POV-Ray : Newsgroups : povray.newusers : Getting good glows over high-intensity areas Server Time
31 Mar 2026 01:03:24 EDT (-0400)
  Getting good glows over high-intensity areas (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Getting good glows over high-intensity areas
Date: 19 Jul 2005 18:45:01
Message: <web.42dd81fa9c9b6ebd3b6b98ba0@news.povray.org>
Thanks!  I have to say, though- I'm having some problems getting it to run
on my machine.  I am a COMPLETELY new user here, so would you mind walking
me through it?  I'm not too sure how to use the command line args
correctly, as when I hit "go" it finishes in 0.4 sec and nothing is
generated.  Anyway, a step-by-step would be much *very* appreciated.
Thanks,
ZA
Date: 20 Jul 2005 03:54:39
Message: <42de033f$1@news.povray.org>
"ZainAnak" <nomail@nomail> wrote in message
news:web.42dd81fa9c9b6ebd3b6b98ba0@news.povray.org...
Okay, happy to try.
I posted the script with it set to render the final image, so be sure you
change it to CreateImage=yes; first. I expected the comments to make sense,
probably wasn't a good idea to start it out in reverse with the hope it
would be changed right away.
Those lines with the //cmd: can be right-clicked and the popup menu will
show a selection for adding it to the command-line field of the toolbar so
you don't need to type it in. The first such line sets the output image
format to PNG uses a path and filename expected to be one of the POV-Ray
library paths. The folder "renderings" is one I use for all output; however,
yours could be anywhere else you usually output the renders to.
Just make sure it is also a library path or in the current scene file
folder, otherwise it won't be found later. Library_Path= can be added to
your povray.ini via the Tools menu, select 'Edit master POVRAY.INI', and
look at the end of that text file (folder must already exist!). Close and
Save the file. You will need to close and run POV again to reset things if
you choose to do this.
Okay, with that much out of the way you should be able to get a rendered
example scene if you left it in the script (didn't replace it with your own
yet). Of course, you could replace that scene (comment it out or delete the
lines) and either copy and paste your entire scene into it (probably not
wise for a large file) or collect it all into one or more #include files
then just add them that way.
Since includes are easier to manage I'll tell more about that.
#if (CreateImage=yes)
#include "yourscene.pov"
is how it would look at its simplist. My example scene with the crackle
textured sphere has lights and camera within that if/end section but it
would need to be removed for your own to go there. For now you might want to
give it a look as is first to be sure it works right.
Next, after rendering that image, you will need to change the command-line.
So right-click the second //cmd: line in the header comments and select that
to replace the command-line field with it. Render that way and you should
see the resulting light-bleed image. Again, be sure you use a path (or none
to render to default location) and filename you want. As long as the first
time render has a matching file name that is under the " begin
light-bleeding part" you should be ok, the second render could be anything.
If this doesn't help completely yet just ask more about it.
Two other things I should mention is image resolution and the 2/3 index
values of the pigment_map. You're image size for the first rendering will
probably need to be larger than the second in order to prevent lowering the
quality. Also, I didn't set this up for anything more than a simple 4:3
ratio and the scale would need to be adjusted if another ratio is used.
Likewise, a camera with the proper aspect ratio will be needed. As it is now
there is no camera defined since it uses a default one at <0,0,0> with
default parameters.
Maybe you can at least get started on it knowing all this.
Bob Hughes
Subject: more to be said
Date: 20 Jul 2005 04:09:57
Message: <42de06d5$1@news.povray.org>
Reread my "help" only after posting that reply and saw I left out anything
about the 2/3 index values found in the pigment_map...! Early morning for
me, sorry.
I chose two-thirds so that the remaining one-third is the brightest parts of
the image and would be the only places blended into the original image.
While I'm here again I might as well emphasize the fact that I hadn't even
used an actual premade scene file to test this effect yet. I have no idea if
it really looks okay. I'm not 100% positive it works as expected so you'll
probably know how it really looks before I will.
Subject: Re: more to be said
Date: 20 Jul 2005 10:25:00
Message: <web.42de5e3fa93ad1b23b6b98ba0@news.povray.org>
Bob, thanks for all the help!
I had an idea, though.  If you look at the original picture I posted as a
reference, you'll notice that it's a pretty small, well-defined bleed that
occurs at the sun line.  I was wondering- couldn't I achieve this with some
sort of area light setup?  All I really want, after all, is the sun lines
to be a *little* blurrier than normal- I don't want everything bright in
the scene to glare out, like your sample code would do.  Here is my current
light:
light_source {
  <-5000, 4000, 15000>
  color rgb <0.8, 0.4, 0.2>*4.1
how would you turn this into a light with slightly fuzzier lines?
Thanks!
-ZA
Subject: Re: area lights
Date: 20 Jul 2005 12:07:41
Message: <42de76cd$1@news.povray.org>
news:web.42de5e3fa93ad1b23b6b98ba0@news.povray.org...
Always welcome to any I have.
> current
> light:
 light_source {
  area_light 150*x, 150*y, // dimensions, or physical size
  4, 4 // number of sources for each axis (above). integers only
  adaptive 1 // sampling rays (more is slower, but better. integers only)
  jitter // smooth shadows, without this you would get banding
  circular // make it round not square
  orient // turn toward scene objects (works in conjunction with circular)
Ha ha ha! Well, you're right. Why not keep it simple? Heck, I'm just glad
you got me going on Samuel's light-bleed idea, otherwise I might have never
had such a thing here.
When you're dealing with area_light the important things are size of the
array and smoothness of the shadows. I've added in what might be okay with
you're scene but you'll definitely need to adjust the x and y dimensions to
either narrow or widen the resulting shadows.
The number of sources (4 X 4) ultimately determines quality, as well as
speed of the render, so you might also need to increase that even if it
slows the rendering down. But if the shadow edges are only needed to be very
thin you could possibly lower those two numbers (equally and integer only)
to a 3 by 3 array. All depends on what you see in the render as you make
adjustments.
Oh yeah, and area_light does not affect surfaces directly, such as specular
highlights and the diffuse finishes. It's only for shadows.
You would be wise to read up on this in the scene help (docs), section
3.4.7.5  Area Lights, so I'll leave it at that. Unless you have more to ask,
please go ahead and do so.  : )
Date: 20 Jul 2005 14:25:00
Message: <web.42de965ef335b5b53b6b98ba0@news.povray.org>
Bob, this is looking GREAT.  I'm futzing around with the settings, and it's
giving me some nice color ramps where the sun falls.  And I don't even have
to render twice... woohoo!
Thanks!
-ZA
Date: 20 Jul 2005 17:16:14
Message: <42debf1e$1@news.povray.org>
So low! I generally use 17, 17 myself. Maybe I could go lower if I used
jitter more often, but I still recommend using higher numbers than 4; the
jittering with such a low number probably forces otherwise unnecessary
anti-aliasing.
Of course, with such high numbers it's very important to use adaptive (so
that you don't actually shoot a full 17x17=289 shadow rays); adaptive 1 has
always worked best for me.
Finally, I also recommend using a number which is one greater than a power
of 2 (3, 5, 9, 17, 33) because these make the most sense with the adaptive
process (See the second picture at
http://www.povray.org/documentation/view/3.6.1/313/ , which demonstrates why
this makes sense).
 - Slime
 [ http://www.slimeland.com/ ]
Date: 20 Jul 2005 18:29:59
Message: <42ded067$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message
news:42debf1e$1@news.povray.org...
> anti-aliasing.
To be honest, I actually wrote 5,5 at first and replaced it with 4,4
thinking it might seem too slow. I subconsciously consider shorter render
times to be better than quality of the output. A habit formed during the
days of one-line-at-a-time renderings and hardly ever doing "final" images
left running for hours or days.
> has
Makes sense. Proves you *can* teach an old dog new tricks. I've always
stayed away from the larger arrays just because I worried about longer
render times.
> why
> this makes sense).
I went looking for the example files and read each lights\arealight*.pov, as
well as rendering them in a few different ways to check against my usual way
and what you said. Firstly, I hadn't realized those had 17 by 17 arrays.
Secondly, I'm amazed to find out that circular.pov has only 4 by 4 arrays
and the shadows are awful. But even more amazing is that after changing them
to 9 by 9 the render time only increased from 11.56 to 11.64 seconds! The
shadows look great, too; although, any higher than 5 by 5 array and the idea
behind the example of a circular arealight compared to non-circular gets
lost. ;-)
Apparently I'm going to need to change my mind about arealights and start
giving better advice about them in the future.
Thankyou for jostling my old POVing into new territory! If I can just train
myself not to drop back to 4X4's again I should be okay.
Date: 24 Jul 2005 10:25:01
Message: <web.42e3a3d9a93ad1b2e9d8b2350@news.povray.org>
There might be one more effect in the picture, but the ones you discussed in
this thread, that would cause the line to be blurred: if the wall is
bumped, the bumps in the wall may reflect light, causing the neighboring
bumps to be lit, even that they are not directly lit by the sun. Radiosity
or photon maps might be used for this.
> light:
> light_source {
> Thanks!
> -ZA
Date: 24 Jul 2005 10:45:00
Message: <web.42e3a829a93ad1b2e9d8b2350@news.povray.org>
And there might be yet one more effect: the bumps might cause the shadow
line to `wiggle', what may look like a kind of softening from some
distance.
