1.5,0,0>
  turbulence 0
  color_map { [0 rgb 1]  [0.4 rgb 1] [1 rgb 0] }
  scale 0.006
  scale 1+x*0.2
#declare F2=function{pigment{
  granite
  turbulence 0.2
  color_map { [0 rgb 1]  [0.2 rgb 1] [1 rgb 0] }
  scale 0.01
#declare Transparency = 0;
#declare PrePressedSponge = isosurface {
  function { F(x,y,z).red - 0.6}
  threshold 0.01
  max_gradient 50
  max_trace 10
  contained_by{box{0,<0.37,0.1,0.2>}}
#declare SpongePress2 = difference {
  isosurface {
    function { 0.5 - F1(x,y,z).red}
    threshold 0.1
    max_gradient 500
    max_trace 10
    contained_by{box{-0.001,<0.37,0.1,0.2>*1.001}}
  box {0.003,<0.367,0.097,0.197>}
#declare SpongePress3 = difference {
  isosurface {
    function { F2(x,y,z).red - 0.6}
    threshold 0.01
    max_gradient 1800
    max_trace 10
  box {0.001,<0.369,0.099,0.199>}
#declare Sponge = difference {
  object {PrePressedSponge}
  object {SpongePress3}
difference {
  object {SpongePress2}
      bozo
      turbulence 0.5
      omega 1
      color_map {
        [0   rgbt <169,115,051,255*Transparency>/255]
        [0.1 rgbt <174,117,053,255*Transparency>/255]
        [0.2 rgbt <179,123,056,255*Transparency>/255]
        [0.3 rgbt <200,145,071,255*Transparency>/255]
        [0.4 rgbt <218,173,104,255*Transparency>/255]
        [0.5 rgbt <232,201,139,255*Transparency>/255]
        [0.6 rgbt <246,221,157,255*Transparency>/255]
        [0.7 rgbt <246,223,166,255*Transparency>/255]
        [0.8 rgbt <199,149,078,255*Transparency>/255]
        [0.9 rgbt <186,132,059,255*Transparency>/255]
        [1   rgbt <174,128,067,255*Transparency>/255]
      scale 0.006
    finish {ambient 0.3}
plane {y,0 pigment {rgb 0.4}}
Subject: Re: Sponge
Date: 23 Dec 2007 10:49:04
Message: <476e8370$1@news.povray.org>
Chris B nous apporta ses lumieres en ce 2007/12/23 05:35:
> Regards,
> Chris B.
Using differences? You are experiencing the problem from multiple overlaping
bounding boxes. Try bundling your small bits in a blob that you difference from
the main object. It's usualy much faster, but you are limited to spheres and
round capped cylinders.
diference{
	object{Your_Main_Object [Object_modifiers]}
	blob{treshold 0.02
	  Your_Macro}
Hard work pays off in the future. Laziness pays off now.
