POV-Ray : Newsgroups : povray.newusers : night vision (or similar) needed Server Time
20 Dec 2025 06:15:26 EST (-0500)
  night vision (or similar) needed (Message 1 to 8 of 8)
Subject: night vision (or similar) needed
Date: 24 Sep 2006 06:00:01
Message: <web.4516560d8fdbbf612e23de600@news.povray.org>
I'm new, please be kind.
I have simple scene. the only source of light is from a point light source
projecting through a slit in a wall that then falls on a prism.  I want the
resulting rainbow to illuminate the scene.
I have the scene set up and it works nicely, except the image produced is
too
dark. What can I do?
I cannot find any info on how to adjust the sensitivity of the camera.  I
cannot see how to get the same effect from spot lights or other light
sources as I need the slit shaped light source. Also, would spotlights
actually be brighter?
I would post the scene and image but I'm not allows to in this group -
should I ask in another group?
steven
Subject: Re: night vision (or similar) needed
Date: 24 Sep 2006 06:43:52
Message: <45166168@news.povray.org>
> too
If the light is just too dark, just raise the RGB-Value on the
lightsource. If that doesn't work, why not post the image as a jpeg in
p.b.images and ask there? Descriptions of images often don't get as many
useful answers as showing the image itself. :-)
Tim
aka "Tim Nikias"
Date: 24 Sep 2006 08:51:25
Message: <45167f4d$1@news.povray.org>
> too
A) as told, you could increase the RGB value
B) if I understood your image correctly, you could increase the light
sources (ie. put n+1 light sources in 'bout the same place)
C) if using radiosity, you could possibly increase the brightness -value
D) check your gamma settings
For images there's povray.binaries.images and for scene files there's
povray.binaries.scene-files. These are often mentioned as p.b.i and p.b.s-f.
> Regards,
> steven
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 24 Sep 2006 12:15:53
Message: <4516af39$1@news.povray.org>
Steven Borley nous apporta ses lumieres en ce 24/09/2006 05:56:
> too
> Regards,
> steven
You can use a value greater than 1 for the light.
You can use a filter or transmit value greater than 1 for the prism: this will
effectively amplify the light as it goes trough the prism. A pigment like "rgbt
2" is legal if not physicaly correct.
A spot_light is not brighter than a point_light. The rays of light outside of
the illumination cone are just suppressed.
You are right: there is no other way to get a rectangular light beam than to use
  a slit mask.
You need photons if you want the spectrum to apears projected on your scene.
You need radiosity if you want that spectrum to in turn illuminate the rest of
the scene.
If you use scattering media to make the beam visible and use radiosity, there is
NO way that the scattered light can illuminate the scene. The "media on"
radiosity option only allows emissive media to light the surrounding.
If the scene file is relatively short (less than 2K), it's possible to place
it's text here, but it's beter on povray.binaries.scene-files.
Post the images on povray.binaries.images.
'hAS ANYONE SEEN MY cAPSLOCK KEY?'
Date: 24 Sep 2006 15:10:01
Message: <web.4516d7145363cd102e23de600@news.povray.org>
Tim, Eero, and Alain, thank you so much.
It has taken me some time to read through an understand your replies.  I
didn't realise I could have light values that exceeded 1.0 - don't know but
it just didn't occur to me.  First thing I did was to change my light source
to...
light_source { < 2, -0.5, 0 > 10*White }
Now I have enough light. Actually now I see I have multi-path problems - but
that's another thing, and I want to try and fix that myself.  I may try some
of the other suggestions to. So nice to have choice! There is a good chance
that the will be a combination that will give me just the effect I want.
I have still have some questions related to the original problem, but I'll
take your advice and ask where I can also post the image files.
Thank you once again.
Steven
Date: 24 Sep 2006 17:10:38
Message: <4516f44e$1@news.povray.org>
Hey, that's what this group is for :). You're welcome.
> to...
Don't wonder, it actually took 2-3 years for me to find that out (no, I
didn't know about this newsserver back then either).
Like said, povray.binaries.images for the image and
povray.binaries.scene-files for the source.
> Regards,
> Steven
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 27 Sep 2006 04:09:21
Message: <451a31b1$1@news.povray.org>
You need to know which kind of illumination need to increase
FIRST:
if it is the whole scene which got a lack of light ..then use
    global_setting {
            assummed_gamma 1.1  ( less is the value , lighter is your
picture) (this light up the shadows, in fact the overall scene)
    also
 if there is not enought light sources for lighting you scene , you can add
    ambient_light 2.0 for exemple (i do not recommend to use this parameter)
SECOND:
If you think that the amouth of light from a particular light source is not
enough the increase the color by a factor color rgb 1.2*<0.1,06,1> instead
of <0.1,0.6,1> for exemple ..(increasing the color will not light the
shadows , that will light the illuminated partof the scene and darken the
shadows.)
LAST:
if you want to light the shadow, and contrast the scene, then use the
radiosity ..
in brief you must add the following
global_settings {
    assumed_gamma 2.2 // default value
   // ambient_light rgb <0.2,0.2,0.2>   // to use at last choice
    #include "rad_def.inc"
    radiosity{Rad_Settings(Radiosity_OutdoorLQ,off,off)} // look at the
'rad_def.inc' file into your pov/include folder
news:web.4516560d8fdbbf612e23de600@news.povray.org...
the
> too
> Regards,
> steven
Date: 28 Sep 2006 20:14:12
Message: <451c6554$1@news.povray.org>
Steven Borley nous apporta ses lumieres en ce 24/09/2006 15:05:
> to...
> Regards,
> Steven
Also, a light can have a negative value like rgb -1 to shed "darkness". In fact,
any colour can have negative values: rgb<-1,1,0> is legal and will apears as
green. You wont see the difference in a normal scene, but it will have an effect
on the surrounding in a radiosity scene.
"The way England treats her prisoners, she doesn't
  deserve to have any."               --Oscar Wilde
