POV-Ray : Newsgroups : povray.newusers : Animation without clock Server Time
21 Dec 2025 20:52:13 EST (-0500)
  Animation without clock (Message 1 to 7 of 7)
Subject: Animation without clock
Date: 24 Feb 2005 15:50:00
Message: <web.421e3dcd625e6befca7192a50@news.povray.org>
I want to render a few images of the same scene, but with the camera in
differente places. Is it possible to make them all at once, reducing
raytracing time? Do I have to use a clock for this? Or there's some other
way?
Thanks,
Cesar
Subject: Re: Animation without clock
Date: 24 Feb 2005 16:03:37
Message: <421e4129@news.povray.org>
> way?
You could use frame_number:
#switch(frame_number)
    #case(0)
        camera {...}
Or like this:
#declare locations = array[3] {<1,2,3>,<4,5,6>,<7,8,9>};
#declare lookats = array[3] {<3,2,1>,<6,5,4>,<9,8,7>};
    location locations[frame_number]
    look_at lookats[frame_number]
 - Slime
 [ http://www.slimeland.com/ ]
Date: 24 Feb 2005 16:25:01
Message: <web.421e44f674fee23ca7192a50@news.povray.org>
Great! That's what I was looking for. But the performance question remains.
Will it be faster to render the scene like that rather than one image at a
time? I ask because I will automate this and there will be a c++ program
generating the .ini file(s). If I will render 20 images, should I generate
20 .ini files or just one and let povray deal with the animation?
If povray starts from the begining for every frame, then there's no speed
gain and I think i prefer to change the file for each image. But if povray
cut some steps cause they've been done before, the the speed gain might be
worthwhile.
> > way?
>     #case(0)
>         camera {...}
>     #end
> #end
> Or like this:
> camera {
>  - Slime
Date: 24 Feb 2005 16:35:41
Message: <421e48ad@news.povray.org>
"Cesar" <ces### [at] terracombr> wrote in message
news:web.421e3dcd625e6befca7192a50@news.povray.org...
> way?
With the official version 3.6, yes; using the clock along with #switch()
#case() choices to select each different camera view. You're probably asking
about putting all views into a single image at rendertime, though, and that
cannot be done directly.
This has been a subject talked about plenty in the past so I looked for any
custom-patched POV-Ray's and only found a stereo view one at:
http://stereopov.ichthyostega.de/
At least that shows it could be done. Maybe someone else knows if another
kind exists, my mind is drawing a blank about it.
Bob Hughes
Date: 24 Feb 2005 17:05:02
Message: <web.421e4f6d74fee23ca7192a50@news.povray.org>
Very interesting. I actually don't care for the pictures side by side. But
the developer of stereopov also talks about a considerable speed gain.
That's what I want. Maybe there's another patch for that? I jsut did some
tests and povray and the render time is the same for each image, as I
expected. I guess I'll spend some days rendering :( It's not that bad :)
> Bob Hughes
Date: 24 Feb 2005 18:33:33
Message: <421e644d$1@news.povray.org>
remains.
> time?
Each frame will take the same length of time to render regardless of whether
it's a frame of an animation or a separate pov file.
> worthwhile.
The only steps that are cut are things like the initialization of the
rendering engine. If I were you I'd do it all with one file as a single
animation render, unless the files are completely unrelated to each other.
 - Slime
Date: 24 Feb 2005 23:34:00
Message: <FUhJ5BAbpqHCFwK5@econym.demon.co.uk>
It can be done directly in MegaPOV, using the "camera_view" pigment.
I've not checked what the speed is like, but I'd guess that it's slower
at RENDER time than doing two separate renders because POV has the
additional step of finding the surface onto which the camera_view
pigment is painted.
There might well be speed gains in situations where there's an object
that takes a large amount of PARSE time to construct, since it would
only need to be parsed once.
Mike Williams
Gentleman of Leisure
